Question about Vacuums
I have the Ninja Kitchen System 1100 and the only way I've found to lower the handle on the lid is to simultaneously depress the two white "tabs" at the base of the handle. This is awkward at bes
    President:
  • 2,976 Answers
Make sure you have the arrow on the handle in alignment with the arrow on the lid. Press down securely before closing the handle.
Posted on Jan 18, 2013
2 Suggested Answers
SOURCE: Belt replacement in Hoover Sprint upright vacuum
take the screws off the bottom. Use a flat head press down snap the bottom over off. The housing on top you gotta snap off.
Posted on Oct 22, 2009
How do I hook up the upholstery attachment on a Hoover Spin Scrub 50?
To connect the upholstery tool, first remove the clean water tank by pressing down on the handle and pulling the tank forward. Remove the hose from the storage rack. Press down on the handle release lever and lower the handle to the ground. Unlatch the back part of dirty water tank and remove the lid. Pull the dirty water tank's front panel up about an inch and rotate the panel to parallel with the floor. Replace the panel with the converter and slide it halfway down until it is firmly in place. Pull the collar on the connecting tube towards the tube so that the black tabs are fully extended. Open the door on the hood labeled Stair/Upholstery cleaning connection and press the round solution tube onto the round projection. Press the collar firmly to ensure that the tube is connected. Replace the tank in a hinge-like manner and place the lid under the tabs on the front of the tank. Rotate the lid down onto the tank.
Now slide the upholstery tool on the connector of the hose until the tab locks into place.
The manual for the Spin Scrub 50 is available on the Hoover product page: http://hoover.com/products/details/fh50044/steamvac-spin-scrub-50-carpet-washer-with-tools/ . The direct link to the manual is http://hoover.com/file/1195/ . The directions are on page 14-15.
I hope this helps.
Oct 19, 2015 | Hoover Vacuums
I just purchased a floormate. I can't seem to get it to spray cleaning solution.
Turn the cleaner off and then on again to determine whether the cause of no suction resulted from the activation of the automatic shut-off. There are two reasons a tank will automatically shut off. The first is if the recovery tank is full. Located on the lower front panel of the unit, the recovery tank can be easily emptied and replaced into position. To remove from unit, press down on the release button and pull the tank downward and forward. Lift up on the tank latch lid and take out the tank lid. Empty the tank. Also check the tank lid screen for debris and remove any found. To replace the lid, align the tab that corresponds to the front hole of the tank. Snap the latches on the back of the tank. Insert the bottom of the tank back into the cleaner and push in and up until it locks in place.
Turn the unit on again and check the suctioning action. The second reason automatic shut-off could take place is if the handle was raised to an upright position while the motor was running. Should this occur, simply turn the unit off, wait a moment for the shut-off to reset, and turn it on again to continue cleaning.
  • 2 Make sure the filter and filter lid are properly positioned in the recovery tank lid. The cause of the problem could be that the filter or the filter lid were missing or were not in the proper position.
  • 3 Check that both recovery tank and/or solution tanks are locked in place and are positioned properly. The recovery tank is located on the lower front panel of the Floormate, and the solution tank is located in the front top panel of the unit. To remove from unit, press down on the release button and pull the tank downward and forward. Lift up on the tank latch lid and take out the tank lid. Empty the tank. Also check the tank lid screen for debris and remove any found. To replace the lid, align the tab that corresponds to the front hole of the tank. Snap the latches on the back of the tank. Insert the bottom of the tank back into the cleaner and push in and up until it locks in place.
  • 4 Observe whether filter is dirty. If the filter is dirty, clean the filter by turning the cleaner off and disconnecting it from the electrical unit. Take out the recovery tank and lid. Remove loose debris from the filter by wiping clean with a brush or tapping the filter over a garbage can. After this is completed, the filter may be rinsed clean for additional cleaning and then air dried before returning the filter to the unit.
  • 5 Check that the nozzle is in the proper position and locked. Locate the nozzle underneath the suctioning base of the unit. Make sure the latches are out and line up the middle section of the nozzle with the opening of the cleaner. Hold the nozzle in place while simultaneously sliding the latches inward to lock in
  • Mar 07, 2011 | Hoover Floormate H3000 Upright Wet/Dry...
    I want to use upholstery cleaning tool and do not know how to hook it up
    Hi There,
    I'll be happy to walk you through step by step how you can attach the hose to your Hoover SteamVac.
