Question about Konica Minolta bizhub Office Equipment & Supplies
C550 error C3924
Bizhub C550 error code C3924
SOURCE: Can't Scan anything on a BizHub C550 to 5 pcs on the same network
Be sure that your Domain name is in the network settings on the printer. This can be done on the printer itself or opening a web browser. Put the IP address in the address bar of the browser, this will conect you to the machine. Log off the public domain that come up and log on the administrator area. Enter the password 1 2 3 4 5 6 7 8, unless it has been changed. There you will be able to set all of the network functions. The machine need this information in order to direct the scans to the correct place.
Posted on Jan 06, 2009
SOURCE: Socket Connect Error on BizHub C550
Select HTML on the Pagescope login page.
Posted on Mar 09, 2009
  • 44 Answers
SOURCE: on the bizhub C550 an error code C0204..... won't
Two things 1) check to see if there is paper in the back of the of the tray where it meets the back wall (that would prevent the paper tray from rising. 2) there is an upper limit sensor on the paper feed (thats where the rollers are) so check to see if any bits of paper blocking the sensors. If you find it, reset the machine and it will see the tray.
Posted on Dec 14, 2009
taminol
  • 62 Answers
SOURCE: I have a bizhub C550 color copier a error trouble
Hi Kiddco,
Sorry, this probably a bit late for you. It's Sunday evening here in the UK.
C-2A04 is an internal error of the EEPROM.
The only thing you can really do is turn the main power swich (the big one under the flap) off and leave it for about 10 seconds. Then turn back on and cross your fingers.
I'd generally look over the machine too, just in case there's any paper stuck.
Good luck
Posted on Feb 07, 2010
xeerie
  • 347 Answers
SOURCE: still need help with BizHub C550
tell me whats the problem you are facing plz tell in detail>..........
Posted on Jun 19, 2010
Konica minolta c550 displaying a code C-B116, how can I solve this please?
Konica Minolta Ineo 223 Fax card Error C-B003 \ C-B116 ...
www.copytechnet.com > ... > Copier Technical Discussion > Konica Minolta
Feb 6, 2014 - 10 posts - ‎6 authors
The other errors that appear are C-B116 & C-B003, i've tried the below : 1. .... Also ensure you have the fax set to the correct country code. Error Code konicaminolta bizhub500 error code C-B003
7 Sep 2010
How Do I Access Techrep / Service Mode? - Page 4
18 Jul 2008
More results from www.copytechnet.com
Error code C-B116, what does it mean? - Fixya
www.fixya.com/support/t1535504-error_code_c_b116_mean Jan 13, 2009 - Touch the following code on the trouble code display screen. Stop ? 0 ? 7 ... 4 Answers. SOURCE: Konica Minolta Bizhub C352 error C-B116.
Bizhub c250 code c-b116 - Fixya
www.fixya.com/support/t11325427-bizhub_c250_code_c_b116 Jan 17, 2012 - bizhub c250 code c-b116 code c-b116 on the bizhub c250. ... on the display you'll see the Trouble reset button on the display, touch it and turn ...
Konica Minolta Bizhub C352 error C-B116 - Printer
www.allprintersmn.com/konica-minolta-bizhub.../q724088-konica_minolta_bizhub_c... fix Printers & Copiers - Konica Minolta Bizhub C352 error C-B116 about Printers & Copiers. ... Konica Minolta BizHub C550 Error Message ... ERROR CODE C11B2 ON DISPLAY - Konica Minolta bizhub C250 All-In-One Laser Printer. konica minolta c550 displaying code B116 Google Search
Mar 15, 2017 | Konica Minolta Office Equipment & Supplies
C550 cooling fan not functioning, what can i do to make work?
Konica Minolta bizhub cooling fan not working Questions ...
www.fixya.com/tags/cooling_fan_not_working/printers/konica.../bizhub
Konica Minolta bizhub printers & copiers cooling fan not working related questions and answers. Ask your Konica ... Question about Bizhub C550. 1 Answer ...
Konica Minolta Bizhub C550 Cooling fan power - Questions ...
www.fixya.com > ... > bizhub > Konica Minolta Bizhub C550
konica minolta bizhub c252 error c-5351 C - 5351 Is power cooling fan problem.Verify the cooling fan connectors and clean.For reset open/close the front door.
cooling fan not operating properly - HP Support Forum
Nov 29, 2015 | Cars & Trucks
Bizhub c550
replace the drum and developer unit. try this site for parts as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Apr 14, 2014 | Konica Minolta Bizhub C550
Bizhub c550 code c d403
check all connections between the main boards start with having the firmware re-flashed via secure konicaminolta web site only tech have assess to, KonicaMinolta wants their firmware secured. secondly remove each connector on the board check for bent pin on the board connector, then re-seat each plug and there are a lot of plugs on each board!!!!!!!! worse case bad boards $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
Apr 08, 2014 | Konica Minolta Bizhub C550
Bizhub c550 loosing network access
does the copier have a static IP address or is dhcp meaning ever time the network is turned on the copier get a new/different ip address. Copiers love static so recommend your it person assign one.
Feb 11, 2014 | Konica Minolta Bizhub C550
two red light up doun, & do not printing...
64 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
