Question about Cycling
I have a mongoose rebal, i was riding around like normal doing small jumps when i hears some grinding then pop. So i got off and looked and it looks like my whole bearing poped out so i took my back wheel off and sure enough im missing a bearing and theres 3bend then rings i have no clue what to do? Help!
    Problem Solver:
  • 18 Answers
You will have to replace the axle and repack new bearings a huge greasy mess buy new back wheel. if you are jumping that bike does not come with strong enough wheels for hard riding. if you upgrade the back wheel you can always keep it for your next bike, like an investment in your happiness.
Posted on Jan 25, 2013
ah1f39
  • 34 Answers
SOURCE: Front wheel wobbles
More than likely the wheel is out of true. There are 2 choices,
1 Buy a spoke wrench and attemp to true the wheel. You can do this by spinning the wheel to locate the spot where the wheel goes furthest to one side then tighten the spoke coming from the opposite side. Do this slowly 1/2 turn at a time. Do not over tighten the spoke. It may be necessary to loosen the other side slightly.
Alternate spokes between both sides of wobble.
2 Take bike to a good local bike shop to be tuned and have the wheels trued. Most shops offer a tune up at low cost. A well tuned bike will last a long time.
http://www.sansaworld.com/
http://www.sansaworldmp3.com/
Posted on Apr 07, 2009
cogdoc
  • 7 Answers
SOURCE: i purchased a 16in boys Mongoose and took the
The wheel isn't centred correctly is my bet. Looking at the bike from behind, is the wheel pointing straight ahead, or is it off to one side? Common mistake to either not put it back in straight, or not tight enough, and the chain tension when you pedal will pull the wheel off centre.
Posted on Jul 01, 2009
  • 1137 Answers
SOURCE: took the back tire off of a Mongoose Racer X 7808
I hope this helps:http://www.mongoose.com/usa/eng/bmx/MongooseTemplates/downloads/OwnersMan_Mass_010307.pdf
Posted on Aug 20, 2009
  • 1137 Answers
SOURCE: riding 3 wheel schwinn meridian on a slope
Try shifting your weight to the center of the road side of the seat and steering slightly towards the center of the road. You might have to adjust your seat down slightly to give you a lower center of gravity. Unfortunately roads aren't particularly designed with enough width on the shoulders. If you are an older person, you may be able to get away with riding on the sidewalks unless there is a bylaw or law which prevents you from doing so. Just be really courteous to the pedestrians.
Posted on Sep 11, 2009
SOURCE: New Mongoose 700c Men's Paver bike: Mongoose 700
Local bike shop determined that both wheels were defective. I took the junk back to Walmart and got a refund... PROBLEM SOLVED!!
Posted on Dec 30, 2009
How can the drive and driven sprockets be aligned?
Hi Charles
I'd be looking at the positioning of the rear axle. A small change in the angle could line up the sprockets.
If the rim is centred in the frame right next to the pedal sprocket, the sprockets should be in alignment. If they are not, I'd be thinking that the frame has been bent, and be trying to figure out where, and how to straighten it.
Odds are that one of the cycle shops would have a quick look and give some advice. Those guys are usually really great with helping keep riding enjoyable.
Jul 04, 2015 | Pacific Cycle Mongoose 18 inch Bike - Boys...
All the bike is aluminiun
Mongoose is the run of the mill brand on the utilitarian side. They are a perfect step for a kid or an adult getting into biking. All aluminum is great because it is so light weight but that is pretty much the normal material for bikes these days. If you become a serious biker you will find out what you do and do not need by riding a Mongoose.
Aug 15, 2014 | Mongoose Cycling
Grinding noise when accelerating
HI If your bike is chain drive, look at the chain tension, the chain could be hitting the gear box case. If you primary sprocket is worn the the chain could be jumping teeth If you have a shaft drive then inspect the universal joints and the differential oil level
Feb 02, 2014 | kawasaki Motorcycles
Loud pop when amp is turned on, arc appears to jump somewhere near 3-500's
(22a has a discharge spark gap built in in the op manual it will tell you that upon power on you may hear arch witch is normal similar to a spark plug gap, its not your caps arching. look for the caption small paragraph in manual it will explain.
Aug 07, 2013 | Kenwood TL-922A Amplifier
Snapper riding mower runs but wont pull itself
first check the friction wheel that drives the rear axle then look at the cable adjustment you may need to move the small rings around the pedal if all that looks good loosen the pulley assem away from the engine closer to the axle
May 16, 2012 | Garden
Rubbing/grinding sound in front end/ drivetrain
from your description it is possible that the low brake pad warning tag is activated indicating tat the brake pads are worn out
it is a small tag that rubs on the disc just before the pads damage the rotor
as sound travels it could be a rear wheel with the problem
to check , take the vehicle to an accredited brake specialist shop and have the pad thickness checked
to be safe the thickness has to be 1/8 " or better
Mar 31, 2017 | Dodge Charger Cars & Trucks
Hi...just put together my son's new Bike (20'' Boys' Mongoose Rebel Freestyle Bike) and I noticed that when pedaling backwards, it's not smooth, and sounds like something is rubbing or grinding (pedaling...
It sounds as though the chain is too tight. Check to see when it is "freewheeled" if the chain gets tighter. Generally this will happen because the chain ring (front sprocket) was not perfectly aligned with the "spider" (thing it bolts to). You can loosen the chain a little and see if this helps. Be careful because you don't want it so loose the it comes off while riding. What I usually do is adjust the tension of the chain with the sprocket in the tight spot. Kind of tight but without the "grinding" feeling.
Good luck.
Dec 22, 2010 | Mongoose Cycling
I am not sure if the wheel bearing on the front end is broke. it makes a loud poping noise when turning and the wheel is towed in
Loud popping/grinding most noticeably heard when turning is normally a sign of a bad CV joint. Look under the van where the axle half-shafts come out of the transaxle and connect to the backside of the wheel assembly. Are the rubber boots on the axles torn or missing?
If you hear the popping only in left turns, your right CV joint is bad, If you hear the popping only in right turns, your left CV joint is bad.
Nov 10, 2009 | 1999 Ford Windstar
Jumps around
Mine did this, it never got fixed, repairman told me to replace it. I suggest you do the same. He told me the springs and bumpers had just worn out, and from the looks of my old washer, he was right lol
Feb 27, 2009 | Kenmore 24032\24036 Top Load Washer
Vibrations in Whirlpool WFS1071AW
Hi the problem with your machine is the fact the transit straps have not been removed!! Remove them and you will not hear another thing from it. Look at the manual to find out how to take them off!
Dec 28, 2008 | Whirlpool AWM5125/1 Front Load Washer
Cycling Logo
27 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
