Question about GE PSF26NGN Side by Side Refrigerator
My GE PSF26NGN has stopped cooling. Compreesor not running, but inner and outer fans running when plugged in. Does compressor have a thermal overload reset ? Where can I find a wiring/electrical component schematic. There was no ice build up on coils or in cabinet. Could it be something on the board ?
  • Steven Melton Jan 17, 2013
    Unplugged unit for a few hours.Used compressed air to clean dust from coils in the back. Compressor started running when plugged in again and now 24 hours later is operating properly.I assume overload reset or board did, either way it works. I believe it shut down due to dirty air vent and coils.
    New Friend:
  • 15 Answers
IF IT DOES IT AGAIN REPLACE PART # WR55X10942 MAIN BOARD
Posted on Jan 18, 2013
SOURCE: ge model gsh25jfrfww not cooling just clicking
Replace the main board on the back i got the part for $130 at a wholesale parts store
Posted on Mar 06, 2009
  • 10 Answers
SOURCE: Compressor won't turn on. Lights turn on. Won't cool anymore.
Make sure that the defrost timer is not stuck in defrost mode also the compress may be stuck. you can purchase a compressor booster kit from your local appliance parts store for about $15.00.
Posted on Mar 07, 2009
  • 146 Answers
SOURCE: Evap fan stops running/low cooling, Unplug Frig Evap fan runs
Is there anything obstructing the fan area, ice build up ? It is normal for your freezer to get warm if evap fan is not working, it is essential for it to work :) A defrost cycle should kick on a timer or as needed (adaptive) and there should not be excessive frost buildup that it blocks your evap fan. I would have suggested you unplug your refrigerator for about 10 minutes and see if that resets your control board - if not, then you will need service - either replacing motor assembly or a faulty control board.
Posted on Aug 22, 2009
Testimonial: "Thanks for your help. The control board was faulty. This is what I suspected but I wanted a second opinion before buying the board. "
arikrom
  • 528 Answers
SOURCE: PDS18SBMRBS model GE Profile fridge. The fan
the heater unit might be weak and usualy it is a hlogen light that need to be replace , so the defrost will be better
Posted on Jan 02, 2010
Sea Breeze
  • 4655 Answers
SOURCE: GE profile TFHW22R side-by-side fridge compressor issue
Most times replacing the start relay part=> WR07X1001 start capacitor=> WR62X80 and overload=> WR8X97 will resolve the problem. Click here to downlod the Service Manual=>PROFILE ARTICA SERVICE MANUAL CLICK HERE and go to this page to use he Tech Sheet> GE Artica Profile Technical Information If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breeze
Posted on Jan 26, 2010
Testimonial: "Great response time. Very helpful too."
I have an Amana heater/airconditioner (Prestige I think) that is not cooling. The outside compressor fan was not spinning, so i I changed the capacitor on the unit. It now spins, yet vent air not cold
If that fan stopped your compressor overheated, shut off on thermal overload. Carefully cool compressor with water hose and restart. If the big copper is cold ,small copper warm, compressor is running. Check capacitor on compressor
Jun 06, 2016 | Amana Heating & Cooling
My vinotemp vt60 starts cooling then stops
I sounds to me like the compressor is overheating. There is an overload on the compressor itself. Follow the wires where they go into the compressor. There will be a black wire going from the power cord to the overload. These can be purchased at appliance parts stores. Make sure there is no dirt build up on condenser coils or a kink in the tubing.
Jul 30, 2014 | VinoTemp (VT60GNV) Wine Cooler
I have a Samsung rs21!!! it wont cool in either compartment. when I plug it in the compressor fan does a quarter turn then stops. the compressor runs for about 30 seconds then cuts out? any ideas plea
most likely the start relay on the compressor that changes from start windings to run windings. the compressor will run for about 30 seconds on start windings then click out on internal thermal overload.
this can be confirmed by turning it on and letting it do the 30 second run then when it stops just wait and see if it cuts in and tries to run again (usually takes about 5 min) the second time it cuts in it wil most likely not run for as long (usually about 10 seconds). if this is what it does get a new compressor start/run relay.
as for the fan flick it with your finger and see if it spins freely.
