Question about Hitachi RAS-09UH Air Conditioner
Inverter unit fan and compressor wont run.
Light flashes 4 times outside unit fan runs for a short while then stops. Cold air not coming out of interior unit. Is it likely to be an expensive repair?
  • Brawlio Jan 26, 2009
    First: Actually the main control board is the on who control the rotation of the fan motor and the compress
    Problem Solver:
  • 5 Answers
Sir/Maam,, Just Call or visit directly to your nearest service center, Thanx......
Posted on Jan 26, 2009
Compressor stop working
have a technician check the operation of the start/ run capacitor on the outside unit.
Apr 30, 2015 | Inverter Heating & Cooling
Fan on unit comes on but no cold air comes from the registers
is the outside compressor running or just the condensor fan.
Jun 18, 2014 | Goodman Heating & Cooling
Green light flashing on wall unit - no cold air?
Compressor should switch on after 3 minutes.And if it does and still no cold air coming out of the inverter.Then unit needs to be gased.
Jan 06, 2014 | Heating & Cooling
AC was running all this summer, then suddenly stopped working. The fan runs on auto and manual but the outside unit does not come on.
The indoor fan is running . but the compressor and outdoor fan does not come on . check fuses there should be a disconnect on the outside by the unit it may have fuses. one could be blown. if the unit has a curcuit board see if any light are falshing. let me know
Jul 23, 2011 | Weather King 10AJA6001AH Air Conditioner
Carrier outside Unit will not power on. Every 45 sec's to a 1min it will make a humming sounds like its trying to power on but wont. The fan unit inside will come on but will not disburse cold air
You probably have a bad run capacitor in your outside unit. You will need to cal a service tech to test and replace it, until then turn your system off until it is repaired. Continuing to try to run it will over heat the compressor and fan motor and cause them damage.
Jun 16, 2011 | Carrier Heating & Cooling
My air conditioner has stop working its blowing air inside but the fan is not spinning outside .....
If the fan is not running is the compressor not running also...if neither is running the possible reasons are 1..no power to outside unit...2..bad contactor on outside unit.is this buzzing if it is this indicates no power...3 bad capacitor,do both compressor and fan humm then quit humming and hum some more...4 high pressure switch has shut unit down because fan wasnt running if compressor was running but not fan....if your unit has this there will be a manual reset button where the lines come out of unit...if compressor was running and fan was not...1 bad fan...2 bad capacitor.. if you do not have any electrical knowhow i would recommend calling a hvac tech to come and fix unit...Thanks
Feb 01, 2011 | Samsung AS18A6RB Air Conditioner
My a/c unit does comes on but it only warm air not
Make sure the outside unit is running, compressor and fan. Sometimes it is hard to hear the compressor over the fan. If the outside unit is not working check circuit breakers first. Set thermostat to call for a/c and make sure the contactor in the outside unit pulls in. If it does check capacitor for whatever is not running. If everything seems to be running fine hold your hand above the fan outside. The air coming from it should be hotter than the outdoor air. If it isn't get the refrigerant charge checked.
Jun 29, 2010 | Goodman GPC1342H21A Air Conditioner
Fujitsu inverter air cond. Just stopped working properly. Model outdoor AOT30PMAL indoor unit AST30PBA-W. Code oper. Red led flashes fast continously green led (timer) repeats 13 slow flashes. After power...
It sounds like your inverter is at fault. You will need an inverter tester ( most good service techs will have one ) to prove that the output to the compressor is correct. If the inverter is okay then it will be the compressor at fault with a location error or it is simply seized. A common fault that caused this was the eev remained closed (coil failure ) and caused the compressor to over heat.
May 11, 2010 | Heating & Cooling
Kenmore AC compressor on and off while outside unit fan running
If the out door fan keeps running and the compressor cycles off that would be the overload in the compressor.
What keeps the windings cool is the refrigerant back to the compressor.
For the overload to cycle it would have to be either not enough cooling back to the compressor or high amp draw, which could be the metering device (txv or orifice) or low on charge, or other things would be a bad capacitor, sometimes a bad start relay not staying open, when compressor gets up to speed or anything causing the compressor to draw high amps.
To check the refrigerant, he needs to check the superheat at the compressor it should be appoximately 12° to15°, and next time the compressor goes off if you shut the power off and feel the top of the compressor and if it's hot 130° or higher it's probably refrigerant.
Aug 14, 2009 | Heating & Cooling
No cold air coming from the registers.
If your compressor is running outside (low hum noise) then your probably need freon .If the compressor is not running could be a bad cap or bad compressor
May 22, 2009 | Heating & Cooling
Hitachi RAS-09UH Air Conditioner Logo
289 people viewed this question
Top Hitachi Heating & Cooling Experts
ka4iup
ka4iup
bobalix
richie46
Are you a Hitachi Heating and Cooling Expert? Answer questions, earn points and help others
