Question about GE Monogram ZDP48L4GWSS Gas Kitchen Range
Low temp in electric oven
Low temp in small oven. there are two screws behind the knob. which do I use and turn left or right to raise temp
  • dustybob1937 Jan 24, 2009
    I know that. which way l or to raise temp?
    President:
  • 1,214 Answers
Right tighty, lefty loosey
Posted on Jan 24, 2009
  • Mark Egan Jan 24, 2009
    My bad, I typed before I thought.
    Those two screws mount the control. The temp adjustment is down inside the stem of the control, once you remove the knob.
    The direction you rotate is best figured out with a thermometer inside the oven.
    Let the oven reach the temperature it's going to get, note temperature. Turn control inside stem 1/2 turn, wait about 10 minutes, and read temperature. Note if you turned right or left.
    Next correlate the turn direction and amount with where you want to the temperature to be.
    All of these controls are a little different, so to give you a specific is difficult.
How do you adjust the oven thermostat part# 411506
Look for a small screw in the center of the shaft that holds the oven knob. Use a flashlight to see it. A very small turn on this screw will change the temp 25 degrees so turn in small amounts and test. 1/2 turn at a time or smaller.
Tom
Aug 10, 2010 | Vulcan E60FL Electric Kitchen Range
Tip
Electric stove oven burning food?
if your oven is over cooking and or burning everything ,more than likely its your temp.thermostat it is not that hard to replace,before you do that go down to your nearest home depot or lowes or appliance store and get a portable thermostat they usually crome in color,take and set your oven to a temp like 350 for example put your new t.stat inside your oven and keep checkin to make sure it dont go above 350 if it does then you will need to replace the thermostat.to get to it first pull the t.stat knob off remember its the one you set the oven temp.with unplug range pull stove out away from wall so you can get behind it,you will have to take off all the screws that hold your cover panel on the screws are usually 5/16 nut driver.take the two screws off the front right behind where the temp knob is,mark the wires so that you do not forget where they go,, you dont want to hook them up wrong.it can cause alot more problems if they are put on wrong ok now,open oven door and you will see on the inside of the oven a copper wire that goes from the temp.control to inside your ovenall you have to do is take the wire and feed it through the back pull it out and take to your nearest appliance store make sure you write the model number and brand of the stove pick up the new one and put new one back on, put panel back on plug range in,and set temp back to 350 put the portable thermometer back inside oven should be good to start baking again
on Mar 09, 2010 | Kitchen Ranges
Doesn't get as hot as it should
the range has two thermostats one for each oven located under the oven knobs. put a meat thermometer in the oven and adjust the thermostat screw with a small flat screwdriver untill the oven turns off at the correct knob temp.
registered on the thermometer.
then adjust the knob screw on the back of the knob to match that temp setting.
clockwise is hotter counterclockwise is cooler
Apr 21, 2009 | Ovens
Maytag oven needs temp calibration
Take your temp knob off and look in the center of the stem and you should find a small set screw. Using a small precision screwdriver, turn the screw until you see the light come on. (You won't have to turn it far.) Turn it a little at a time, maybe a 1/16 of a turn. Leave your thermometer in the oven with the door closed and at or near the temp probe that is in the oven. This way, you are getting a true reading.
Dec 30, 2008 | Maytag CWE4800A Electric Single Oven
Stoves 900DFa oven overcooking food
Sounds like the temperature control is bad. If it's digital you'll probably have to replace the circuit board. if it's a control knob, it's the mechanism behind the knob.
Jul 02, 2017 | Stoves 900DFa Dual Fuel (Electric and Gas)...
Hotpoint oven/range
Is it a gas or electric if it is gas take knob off usally in front where it says 150 degrees and up and if you look down the shaft you will see a little screw turn it counter clockwise to turn oven down if it is electric take knob off where it says 150 /250/etc... and look behind the knob in your hand it has 2 screws to adjust the oven temp.
Aug 25, 2008 | Kitchen Ranges
Stove to hot burns everything
This is a simple fix as long as the oven is heating properly and the only problem is that the temp seems higher than what the temperature control knob indicates...
Purchase an inexpensive oven thermometer from the hardware store and place it in the center of the oven. Set the temperature control knob to 350 degrees F.
Check the temperature indicated on the thermometer in the oven after 20 minutes. If it's not within 5 degrees of 350, you'll need to adjust the oven's temperature control.
Turn the oven off.
Pull off the temperature control knob. You can usually pull it off by hand, pry it off with a thin screwdriver, or slide a piece of cord up behind it and pull.
Note which kind of temperature control knob you have. There are two types: The first has a screw in the shaft of the knob; the second has an adjustment dial on the back of the knob.
Adjust the temperature with the first type by turning the screw in the shaft with a screwdriver. Turn it clockwise to lower the temperature; turn it counterclockwise to raise the temperature. Turn the screw just a little bit in the appropriate direction.
Adjust the temperature with the second type of knob by turning the dial on the back of the knob. (This dial is held in place with a screw or a clip that will need to be removed.) Raise the temperature setting by turning the dial counterclockwise; lower it by turning the dial clockwise. The notches are typically in 5 or 10-degree increments.
Test the oven temperature again.
Repeat until you're in the right temperature range.
Good Luck!
Mar 20, 2008 | Kitchen Ranges
Calibration
Electric ovens are calibrated behind the temp knob. Pull the knob straight off of the shaft and look at the back of the knob. There should be a metal slide with a scale and a little set screw. Loosen the screw and move the slide in the direction indicated for your needs.
Mar 06, 2008 | Viking VDSC365-6B Dual Fuel (Electric and...
Tappan TGF336ASD stove Calibration of the oven
does it have a knob in front or is it a panel to operate bake broil ? if it has a oven knob take it off and look in the back of the knob you adjust it there if it is electric if it is gas you need to use a small screw driver in the stem where the knob goes on and turn a little screw in there to ajust temperture turn clockwize to adjust temp up
Aug 13, 2007 | Tappan TGFS_63 Gas Kitchen Range
GE Monogram ZDP48L4GWSS Gas Kitchen Range Logo
87 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
