Question about HP Mini 1000 Netbook
Windows could no connect to any of your preferred wireless networks. Windows will keep trying to connect. To see a list of all networks, including others you can connect to, click this message.
  • 3 Answers
You will need to enter a password key to access the network if it is secured. If it is your network and you have the key entered you might try rebooting the router. If those don't work, you will need to supply more information here.
Posted on Feb 02, 2013
5 Suggested Answers
SOURCE: Cannot connect to wireless internet
First, do you have a wireless router button that enables or disables wireless internet? If so than it might have got accidently turned off. push it and see what pops up on screen. If it says enabled than it was turned of try connecting to internet again. If it says disabled than push again until it says enabled clearly that wasn't the problem. Next try going down to the two computers (right hand bottom corner) then double click them. This will bring up a wireless networks available, try refreshing this page. After refreshed if no networks are available than it may have to do with your internet provider. Try calling them to get a better detailed explanation.
Posted on Jul 19, 2010
SOURCE: sporadic internet wireless connection
Have you tried putting the computer in to safe mode. I had the same problem with 3 other laptops but all the same model. I think it has something to do with an update. I put it into safe mode and rolled back the driver and its working fine
Posted on Feb 17, 2009
  • 7 Answers
SOURCE: intel pro wireless 2200bg Problems on HP dv4000
go to intell.com download most recient driver
ihave had the same problem with 5 other laptops with the same card in the past 2 weeks
Posted on Apr 11, 2009
  • 22 Answers
SOURCE: i have a connection problem
have you tried powering off you modem and router, then re-powering them after 30 seconds? peace, abz
Posted on Mar 30, 2011
Listing of preferred wireless network for DELL 1510
right click on on status bar and then property and then customize and then you will see wireless icon and then make it visible all the time.
perhaps you did turn off windows zero configuration. to do that right click my computer then manage the services , and then in service start windows zero configuration
Mar 10, 2012 | Dell Vostro 1510 Notebook
Hi i am using the pc sony vaio i have the problem on wireless adabter it was in desable mode and difficutl to active it ,while i am useing the bottom in front of pc on and off of wirless adabtor but i i on...
In Vista, you can either go to control panel, device manager and right click on it and click "eneble"
or go to control panel > network sharing and set up wireless network connection
or
go to task manager (press and hold ctrl . alt . delete for a couple of seconds), until task manager comes up. Then click on the services tab, scroll down till you see "Plug Play or Plug and Play and make sure it's running. If it's not, right click on it then click "enable"
In XP
Open Network Connections
Right-click Wireless Network Connection, and then click Properties.
On the Wireless Networks tab, do one of the following: •
To enable automatic wireless network configuration, select the Use Windows to configure my wireless network settings check box. This check box is selected by default. For information about what happens when you enable automatic wireless network configuration, see Notes.
To disable automatic wireless network configuration, clear the Use Windows to configure my wireless network settings check box.
To connect to an existing wireless network, do one of the following:
Access point (infrastructure)
To connect to an existing access point (infrastructure) network, under Available networks, click the network name, and then click Configure.
In Wireless Network Properties, specify the wireless network key (Wired Equivalent Privacy) settings, or, if the network key is automatically provided for you (for example, the key is stored on the wireless network adapter given to you by your administrator), select the The key is provided for me automatically check box. If you are unsure about whether a network key is needed or which settings you need to enter, contact your network administrator or the wireless network adapter manufacturer.
Important
If a network does not broadcast its network name, it will not appear under Available networks. To connect to an access point (infrastructure) network that you know is available but that does not appear under Available networks, under Preferred networks, click Add. In Wireless Network Properties, specify the network name (Service Set Identifier) and, if needed, the wireless network key settings.
Computer-to-computer (ad hoc)
To connect to an existing computer-to-computer (ad hoc) network, under Available networks, click the network name, and then click Configure.
If you want to connect to a computer-to-computer (ad hoc) network and both computer-to-computer and access point (infrastructure) networks are within range of your computer, click Advanced, and then click Computer-to-computer (ad hoc) networks only.
To configure a new wireless network connection, click Add, and then do the following: •
If the network connection that you are configuring is to a computer-to-computer (ad hoc) network, select the This is a computer-to-computer (ad hoc) network; wireless access points are not used check box.
To change the order in which connection attempts to preferred networks are made, under Preferred networks, click the wireless network that you want to move to a new position on the list, and then click Move up or Move down.
To change the wireless network connection settings for a network that is listed in Preferred networks, click the wireless network for which you want to change settings, click Properties, and then change the settings as needed.
To remove a wireless network from the list of preferred networks, under Preferred networks, click the wireless network that you want to remove, and then click Remove.
To update the list of available networks that are within range of your computer, click Refresh.
To automatically connect to available networks that do not appear in the Preferred networks list, click Advanced, and then select the Automatically connect to non-preferred networks check box.
To open Network Connections, click Start, click Control Panel, click Network and Internet Connections, and then click Network Connections.
When you enable automatic wireless network configuration, you can connect to an existing wireless network, change wireless network connection settings, configure a new wireless network connection, and specify preferred wireless networks. You will be notified when new wireless networks are available. After you select a wireless network, your wireless network adapter will be automatically configured to match the settings of that network, and a network connection attempt will be made.
To configure settings on the Wireless Networks tab, you must be logged on as an administrator, and you must use a wireless network adapter that supports the Wireless Zero Configuration service. If you are unsure whether your wireless network adapter supports the Wireless Zero Configuration service, contact your network administrator or the wireless network adapter manufacturer. For more information about automatic wireless network configuration, see Related Topics.
