Monitors
Problem for Monitors
Generic problem for all Monitors
No 1440X900 Resolution Option in Dis...
By sgills on Jan 24, 2009
I recently purchased a Samsung SyncMaster 933BW 19'' LCD Monitor. It says the recommended resolution is 1440x900, but that option does not show up in the Display Settings. In fact, was does show up are settings smaller & larger, skipping over 1440x900 from 1280x1024 to 1600x1200. The two settings are either too small, or too large, making everything look awkward. I was prompted to install a new monitor driver, SyncMaster 933BW/933GW SyncMaster Magic CX933BW/CX933GW (Analog), and I did - but the settings still do not show up. Any suggestions?
Comments:
Jan 24, 2009
- Windows XP
Jan 24, 2009
- That seems easy enough - thanks. Unfortunately, I'm unable to take the check from the box as the entire section is in gray. Do I have to change another setting to allow for me to alter that section?
Jan 24, 2009
- I actually restarted my computer and *was* able to un-check the box upon rebooting it, but it still did not enable me to get 1440x900, however, the 1280x1024 and higher came back (but 1440x900) did not show. I also tried removing the monitor to no avail. =[
Clarification Request
Posted by Bat1956 on Jan 24, 2009
Which operating system?
Solution #1
posted on Jan 24, 2009
Not Rated)
Bat1956
Rank: Guru
Rating: 89%, 325 votes
Windoze is not detecting the monitor correctly. Right click the desktop as you had before to get to the display settings. Click the "advanced" button at the lower right, on the next window, click the "Monitor" tab, and remove the check from the box from "Hide modes that this monitor cannot display". That should add to the settings the 1400 X 900 resolution you are looking for.
Comments:
Jan 24, 2009
- Ok, another approach, go to the device manager and remove the monitor. See if it detects it correctly upon reboot.
Jan 24, 2009
- The limitation then must then fall on your display adaptor. Check that manufacturer's website for a newer driver.
Was this helpful?
Yes
No
Popular Solutions for Monitors
Questions and Unsolved Problems for Monitors
Answer
I need a monitor to work on a old industrial machine it must be vga compatible
Answer
Monitor has just died....tried usual...there is power, removed monitor plug....no box with 3... (More)
Answer
power switch is stuck(broken) on Dell 1707FPc LCD monitor. How can I fix or override?
Answer
I have a Samsung SyncMaster 931c monitor (2.5 yrs old). Sporadically during the last month, I'd lose... (More)
Answer
can i add speakers to this monitor? the audio it comes with is subpar
Describe your Monitors problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Monitor Experts
Top Computer & Laptop Repairmen
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