    Here are step by step instructions for you:
    Step 1. To prevent possible leaking, remove
    clean solution tank by pressing down on
    tank handle (D) and pulling forward; set
    tank aside (do not set tank on furniture2_bing.gif).
    Remove hose from storage rack.
    Step 2: Step on handle release pedal (E) and
    lower carpet cleaner handle until it rests
    on the floor.
    Unlatch back part of recovery tank and
    remove lid.
    Step 3: Remove recovery tank front panel (F)
    by sliding it straight up.
    Step 4. Replace panel with converter (G).
    Slide converter halfway down opening
    Step 5. Before connecting tube (H) to
    cleaner, make sure black tabs are
    extended by pulling tan collar toward
    tube.
    Open door on hood labeled “Stair/
    upholstery Cleaning Connection”. Press
    round solution tube connector onto
    round projection inside door. Press connector
    collar down firmly to ensure
    that it is fully connected.
    Step 6. The tank replaces in a hinge-like
    manner. Position front of lid under tabs
    (I) on front of tank. Rotate lid down onto
    tank.
    Make sure lid is secure on all sides
    before cleaning.
    For full suction, it is important that
    the recovery tank lid is properly
    secured before cleaning.
    Reverse procedure to remove hose
    and solution tube.
    Raise carpet cleaner2_bing.gif handle to upright
    position.
    I hope that this was helpful to you in hooking up your Hoover SteamVac hose. If you found this helpful, please be so kind and rate my repair helpful by clicking the 4 thumbs up icons in the top right hand corner of the repair, this is really appreciated.
    Thanks again,
    Chris J.
    GoVacuum.com
    Jun 15, 2010 | Hoover SteamVac F5914-900 SpinScrub...
    Where do i plug the hose into the vacuum
    Hi There,
    on the floor.
    remove lid.
    tube.
    tank.
    before cleaning.
    and solution tube.
    position.
    Thanks again,
    Chris J.
    GoVacuum.com
    Jun 15, 2010 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
    Dont have a manual how do u connect the hose to it
    Hi There,
    on the floor.
    remove lid.
    tube.
    tank.
    before cleaning.
    and solution tube.
    position.
    Thanks again,
    Chris J.
    GoVacuum.com
    May 05, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
    I have lost my owners manual and need to find out how to hookup upholstery cleaning tool
    Hi There,
    on the floor.
    remove lid.
    tube.
    tank.
    before cleaning.
    and solution tube.
    position.
    Thanks again,
    Chris J.
    GoVacuum.com
    May 01, 2010 | Hoover SteamVac F5914-900 SpinScrub...
    How to attached stair cleaning attachment
    Hi There,
    on the floor.
    remove lid.
    tube.
    tank.
    before cleaning.
    and solution tube.
    position.
    Thanks again,
    Chris J.
    GoVacuum.com
    Apr 25, 2010 | Hoover F5835900 Upright Steam Vacuum
    How do i hook up my stair cleaner part to my hoover steamvac to clean my carpeted stairs? f5909=900 model
    Hi There,
    on the floor.
    remove lid.
    tube.
    tank.
    before cleaning.
    and solution tube.
    position.
    Thanks again,
    Chris J.
    GoVacuum.com
    Apr 25, 2010 | Hoover SteamVac F5914-900 SpinScrub...
    Replace accessory hose
    i There,
    on the floor.
    remove lid.
    tube.
    tank.
    before cleaning.
    and solution tube.
    Raise carpet cleaner handle to upright
    position.
    Thanks again,
    Chris J.
    GoVacuum.com
    Apr 15, 2010 | Hoover SteamVac F5914-900 SpinScrub...
    I lost my instruction manual to my hooversteamvac and need to know how to hook up the upholstery tool
    Hi There,
    tank aside (do not set tank on furniture).
    on the floor.
    remove lid.
    tube.
    tank.
    before cleaning.
    and solution tube.
    position.
    Thanks again,
    Chris J.
    GoVacuum.com
    Apr 12, 2010 | Hoover SteamVac F5914-900 SpinScrub...
    Vacuums Logo
    Top Vacuums Experts
    AskDyson
    AskDyson
    D. Floyd Kolb
    D. Floyd Kolb
    Are you a Vacuum Expert? Answer questions, earn points and help others