If you are using third-party wireless networking software, clear the Use Windows to configure my wireless network settings check box.
If you are unable to connect to an existing wireless network and the name of the network that you want to connect to appears under the Preferred networks list, click the preferred network name, and then click Properties. In Wireless Network Properties, review the settings to ensure that they are correct. If you are unsure whether the settings are correct, contact your network administrator or the wireless network adapter manufacturer.
If the Preferred networks list includes both access point (infrastructure) and computer-to-computer (ad hoc) networks, you cannot move a computer-to-computer network to a position in the list that is higher than the position of an access point network.
To provide enhanced security for 802.11 wireless networks and for wired Ethernet networks, IEEE 802.1x authentication is enabled by default. For more information about how to set up 802.1x authentication.
Hope this helps
Dec 12, 2010 | HP Broadcom NetXtreme Network Adapter
My computer died we redid widows xp disk and it came back now i dont have wireless how do i get it back
Hi, you will need to reinstall the wireless card drivers, if this came with wireless as standard you should be able to download the drivers from the manufacturers support website, if it was added later on then it should have came with an install disc with the drivers on it.
Hope this helps
John
Dec 02, 2010 | Computers & Internet
I can not figure out how to get the computer to make a wireless connection.
Add the Home SSID to the Preferred Network List After you set the SSID on your home gateway, you may need to add it to your preferred network list if Windows XP Wireless Auto Configuration is enabled. (Although automatic configuration is nice to have, your IT department may have disabled it on your laptop in order to meet their needs. If they have, you'll need to use the tool provided by your laptop or wireless manufacturer to manually configure wireless settings.) To manually add your home wireless network to the list of preferred networks when Wireless Auto Configuration is enabled, follow these steps:
• In Control Panel, click Network and Internet Connections, and then click Network Connections.
• Right-click the Wireless Network Connection, and then click Properties.
• On the Wireless Networks tab, shown in Figure 3, click Add.
Figure 3
• In the Wireless network properties dialog box, shown in Figure 4, enter the SSID you configured for your wireless gateway (ExampleHome_g in this example.)
Figure 4
Note: Figure 4 assumes you've added the Windows WPA Client Update. If you haven't downloaded and installed it, you probably should. For more on the WPA Client Update, see Overview of the WPA Wireless Security Update in Window XP.
• Fill in the rest of the fields, including the necessary authentication and encryption information based on the configuration of your wireless gateway.
• Click OK and your home network will be added to the list of preferred networks.
Now, whenever you're at home, your work laptop should automatically see your home wireless network and connect to it.
Jul 05, 2010 | Acer Aspire 5100 Notebook
One of our computers keeps saying it cant authenticate the certificate, what should i do?
I think you are trying to connect to the wireless network on a windows XP computer. The security on the wireless network must be WEP.
In this case you can remove the list of preferred networks on the computer.
Add the network manually.
If this is the only wireless computer then change the wireless settings of the router.
Click here for more information about how to connect to the wireless network
Feb 23, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Windows was unable to find certificate to log on to the network
This type of error message appear when we are trying to connect to the wireless network.
For Windows(xp) perform the following steps:-
a)click on start menu and then go to control panel and then open network connections from there.
b)Under network connections an option for wireless connection exist , right click on that option and then click on properties.
c)Under wireless network connection properties there are three tabs general , wireless network and advanced.
d)Left click on wireless network tab and check the box which says use windows to configure my wireless setting's and click OK at the bottom.
e)Then , Right click again on wireless network connection and click properties and then again click on wireless network tab.
f)At the bottom of the wireless network tab you will have preferred networks and in that small box yo will have list of networks and therefore delete all of them from there including the one you are trying to connect to.
g)On the right hand side of preferred networks you will have ADD click on that option and enter the details of your network manually.
SSID(name of the network)
Network Authentication:-Open if the security is WEP else WPA-Personal.
Encryption:-WEP for wep security TKIP/AES for WPA-PSK.
Network key/Confirm network key:-is the wep key or wpa-psk password.
Untick the box at the bottom that says the key is provided to me automatically.
Click OK at the bottom and close the properties window.
h)Then , Right click again on wireless network connection and then left click on view available wireless network.
i)List of available networks will be there , select the network you use and try connecting to it , it will get connected automatically.
Nov 19, 2009 | Computers & Internet
Not able to type in network key for wireless
1) If you are using the Windows Default Wireless Network Connection. Open the windows where you you will see a list of all wi-fi connections near by your location. On the left panel(Related Tasks) click on "Change Advance Settings" >> Wireless Network Connection Properties >> Click "Wireless Network" Tab >> from the Preferred Networks: list, remove the wi-fi connection you are trying to connect. Once your W-Fi connection settings are removed. You can either add it manually clicking on the Add button and entering all informaiton manually, or from the wi-fi network list click the network name it will ask you to enter the netowkr key....
OR
2) if you are using any other Wi-Fi connection application, like the Intel's, follow the same procedure. delete the settings and try connecting again.
Feb 11, 2009 | IBM ThinkPad T40 2373 Notebook
3COM Office Connect 3CRUSB10075
are you using windows xp? vista? 98?
I'll guess at xp.(and that you're using the windows software to connect)
Double click the wireless connection icon in the bottom right (the one that flickered when you're online.
Click 'view wireless connections'
click 'change the order of preferred networks'
Now select everything on the list and delete it apart from your own.
Now click 'advanced'
make sure 'automatically connect to non-prefurred networks' is NOT ticked.
Click close, then ok.
You should be ok now.
Regards
Tony
Feb 28, 2008 | 3Com (3CRUSB10075) 802.11g/b Wireless...
HP Mini 1000 Netbook Logo
27 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
