Question about Maytag EPIC MFW9700S Front Load Washer
Maytag MFW9600S does not spin - Maytag EPIC MFW9700S Front Load Washer
  • Maytag Master
  • 17,130 Answers
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Posted on Jan 17, 2013
Control lock stays on
Try holding for 3-5 seconds should unlock controls.
Jan 20, 2014 | Maytag EPIC MFW9600S
I have a problem with a f02 error
The washer is not finishing the cicle and is showing error f02
Aug 03, 2013 | Maytag EPIC MFW9600S
Suds and F02 Error codes.
You did all the right thing, now it could be the control panel
Mar 29, 2013 | Maytag EPIC MFW9600S
My epic washer will not spin. Does this have a belt???
Yes remove top and look down the back . You will see the pulley and the belt should go from there to the motor(flat serpentine type belt).
Nov 18, 2010 | Maytag EPIC MFW9600S
EPIC MFW9600S F02 Error Code before cycle ends I read on here to remove the front panel and check for blockage but I haven't a clue how to take the front panel off?? I don't see the 3 screws mentioned.....
The 3 screws come at the toe panel in front of the machine. You have to prop up the machine to have access to the screws, they come just underneath the panel. Its kinda of fashionable to place them there i guess, but that's it. On unscrewing the panel slides down & towards you. The rest of the matter you know by the posts.
Jun 17, 2010 | Maytag EPIC MFW9600S
F o2 error won't drain
if this wont drain then the drain pump is either seized or faulty if you have no power their then you have a faulty control board
Aug 21, 2009 | Maytag EPIC MFW9600S
Error f-01 maytag epic z
HI. this F-1 error concerns the actual Electronic control board. it is malfunctioning at this point. this board cannot be repaired and, you will need to replace the entire control in this case. it has failed.
The unit will be inoperable without a functioning electronic control module. replace it asap if possible.
Jun 07, 2009 | Maytag EPIC MFW9600S
Maytag epic mfw9600s
press and hold the signal for 10 seconds.
bit late huh.
Oct 22, 2007 | Maytag EPIC MFW9600S
Maytag EPIC MFW9700S Front Load Washer Logo
373 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
