Question about Craftsman 4 Cycle Blower/Vac
Motor Oil Mr. Fix It: Is it best to mix the oil/gas before I put it into the engine or should i mix it beforehand? Thanks!
  • Kdabell Jan 26, 2009
    Thank you, Mr. Fix It, for the extra advise!!!
2 Suggested Answers
SUPERMAN_B_1
  • 294 Answers
SOURCE: I just foun out that i forgot to add oil to gas mixture to my blo
hello, what you should do is drain out the gas from the tank into a clean container so you can add the oil to it and you should also check your spark plug make sure it's o.k. after draining out the gas try starting the blower a few times with out the spark plug wire connected to the spark plug this will flush out and of the pure gas from the fuel lines, after doing this re-connect the Spark plug wire and add your fuel/oil mixture and re-start, it might take a few times for it to start due to all the gas in the engine but it'll start also if your blower has a primer bulb you may want to prime it a few times after adding the fuel oil mixture to get it in the combustion chamber, if after doing this you still get nothing you'll want to re-place your spark plug it might be fouled out. good luck
Posted on Mar 25, 2009
  • 5 Answers
SOURCE: I think they used wrong gas ie no oil mix and froze engine
If the piston froze to the cylinder wall its toast.
Posted on Feb 24, 2010
Oil petrol mixture for Rockwell 26cc weedeater
Two cycle engines run on a mixture of gasoline and oil. Each engine type is designed to run on a specific gas-to-oil mix ratio.
IMPORTANT: Use only oil that is labeled for use in "Two-cycle" or "Two-stroke" engines. Home Depot and other stores now have "premixed fuel" of gas and 2 cycle oil.
To mix two-cycle fuel, start by putting correct amount of oil in gas can. Then slowly add correct amount of gasoline. Do not try to mix gas and oil directly in gas tank of equipment.
IMPORTANT: Do not use any fuel that is over 30 days old. Do not mix more fuel than you are likely to use in a month. Old fuel can gum carburetors and prevent starting. Always use fresh fuel.
The chart below shows correct amount of oil per gallon that each mixing ratio requires. Expect that yours will be between 32 gas to1 oil and 50 to 1. 32:1 and 50:1 are most popular.
Ratio GAS:OIL UNITED STATES OIL per 1 U.S. GALLON Gasoline
(128 oz.)
*INTERNATIONAL OIL per 1 IMPERIAL GALLON Gasoline
(160 oz.)
*INTERNATIONAL OIL per 1 LITER Gasoline
(metric)
32:1 4 oz. 5 oz. 31.25 mL 40:1 3.2 oz. 4 oz. 25 mL 50:1 2.6 oz. 3.2 oz. 20 mL
Jan 01, 2015 | Weedeater Garden
Whats the best premix gas to use on a Husquarna 125B hand held Blower
The best mix to use is what's recommended in the manual but in most cases blowers use a 50:1 mix. The difference from 40:1 to 50:1 is negligible but you have to use what the motor is built for. Too much oil causes a loss of power because the gas won't burn efficiently. Too little oil and you risk damaging your piston or cylinder.
Feb 22, 2012 | Husqvarna Hand Held Blower 125 B Grass...
Gas and oil mixed in 4 cycle backpack leaf blower
If it is a 4 cycle blower, you do not mix oil with the fuel....It takes straight Gas. there is an oil cap to put engine oil in crankcase, this only usually takes 2,3,4 oz. of oil. Sounds like your Spark Plug probably fouled out from having oil mixed in your gas. I would recomend changing your Spark Plug and put some Fresh GAS only in the blower, dump the old stuff out !!! You should be on your way Blowing in No Time !
Nov 27, 2011 | Troy-Bilt 32cc 4Cycle Backpack Blower
What type of oil do i add to the gas for a ry30240 weedeater?
Any type of 2-cycle engine oil will work fine. Just make sure it is 2-CYCLE engine oil, and not motor oil! Also,mix it at a ratio of about 1 part oil, to 40 parts Gas. Hint: The Ryobi equipment seems to like the 87 octane better than the low grade fuel, especially in high temps! Good luck!
Sep 30, 2011 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
What kind of oil do i use to mix with gas for my Poulan gas trimmer. Can i use WD30 motor oil or does it have to specifically say its for 2stroke engines? the ratio on the trimmer says 40:1 so i assume...
DO NOT USE MOTOR OIL!!!
There is a special 2-stroke engine oil mix that you can purchase at various stores that have outdoor equipment or you can also find mix at Walmart. There are instructions for proper mixing on the bottle.
Remember not to put 2-stroke mixed fuel in your lawn mower unless it is also 2-stroke (rare). And the converse is also true, do not put your 4-stroke lawn mower fuel in your 2-stroke weed eater.
If this is really helpful, please rate.
Jul 10, 2011 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
What is the gas oil mixture for this product
If this is a 4 cycle engine you do not mix the gas and oil. The engine oil is in the crankcase just like your car. Hope this helps, Happy New Year.
Dec 29, 2010 | Craftsman 4 Cycle Blower/Vac
I do not know the proper gas-oil mix for a sears craftsman backpack 2 cycle leaf blower; i am using 1 gallon of gas; how much of the oil do i put into it? thanks
Craftsman engines typicallty run a 40:1 fuel ratio mix. That is 3.2oz./gal. I suggest synthetic oil It helps the engine to run cooler with less friction/stress. If you make the mix a little richer; say 3.5 to 4 oz./gall. it will assist the engine if it is tuned to the "lean" side (that is with more air/less fuel). The extra oil will not hurt or foul your spark plug.
Nov 21, 2010 | Garden
Need to know oil to gas mix ratio for Craftsman 32cc, 360 cfm, 170 mph blower vac? Can someone provide ratio?
40:1 is the standard mix. Go buy one of the little containers ( 3.2 ounces) of 2-cycle oil and mix it with a gallon of gas in an approved container (like a gas can). How you mix it is, pour some gas in the container...about 1/4 of the gallon, then pour in the oil, mix well, by shaking the can then add the remaining gasoline and PRESTO, you have a 40:1 mix!
Nov 08, 2009 | Garden
What type of oil goes in the Ryobi 08570 Blower? What is the oil gas mix ratio?
You need 2 stroke motor oil or chain saw oil.Mix it according to the lable to make up 50:1 oil/gas mix.
Nov 07, 2009 | Ryobi Backpack Blower 25.4cc
Cord won't pull out
Hi Shaun77b,
Regretfully if you didn't use a gas/oil mix the motor is probably seized. The internal parts on a 2 cycle motor are lubricated by the oil in the gas. It may keep running without oil but once it shuts off- its done.
Sorry, Phil
Dec 27, 2008 | Husqvarna Forest & Garden 125bt Backpack...
Craftsman 4 Cycle Blower/Vac Logo
51 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dwain Pippen
Jim Parker
Jim Parker
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
