Decurler sensor error on xerox 4595 - Office Equipment & Supplies
Error 93-311 xerox 4595
That error signified a failed dispense motor. First try reset NVM 762-032 to 0. If that doesn't work replace the dispense motor.
Part number 127K38220.
Jan 30, 2016 | Xerox Office Equipment & Supplies
Sharp mx1204 error f1-90 what is causing the error?
Hello Awelani,
The error code of F1-90 means the following;
Communication trouble between the decurler and the downstream units. OR possibly;
Communication trouble between the decurler and the units connected to the downstream of the decurler.
CAUSE; Noise on the communication line, control PWB trouble, disconnection of connector or harness.
REMEDY; Turn OFF/ON the power. Check connection of the connector between the decurler unit and the downstream units of the decurler. Replace the control PWB of the downstream units of the decurler.
A complete error code list can be found here; Error Codes Sharp MXM1204 page 11 Use the < and > to go through the complete list.
Good Luck!
Rich Lilja
Feb 19, 2015 | Sharp Office Equipment & Supplies
Xerox 4595 error code 062-380
Platen AOC Failure.
Power off completely and then power back on.
If the problem persists please Call for Service.
Jul 12, 2014 | Xerox CopyCentre C128 Black and White...
Xerox 4110 fault code 077-330
ERROR CODE: 077-330, Front Door/Panel - DAMAGED
Apr 25, 2013 | Xerox 4110 4127 4112 4590 4595 Drum...
Error 093-311
Hi
How to delete bug 093-311 in the Xerox 4112
br
Oct 06, 2012 | Xerox 4110 4127 4112 4590 4595 Drum...
Fault 012-332. how can I reset or fix this error code?
The Black Idler Pulley above the Decurler Drive Motor can wear out causing the Decurler Motor to intermittantly stall. Replace the old style pulley with the new style pulley kit, (604K46320). There is also a clutch that wears out that can cause that code. It has to do with the decurler. It also can be the gear mesh in the decurler .
Dec 31, 2009 | Xerox DocuColor 240 All-In-One Laser...
44 people viewed this question
jasbo
jasbo