Jun 05, 2014 | Samsung RSA1SHPN American Platinum Inox...
I have a trane XR12 Heat Pump. The cooling fan on the outdoor unit does not run nor does the compressor. The fan motor heats up and hums. I am guessing that the problem is the start capacitor on the fan...
Hello Rich,NO you have a dual capasitor that runs both fan & compressor motors.Shut it down and let it cool off.You need the uf rate numbers & the volt rating of the existing cap (printed on the side)to get EXACT replacement.The wires plug in to the top termanls C, HERM &FAN.Worth fixing good luck.
Jul 29, 2010 | Heating & Cooling
Will not cool fan runs though
It sounds as if the compressor has gone out. To see if it is out you need to pull the fridge out to access the lower part of the fridge. There will be a black oval tub looking device in back of a fan. Plug the unit in and see if the compressor kicks in you will hear a humming noise from this device. You can put your hand on it to see if it is vibrating but be careful if it has gone into thermal overload it will be very hot. You may want to unplug the fridge for approx 4 hours or so before attempting to check this since if it is in thermal overload it will not start so the time it is unplugged it will cool down and start. Once you plug it back in check to see if the compressor is humming by listening to it or feeling it. It may run fine from this point out or it may go back into thermal overload in which case the compressor has gone out.
Hope for the best good luck.
Dave
Feb 17, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
GE refridgerator won't cool
First of all check and see if the compressor is running and if not is it very hot to the touch. If the compressor is not running but hot then the compressor is either locked up or is cycling on its internal thermal overload. If this is the case then either the condenser fan motor is not running and/or the condenser coil is very dirty. If the condenser coil is dirty you need to blow it out with compressed air(watch out for all the blowing dust). If the compressor has been cycling alot on its internal thermal it will eventually lock up permanently and you will need a new compressor. I hope I was of some assistance to you!
Nov 12, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE side by side TFX22RLC
If the condenser fan is not running while the compressor is running could damage the compressors overload. Yes it's a serious problem if not repaired soon. (Unplug until repaired.) This can cause a weakened internal overload inside the compressor. Thanks, Sea Breeze
Sep 21, 2009 | Refrigerators
I got kalvinator frostfree model KNT283GY. After defrost action is free. Timer gives voltage to compressor. The compressor will not start . there is power on compressor ,fan works but compressor will not...
Condenser fan motor may be running a little slower therefore causing a warmer compressor. Also the refrigerator must be plugged into a dedicated outlet wired 12/3 with 20 amp breaker.
With the compressor to hot the thermal overload will open therefore the compressor will not run until it cools and overload resets.
Apr 27, 2009 | Hoover HCA331FFK
Electrical unit attached to compressor keeps making a spark(clicking sound) Fridge & freezer slowly stopped cooling during the day and is now down to 0 cool.
Overload thermal protector is tripping out. When a mechanical refrigerator is unplugged it should remain unplugged for 5-10 minutes to allow the refrigerant pressure to equalize. If you unplug it and then plug it right back in the overload will open on and off until the pressure in the system balance to the point where the compressor will start.
This protector is a two way protector. It opens on Over current and or over temperature. If a condenser is plugged with dust , hair or what ever the fan which circulates the air for cooling the system will not move enough air to keep the compressor with-in operating temperature range. The thermal protector will open.
May 03, 2008 | Refrigerators
KitchenAid fridg compressor heating up
If the compressor is very hot, it sounds like it may be locked up. Is there an external fan next to it that is not running. this will cause the comp. to overheat, like a dirty coil, which it sounds like you checked out. There is a thermal overload on the compressor. Its underneath the little plastic cover that the wires go to. It protects the compressor from a meltdown. It also has a relay in there. If you have an amp meter you can check this by waiting for it to cool off and clamp it on one of the compressor wires.when it clicks on, If the amps soar over 20 very quickly, and then stops. Its a locked compressor and the thermal overload is cutting it out. If you don't have a volt/amp meter, then try replacing the relay as its pretty cheap. But I would bet on the comp. as long as the fan is running.
Jan 16, 2008 | KitchenAid Superba Architect KSCS25INSS...
GE PSF26NGN Side by Side Refrigerator Logo
74 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
