Question about Kenmore 24032\24036 Top Load Washer
Kenmore 70 Series stopped after wash cycle
Washer stopped between wash and rinse, making whining noise and electrical burning smell. Was able to get it to drain in spin cycle, but started noise and burning again. No visible smoke. Any suggestions. The lid switch was replaced a couple of years ago.
  • 1 more comment
  • smaspero127 Jan 25, 2009
    It was spinning while draining. I had to move the knob to spin. The noise starts while agitating and it won't go past wash on the cycle. The electrical burn smell is coming from the top, so i was thinking timer or lid switch going bad. Lid switch is working at the moment.
  • Thomas Malailua
    Thomas Malailua May 11, 2010
    you can expose you timer and smell in side.that what i did as a repairman.if burn oder it i might open it up.if no odor i would look some where else.lid switches dont usualy burn.if stuck at end of wash and wont advance i may have checked voltage at the timer motor if reciving voltage and not advancing then timer is bad.
  • Thomas Malailua
    so it will drain, but wont spin or agitate?but makes the whining noise when it should be washing or spinning
  • 15,935 Answers
It appears your timer/controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
Kenmore 70 series
Does it do it when the spin stops?
Nov 29, 2012 | Kenmore 24852 Top Load Washer
Washer is making different noises during wash and rinse cycle
could have been the motor,you might also smell like a shellac kind of smell,when the motor overheats,also how old is it and what's the brand name and model number.you can feel the motor,if it's hot then it is cutting out for some reason.
Dec 20, 2017 | Washing Machines
My kenmore 70 series top loading machine will not drain and go into the rinse cycle what part needs to be replaced?
CHECK THE LID SWITCH, AND CHECK THE TIMER FOR A BURNED SMELL. IF SMELL PROBABLY TIMER. SOME WASHERS WOULD NOT GO INTO SPIN WITHOUT LID CLOSED, BUT WOULD AGITATE.
Mar 10, 2010 | Kenmore 22422 Top Load Washer
Kenmore series 70 washer leaks during rinse?
the was exhaust hose is either plugged or cracked. also check the drain it is put into as this sometimes will be puleeged with fabric from the clothes you wash
Jul 10, 2009 | Kenmore 22422 Top Load Washer
Kenmore 70 series slow agitator
You have burned the clutch this must be replaced
Jun 09, 2009 | Kenmore 15864/15862 Top Load Washer
My kenmore top loading washer 70 series wont go into spin cycle
check the lid switch some washers will fill and was with the lid open but will not spin, if the lid is closed manually actuate the lid switch or bypass it electrically, or replace it.
Apr 07, 2009 | Kenmore 22422 Top Load Washer
Maytag Washer whines during rinse belts burn
that friend is about the best possibility I can think of. This site has all your parts for the washer you have www.repairclinic.com
Mar 21, 2009 | Maytag LSE7806A Top Load Stacked...
Kenmore 70 series Washer will not go to spin cycle
Check the lid switch. That is a VERY common problem on these models.
Dec 13, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
My series 600 kenmore will not wash all others work
if washer has speed switch could be it but if not lean washer back and look for loose connection on motor first if cks ok suspect timer wash contacts bad
Dec 07, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
156 people viewed this question
Sal De
fordexpert
Robert Rankin
