Question about Ice-O-Matic ICEU220HA Undercounter Ice Machine
I HAVE A AN ICEOMATIC ICEU220HA2. MACHINE WORKS FINE BUT I HAVE WATER FORMING IN THE BOTTOM OF THE UNIT WHERE THE COMPRESSOR IS? AND HOW DO I REMOVE THE ICE BIN TO GET TO THAT AREA TO FIGURE THIS OUT?
4 Suggested Answers
SOURCE: Ice-o-matic wont' drain water from bin
the purge valve empties the tray... the bin just drains with gravity... If you bin isn't draining... it must be clogged somewhere.
Posted on May 30, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: my iceomatic ice machine is not producing ice.
Could be a bad water solenoid. Could also be because it needs to be cleaned. If there is ice stuck to the evaporator, the hot gas bypass is not working. Try cleaning the unit first.
Posted on Jan 17, 2010
Therinnaiguy
  • 1420 Answers
SOURCE: ice maker is working, but there is water in the bottom of bin
You will need to pull out what ice you have in the bin to get to the drain. Once you have done that, take a hose and force water thru the drain. You may have to snake the drain if is more than a build-up of ice. Once the drain is working, clean out the bin with ice machine cleaner and sanitizer. Restart the machine and make sure no water is dripping from the evaporator above. If there is, it needs to be cleaned.
Makes ice but water want stop running n to ice bin
If you look above / behind your ice bin you'll notice a plastic hose wich feeds water to your ice maker. It may be loose or cracked allowing water to drip to your ice bin.
Oct 17, 2016 | Ice-O-Matic IceOMatic IceOMatic 400 Lbs 38...
Iceomatic
Make sure you have power and water...be more descriptive if there is any more to it.
Dec 17, 2013 | Ice-O-Matic ICEU220HA Undercounter Ice...
Amana freezer forms ice on the bottom. We have taken it apart, cleared ice from coils and drain, turned down freezer temp, but it still happens. Fridge works fine. Any other ideas?
When you see that ice forms on the bottom of your freezer it is most likely means that the drain hose of the fridge is blocked.
You will need to take the panel inside the freezer off, clear all the ice and pour hot water into the drain hole until you hear the water coming out at the beck where the compressor is located.
The next step would be running a 1/4" hose thru that hole.
Good luck.
www.QuickFixAppliances.ca
Oct 07, 2013 | Amana ARB8057CSR Bottom Freezer...
WHERE CAN I PURCHASE A CHEAP NEW OR RECONDITIONED COMPRESSOR FOR MY ICE MACHINE? tIMES ARE HARD AND I CANNOT AFFORD THE $600 FOR A NEW ONE.
Hello Smokinjoex5,
I need to know a model number of the unit in question. The model number should be located on the rear of the unit and/or the numbers off of the compressor. You do understand that you will still need to have a service tech come and install the compressor as this is not something that you can do, you have to be a licensed HVAC service tech.
Post back and I will try and locate you a compressor.
Thank you for choosing FixYa.com
Justin
Apr 19, 2011 | Ice-O-Matic IceOMatic IceOMatic 400 Lbs 38...
My iceomatic ice machine is not producing ice. There is ice frozen to the grate and water is not running
Nov 17, 2009 | Ice-O-Matic ICEU220HA Undercounter Ice...
Water not going into icemaker. Water dispenser works fine.
Check the water valve at the back of the fridge if present.
Even if you used blowdryer, ensure that linse are not frozen by performing a complete defrost.
Disconnect water lines from icemaker, and blow with compressor if the above did not work.
May 20, 2009 | Kenmore Refrigerators
Fridgedaire Elite frost proof fridge part not cooling, Freezer sems fine
If the frozen side is colder than normal and some extra frost is forming where the fan blows,and there is ice in the bottom of freezer compartment, and the cool side is not cool enough, their is a good possability the defrosting unit is not removing all the frost and ice . the defrosting unit has a timer (usually near thermostat) that turns off the cooling fan and compressor and turns on a small heater around the evaporator ( about 20 minutes every 2 days) (evaporaror is cold heat exchanger coil inside the back wall behind a cover near the recirculating fan0, the fan circulates air to both compartments through two small openings, if these openeing are closed by ice buildup cool air can not circulate to the cool side. cure 1. remove all food and leave fridge off for 24 hours with doors open (take precautions to ensure children can't get locked in side and suffocate, if you get a qt of water in bottom of unit (may leak on floor) ice buildup that the defrost heater can not remove melted and was your problem . turn frig on replace food on unit. cure 2. turn frig off, remove food from both sides, remove shelves that block access to evaporator, remove cover over evaporator if you see the evaporator coils free of ice look at openings (2) to other side, one may be blocked with ice the other with frost, carefully melt ice with hair dryer.
If the evaporator coil is solid ice heater or timer or fan has failed. good luck
Aug 09, 2008 | Zanussi Z57 / 3 Bottom Freezer...
No water colledction
Check to see that the air is flowing freely through the dehumidifier. They will accumulate dust particles and become plugged. Also make sure that it is not freezing up (you would see ice forming inside through the vent openings). I have had to remove the case to clean lint from some units to get them to operate more efficently. Always unplug the unit to clean and service it.
Dec 31, 2007 | Crosley MCR40ES Dehumidifier
Ice-O-Matic ICEU220HA Undercounter Ice Machine Logo
82 people viewed this question
Top Ice Kitchen Appliances - Others Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
jasbo
jasbo
mike cooper
Are you an Ice Kitchen Appliances - Other Expert? Answer questions, earn points and help others
