Question about Sony Vaio Pcg-7153l Laptop Webcam
It will not turn on
I charged the battery and the system will not turn on.
  • Sony Master
  • 27,725 Answers
If your laptop won't turn on, you could have any number of problems. The problem might be a genuine power issue derived from either battery failure or simply a loose AC adapter. Conversely, it may only appear to be a power failure, and the problem may lie with another component. Errors in brightness settings and LCD display malfunctions can both make a laptop appear to be powered off, and all these problems will need to be corrected. Look at the battery indicator light on your computer. Is it on? If so, check your brightness settings. If your laptop appears that it is not on, it may in actuality have lowered brightness settings. If the brightness setting is at its lowest setting, the laptop screen will be completely dark, and the laptop will appear to be powered off, even though it is not. Try cranking up the brightness settings. Check your AC power adapter. Is it snugly plugged into the wall or surge protector? Make sure the connection is made and it is not loose. Also, try connecting the power adapter into a different wall outlet. Check the status of your laptop battery by considering how long you have had the same battery. Most modern batteries are only good for about 1,000 full charges. After that point, the battery can and eventually will greatly deteriorate. Replace your battery if necessary. Replace your battery by powering off your laptop and then flipping it over and locating the battery cover outline, which will be near the bottom back of your laptop. Remove any screws with a Phillips screwdriver and pop off the battery cover. Slide out the old battery. Put in the new battery by sliding it in until it clicks, and then replace the cover. Consider replacing your laptop monitor. Your laptop may power on, but if the monitor display does not work, it will appear to be off and you will not be able to operate the machine. Check to see if your current LCD display works by plugging your laptop up to an external monitor using a VGA cable. If the external monitor displays your computer contents, your computer motherboard and underlying systems are still working, but your display will need to be replaced. Replace an LCD display by removing the screws around the bezel of your current display with a Phillips screwdriver. Pop off the bezel carefully and remove it. Then, locate the screws on the two metal brackets beneath the bezel and on either side of the display, and remove these too. Disconnect the inverter cable, which is plugged into the inverter. The inverter is located just beneath the display, at the bottom-center of the laptop. Then, pull back and slide out the old display, and replace it with the new. Put the metal bracket screws back in place, reconnect the inverter cable, and then pop the bezel in place. Replace the bezel screws. Hope this helps.
Posted on Jan 16, 2013
My battery light has been coming on and off for a couple of weeks now and saying "Service Battery Charging System".
Have your charging system tested. The battery light is turned on when there is a charging system problem causing an over/under charge condition. You may possibly have an alternator problem. If the battery is not being charged properly, the computer will start shutting down electrical components for protection and to keep enough voltage supply to enable the vehicle to continue running
Jan 27, 2016 | Cars & Trucks
2004 gmc envoy xuv , battery light stays on , replaced battery and checked alternator charging fine
You checked the charging voltage at the battery with a ? volt meter ? What was the voltage with the vehicle running ? 13.1 to 14.1 volts ?
BATTERY NOT CHARGING The IPC illuminates the battery not charging indicator in the driver information center when the following occurs:
The PCM detects that the generator output is less than 11 volts or greater than 16 volts. The IPC receives a class 2 message from the PCM requesting illumination.
The IPC determines that the system voltage is less than 11 volts or greater than 16 volts. The IPC receives a class 2 message from the body control module (BCM) indicating the system voltage
Charge Indicator Always On
Step
Action
Yes
No
Did you perform the Diagnostic System Check for Starting and Charging? yes or no
Go to Step 2 yes
Go to Diagnostic System Check - Engine Electrical no
  1. Turn ON the ignition, with the engine OFF.
  2. Observe the Charge indicator on the instrument cluster (IPC)
Does the charge indicator illuminate?
Go to Step 3
Go to Symptoms - Engine Electrical
  1. Turn OFF the ignition.
  2. Disconnect the generator connector.
  3. Turn ON the ignition, with the engine OFF.
Go to Step 4
Go to Charging System Test
Test the charge indicator control circuit for a short to ground. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 6
Go to Step 5
5
Replace the PCM. Refer to Powertrain Control Module Replacement in Engine Controls 4.2L.
Did you compete the replacement?
Go to Step 6
6
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Go to Step 3
Aug 25, 2015 | GMC Cars & Trucks
2012 Grand Caravan. How do I turn the battery light off after installing a new battery?
Test the alternator. The battery light is for the charging system. Once the charging system is working with the engine running, the light should go off. If your light stays on with engine running, the alternator may need service or replacement.
To test the charging system, just put a voltmeter on the battery with engine running. The voltmeter should register at least 13.5 volts- alternator is charging. If you only show battery voltage with engine running, like 12.2-12.8 volts, the alternator or charging system is not working. The battery light should be on to signify this.
Jun 17, 2015 | 2012 Dodge Grand Caravan
What's a charging system
The alternator supply the charge to your battery that run all electricalits a 101 on your charging system
Apr 12, 2015 | Cars & Trucks
I have no power charged battery was ok before now no power check the fuses there ok can you tell me why i have no power please
it seems that the battery is not charged or not connected. When you open any door the light inside must turn on. When not, the battery is not charged. Charge the battery and try again.
