How do I change the setting on a sector sv7tc
How to set the date in sector sge 650 2653960035 watch? Thanks.
Unscrew crown. Some models of Sector Sport watches may have a screw down crown. Watches meant to be used in water will often have this feature. To test this try spinning the crown freely in both directions. If it does not spin freely it has a screw down crown. If your Sector has a screw-down crown, turn it in a counter clockwise motion to unscrew it until it pops free.
Pull crown out one click and set date. If the watch has a date perform this step, if not move on to the next step. Pull the crown out one click. Twist crown clockwise and counter clockwise to set the day and date to the previous days day and date. The purpose of this is to set the date by setting the time and insuring the watch is in the correct a.m. and p.m. mode.
Pull crown out to the next click and set time. Pull the crown out the to next click. This is the time setting mode. Set the time by turning the crown clockwise until the day or date changes to the current date. This is the a.m. mode. Continue to the correct time. If it is a p.m. time this will require moving one full circuit of the dial past the twelve again and then to the correct time. If you fail to do this, the date will change at noon. If there is no date, simply set it to the correct time.
Push in and screw down crown to retain water resistance. Push crown down into its furthest setting. If it is a screw-down crown, press the crown in with a finger and twist it clockwise. Be careful here not to cross thread the crown in the crown tube or it will need to be replaced. It should be smooth and easy to turn. If any pressure or resistance is felt stop and start over. If you fail to screw in a screw down crown your Sector Sport watch will not be water resistant.
Jan 16, 2013 | Watches
My Toshiba hard disk is not functioning well
Hi,Dear Customer,
1> Please check you HDD cable connector.
2> Where from connect HDD cable in mother board, this port change and be care fully connect.
3> Check HDD bad sector. If you hard disk create a bad sector then not well run any hard disk.
4> Check jumper setting, first boot & sec Boot option. you hard disk where connect first boot & sec Boot option.
I think solve you problem.
Sep 12, 2012 | Toshiba Computers & Internet
Manuel for yacht timer 700 please. Best regards P.Hessner
Could not find a download for instructions on this watch, but I did manage to find some basic instructions for the Sector brand. I hope this helps as this is the best I can come up with.
Good luck.
Sector Chronograph Watch Instructions
  • Most chronograph watches have screw-down crowns for water resistance. You must unscrew the watch crown before you can make any changes to the watch time. After time is set screw the crown back in. To utilize the chronograph dials, use the buttons on the side of the watch. One button will be for the second timer. Press once for the second hand to start timing. Press again to stop it. Another button will be to reset the second hand timer back to zero. Sector Chronograph watches may have different dial functions (see link in References).
  • Sector Dual-Time Watch Instructions
  • Because Sector watches are known for their sports capabilities, the Dual-Time watches have screw-down crowns. For Dual-Time timepieces, unscrew the crown counterclockwise. Pull the crown to middle position to set the date. Pull the crown out to its fully extended position and rotate it to set the day of the week, hour and time. Press and hold in the crown and turn clockwise to seal the crown back in to the watch.
  • Sector Ana-Digi Watch Instructions
  • Sector Ana-Digi timepieces have analog hands plus digital timekeeping functionality. To set the time, unscrew the crown counterclockwise and then clockwise to the appropriate time. The digital functionalities are programmed by the buttons on the side of the case. Depending on the style of the Sector watch, you can set the digital time with one button, set the date display, 1/100 seconds chronograph timer, altimeter, thermometer and alarm functions.
  • Aug 12, 2010 | Sector 700 2653700025 Watch
    Resetting a sector adv 2500 after battery change
    Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all SECTOR watch manuals. Rate me, please .
    Apr 08, 2010 | Sector 250 3253251115 Watch for Men
    How do i get the temerature guage to work on the secto mountain master? I recently purchased a Sector Mountain master 4 days ago. I have been reading the instruction manual over and over and I have yet to...
    Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all SECTOR watch manuals and these may differ from yours.Rate me, please.
    Mar 25, 2010 | Sector 3251908015 Mountain Master watch
    Washer will not change cycle
    HI. This will be the result of a failed control sector. Your control sector is responsible for the sequential actions of the cycle. If this sector fails to initiate in sequence, you will experience this type of interruption. The control sector can house a timer, or a control board. The timer can mechanically fail if the motor that advances the dial plate over the cogs, becomes faulty, and breaks down. Timer motor failure is common, and will require you to have it replaced, asap. It is not repairable. If your unit is equipped with a control board, this device can fail as well. The control board can experience circuit failure, thus, promoting program failure, due to chip set faults.
    In any case, the control sector must be replaced, asap. Once you have replaced either your timer, or control board, the unit will return to its normal operating status.
    Dec 31, 2009 | Estate TAWX700JQ Top Load Washer
    Windows xp instalation stpos givibg a blue screen in aspire m5640 desktop
    Windows Xp installtion give Blue Screen of Death when XP tries to installed devices driver during installation or when the cd is corruptted and cannot be read in graphical mode installation or when the hard drive is corrupted with Bad sector.
    Get a new windows XP CD and configure your system BIOS to default setting ( load optimal settings) and configured for IDE drive configuration to compatible mode or disable mode if you are using SATA hard drive.
    If problem still occured, get "Bad sector recovery pro" and try to repair the hard disk.If the bad sector are unrecoverable then change the hard drive.
    Sometimes, faulty RAM also give blue screen too. Check your RAM too.
    Dec 19, 2009 | Acer Aspire m5640 PC Desktop
    Sector 255 need to contact sector
    need help in setting time on sector 550 2653955025.
    Nov 16, 2007 | Sector 2653940025 Wrist Watch
    Computers & Internet Logo
    154 people viewed this question
    David Payne
    David Payne
