Question about Ricoh Aficio 180 Copier aficio 180
Where is the hard drive on a ricoh aficio 180 copier
  • 58 Answers
SOURCE: User Manual
You can go onto RICOH>COM ,then go to manuals, then to users manual,and down load.Most all user manuals are free.
Posted on Oct 18, 2007
jaylex
  • 417 Answers
SOURCE: Fault code SC402
Transfer roller leak error 2
A current leak signal for the transfer
roller is detected.
A current feedback signal for the
transfer roller is not detected.
• High voltage supply board defective
• Poor connection of the PCU
• Transfer/separation unit set
incorrectly
• Transfer roller damaged
The above is what SC402 means the most common thing is that someone tried to change the toner and pull out the drum unit a little way.
OPen right hand door open front door lift green toner handle press green button and pull toner unit out press the green button further and keep pulling and then the toner unit will come out totally.
To the right of that is the drum unit pinch the unlock and pull out then push all the way back in. Reinstall the toner unit close all covers and turn machine on.
Hopefully this will work if not there is going to be a problem with the other possibilities listed above
Thanks J
Posted on Jan 02, 2008
spinal
  • 287 Answers
SOURCE: ricoh aficio mp 2510
Hello e3tech, faatmaan has given you some valuable and accurate information. I would like to offer you some additional information that may help. i am not sure to what degree you have technical experience regarding problems as deep as you are experiencing. I just want to try to help you starting with the basics. We can get the proton accelerator out as a last resort. :-) In the event you have not tried to reset the code (which you can in the event that this code was a temporary condition or erroneous to start with) let me walk you thru the process of resetting the code and lets see if the copier can recover without going into the ugly (but prehaps necessary) and expensive stuff. Again I am just trying to help and this is the first thing anyone should do. We need to enter service mode, usually accessed by the expensive on site technician but you can handle it. This is the first thing I would do if I was onsite. I have been working on copiers for 20 years, which may merely mean I have been on a reign of terroe for that long, screwing everything up! LOL .Ok in order to enter sevice mode on your machine you will need to press the yellow button marked "clear modes" then then numbers 1-0-7 in slow but firm sequence, and the the orange stop clear button and hold IT down tull the screen changes and you will hear a beep. Once again......Clear modes,then 1>0>7 (in sequence) then hold down the orange stop/clear button till the screen changes and you hear a beep. (note....the beep is not guaranteed as it can be turen off prior to what we are doing but you will see the screen change). the new screen may say a number of things but for sure it will have a block named copier. Press that block which will bring up another new screen with all kinds of stuff that you need not be concerned with.The fact that you are at this screen is the cool thing. At this point, turn the main power swith off....!!!!!! THE ONE NEXT TO YOUR LEFT KNEE!!!!!! not the one on the op panel. Unplugging the copier will do the same if you are unsure.The point is to totally de-energize the copier. Turn the copier back on, and this point it will know that some one who knows what they are doing it attempting to help it recover andthe copier will wake up witha new outlook on life and will try to successfully restart back to normal. Without the steps we just went through the copier would have not went through the servicr mode process required foe it to truly have a chance to recover. When you turn it back on, the copier will look at all the critical sub systems it monitors before it feels comfortable to say "READY". In this case the errer code has to do with the very high temperature area called the fuser. As you probably understand, the manufacturer of the copier has designed the copier to keep close tabs on this area as to not burn down your building. So id there is any oddity in this area the machine throws a temper tantrum. So, lets hope hope the machine restarts, and it was a temporary thing , and you wont have to go the route that faatmaan suggested, which again may be absolutely accurate and well detailed. I just thought we could try the reset and hope for the best as it is a genuine and viable option and alot less expensive. I wish you the best. By the way, in the future, ALL error codes you get in the future(and there..are a hell of alot of them) can be reset in the manner I described ealier.This can be a big help for you . It just so happens that this and a few others in the "500" series are less likely to stay reset. I hope I have helped save you alarge wad of cash, but a minimum you are armed with a few valuable tools that may save you buttocks in the future. Take care.................. SPINAL
Posted on Feb 19, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Repair and service manual for Ricoh Aficio 250
Check with this website, they should be able to get you one
http://www.service-manual.net/ashop/catalogue.php?exp=&cat=283&gclid=COzWt96Ym5QCFSUqagodnl83tg
Posted on Jun 30, 2008
SOURCE: Ricoh aficio 1232c error code sc 543
This is a fuser problem,possibly a dirty thermistor, but try resetting it first.....
Press yellow key
key in 1,0,7
then press and KEEP HELD DOWN the orange key until the screen alters into service mode. (about 5 seconds)
Then switch off the copier with the main orange on/off switch. Located just below the front cover....
Posted on Jan 22, 2009
What will I do to Ricoh Aficio MP 3350B with an error code of SC220?
Ricoh Copier Error Code SC 220 is Laser Sync Detect problem. Check your manual and there is a fix for this in the menu.
Sep 30, 2014 | Ricoh Aficio MP3350
Ricoh aficio mp c6000 factory reset
1. Press the * key and the # XXXXX on the Ricoh copier at the same time and hold for 10 seconds.
2 After 10 seconds or so, the printer will restart itself and will be factory reset.
Dec 09, 2013 | Ricoh Aficio MP-C6000
Ricoh aficio mo 3351 reads messege functional problem detected . SC819
unplug the hard drive and switch on machine, if the problem goes away, then plug the hard drive back in and format it with service code 5-832-001, normally works
Nov 03, 2013 | Ricoh Aficio MP 2000 Black and White...
Where is the hard drive located on a ricoh aficio 2022
i don't think there is hard drive, but there is memory inside
Feb 02, 2011 | Ricoh Aficio 2022 All-In-One Laser Printer
How to reset toner on Ricoh Aficio 180
If you want to reset the toner bottle, open the front cover, lift up on the green toner handle, push the lever in to slide out the toner hopper, pull out the toner bottle, give it 1 or 2 gentle shakes, and put it back in the hopper. Then push the hopper closed until it snaps into place, push the handle back down, and close the front door.
May 25, 2010 | Ricoh Aficio 180 Laser Printer
Does a Ricoh Aficiio AC 450 have a hard drive?
The Ricoh Aficio 450 came standard with 12mb of RAM and had an optional 1.7GB Hard Drive.
May 18, 2010 | Ricoh Aficio 450 Copier
Ricoh aficio 200
Ricoh Aficio 200 copier has stopped copying from side tray. Can you help?
jimgoatley@slingshot.co.nz
Feb 17, 2008 | Ricoh Aficio 180 Laser Printer
Error Message SC320
We are buying a new machine! The price of the motor and labor is more than the machine is worth.
Feb 06, 2008 | Ricoh Aficio 180 Laser Printer
Ricoh Aficio 180 Copier aficio 180 Logo
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