When the battery goes again out of the power, it indicate that the charging system or alternator are not working properly.
Start your vehicle turn the headlamps on and check the voltage on battery. It must be higher than the voltage when engine is off.
If the voltage with engine on is about 14,5 V charging and alternator are ok. Maybe the battery is dead.
When the voltage with engine on is higher than with engine off but not 14,5 V, there is problem with charging system. When the volage is the same, it can be alternator or charging system.
Oct 20, 2013 | 1990 kawasaki ZZR 1100
Battery keeps going flat on gilera runner 125vx 4stroke
Three possible issues: Bad battery won't hold a charge or rapidly loses a charge. Bad charging system/ alternator. Current draw on the battery when turned off. Use a multimeter to check voltage on battery terminals when it is running. You should see at least 13 volts. Fully charge the battery for about 6 hours, unplug it from the charging system, and then check the battery voltage. It should be at least 12.0 volts, actually a bit higher. If your ammeter can handle it, you could test for current when it is turned off. You want the reading to be 0 or very close to zero,
Oct 17, 2013 | Motorcycles
Why doesn't it charge at idle?
It depends if the system is RVC/regulated voltage control. If so, there are about six modes of operation. One is, "fuel economy mode". In that mode, the targeted generator out-put is 13 volts and battery state of charge is greater than 80%. There are two other conditions.
Is there a battery discharge problem? Does the instrument cluster give charging system message or warning lamp?
Any charging system trouble codes? My info on your charging system is limited.
May 02, 2013 | 2010 Chevrolet Express Passenger
My dell inspiron 1501 will charge the battery but as soon as i unplug the laptop turns off.
It's either the battery or charging circuit on the system board. If you have replaced the battery with a new one then it's probably the system board. A new system board could run between $150 to $300. Then there's the coat of labor.
Feb 17, 2013 | Dell Inspiron 1501 Notebook
Alternator good , battery good, belts on a/c bad can this cause battery not to charge?
What do you mean by bad A/C?If the A/C doesnt come on but the pulley turns without interference to the drive belt then No. It doesnt effect the charging system, what does effect the charging system is the ability of the battery to hold a charge.The average life of a battery is 5 years, The terminals how good of a connection are they? clean and have a solid connection.Have the battery tested,remeber the charging system should be 2 volts above battery voltage
Nov 12, 2012 | 1993 Buick Park Avenue
Open Questions:
We provide best team support to all Toshiba users active for 24*7 hrs. Call us +1888784-9316 With 24x7 major subsidiaries and affiliates worldwide, Toshiba Corporation is known as a world class innovator and global high technology product leader worldwide. Toshibha launched laptop computers from its kitty way back in 1985 and by Financial Year 2010 they have managed cumulative shipment of more than 100 million Laptops. Toshiba has been known to set benchmarks when it comes to quality and features that results in exceptionally high performance. In spite of the exceptional features you may experience issues related to data recovery, backup and security and may be deprived of any support by the Toshiba Support. In the event of an OS Crash there is always a chance that you may Toshiba Support your critical data. Virus attack or accidental data deletion are also some of the other reasons that could cause mess. An updated backup will warrant that you do not lose your critical data forever. DataAlign comes to you rescue in these situations. DataAlign offers comprehensive technical assistance for your computer's data backup, recovery and security. DataAlign lets you schedule backups to execute daily, weekly or monthly. Our award winning cloud backup Toshiba Customer Service lets you schedule your backups continuously throughout the day. Data Align gives you affordable services that saves you both time and money and that lets you take control of other important things in life like growing your business or spending time with near ones. TOSHIBA is known for its diversified product range and services worldwide. Still, there are several issues that a TOSHIBA user can face on the TOSHIBA computer. Problems faced by TOSHIBA customers BIOS update Toshiba Backup Slow Performance Windows 10 upgrade Data Backup and Transfer Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Computer Tune-up Issues Virus Removal Issues Our highly talented and expert IT Team can help you fix most of the issues that you face with Toshiba Virus . And the best thing is that we can help you get your data backed up on our secure cloud storage. Why Our Toshiba Help Desk Number Technical Support Team Are Best? With several years of experience in our kitty working with a wide variety of customer group, we have gained an edge when it comes to providing technical support for TOSHIBA Computers. To add to it, our expert technicians trained specifically on TOSHIBA computers are always ready to help you best possible solution for any issue that you may face with your TOSHIBA product. 24X7 availability and assistance for your TOSHIBA computer. We have a dedicated & experienced support team to handle issues for your TOSHIBA computer We ensure little to no downtime with maximum uptime and highest productivity for your TOSHIBA Computer. We ensure Data backup and retrieval assistance We ensure end to end ownership & solution for issues you face with your TOSHIBA computer. Quick and efficient support over the remote. You can sit back & relax while one of our techs fix the issue for you. All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact +1 888 784-9316.
Apr 27, 2018 | Toshiba Computers & Internet
See all Sony Vaio Pcg-7153l Laptop Webcam Questions
Sony Vaio Pcg-7153l Laptop Webcam Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
