Question about Texas Instruments TI-84 Plus Calculator
How can i make my TI-84 Plus calculate the MR=MC.
I know that i have to solve the equation but i dont know how. The equation is -0,1Q+118,5 = 0,02Q+15. Would like to have an example and guide.
    Sergeant:
  • Texas Instru... Expert
  • 261 Answers
It is easy to find solution for this problem. Type solve(0,1Q+118,5 = 0,02Q+15,Q)
See captured image below
How can i make my TI-84 Plus calculate the MR=MC. - 1_17_2013_12_17_53_pm.jpg
Posted on Jan 17, 2013
SOURCE: how to restore applications on TI-84 Plus Calculator
THIS WILL HELP YOU 4 SHO
the best way to get all your applications back is to link your friend's ti-84 plus and make a file backup, ( do this by first installing Ti graphing Product CD wich is included with the calculator) after this just connect your calculator and store the files back onto your calculator! ZOMG??? IS it that easy???
yes it is, just apply some clear thinking and ull be just as smart as i am
Posted on Sep 09, 2008
  • 21 Answers
SOURCE: TI-84 Plus Calculator will not turn on, says ram is cleared
Thats because the OS is corrupt. Follow the manual and reload the OS, try the 2.43 OS
Posted on Mar 02, 2009
  • 192 Answers
SOURCE: Find the antilog on the TI-84 Plus for finding pH in chemistry problems
I'm not specifically familiar with the TI83 or TI84 but I've used a lot of TI calculators in my time, so I'll give it a try. If your trying to find the antilog of a number in base 10 enter the number and hit the (10 to the X) button. If you're trying to find the antilog of a number in in base e (natural log), enter the number and hit the (e to the X) button.
Posted on May 29, 2009
  • 88 Answers
SOURCE: TI-84 calculator root problem
Press 4 then press math. Select #5. You'll be back at the home screen now type 90 and press enter. You can use this for any root.
Posted on Aug 06, 2009
  • 7993 Answers
SOURCE: TI-84 Plus LCD display broken. Is replacement available?
Contact ti-cares@ti.com or www.ti.com/calc .
Hope it helps
Posted on Oct 25, 2009
Equations
You can't simply enter 7x+9=30 into the calculator, there is a way to calculate what the x is but its been a few years since I've done these..
Oct 03, 2008 | Texas Instruments TI-83 Plus Calculator
Solve for x: x/3-1/5=4/3
Press [math] [0] to put the calculator into equation solver. Then you input your equation in 0 = format. So, the equation x/3 - 1/5 = 4/3 would be input as 0 = x/3 - 1/5 - 4/3 . Then press [enter] .
Apr 05, 2011 | Texas Instruments TI-84 Plus Calculator
2c + 6 + 7c = 8
To solve this with a ti-84 press [math] and select solve from the menu. This will open the equation solver. Type in your equation
(Note: you may need to put it in the form with 0=, So the equation would be 0 = 2c + 6 +7c - 8 ). Then press
enter or arrow down button.
Mar 30, 2011 | Texas Instruments TI-84 Plus Calculator
How do you enter the "plus or minus" sign into the y= of a ti-84
The calculator cannot handle "plus or minus" in the same equation. If you need both, enter two equations into y=, one for plus and the other for minus.
Feb 25, 2011 | Texas Instruments TI-84 Plus Calculator
5/4x-18=-3 Ti 84 plus One: just press enter/solve Two: press 2nd Test (Math) then press enter Every time I put in and equation using the above method for the equal sign. it either takes me back to...
If you wan to solve an equation using the SOLVE feature you enter it as follows (your example)
You should rewrite it as 5/4*X-18+3 (= 0). Implicitly, the calculator assumes that the right side is ZERO and you do not enter any right side nor an equal sign.
Type in
5/4 [*] [X,T,theta, n] -18 +3 [ALPHA] [ENTER] (SOLVE)
You should get an answer -780/47 or the decimal equivalent (depending on display mode.)
Feb 12, 2011 | Texas Instruments TI-84 Plus Calculator
On the TI-84 Calculator I can't find the = symbol. Not the enter key to find the answer to a simple equations. But if I were to use the Solve(...) option in the Catalog I can't because I can not find the =...
Since you know about the catalog, that is where you find the equal sign, near the bottom of the list. It is faster if you scroll up from abs(.
Hope it helps.
Oct 07, 2009 | Texas Instruments TI-84 Plus Calculator
Getting more than 10 equations into y=
The TI 83, 84 seris can not store more than 10 equations. the TI 86 and above can have infinate, but not the 83, 84s. If you have catalog help in your apps, you can run that, and it will be able to tell you all the syntax of every function it has.
Nov 22, 2008 | Texas Instruments TI-84 Plus Silver...
Graphing
The first solution will allow you to watch your calculator graph two equations simultaneously rather than finishing one before graphing the next; it won't solve the problem of having the calculator unselect one equation when you select a second. To fix that problem, try the following:
In order to select additional graphs, the Transformation Graphing App will need to be uninstalled from the TI-83 Plus Family and TI-84 Plus Family. Uninstalling the App does not erase it from the calculator, it disables it from interfering with the normal graphing modes. Below are the steps to successfully uninstall the App.
  • Press [APPS] key
  • Select Transfrm from the menu
  • Press 1:Uninstall
The illustration and solution are courtesy of Jesse Phillips, who cites this page from the Texas Instruments support site
- doug garfinkel, Children's Day School
Jan 15, 2008 | Texas Instruments TI-84 Plus Silver...
Texas Instruments TI-84 Plus Calculator Logo
115 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
