Question about Kenmore 24032\24036 Top Load Washer
Kenmore 700 trips breaker
I bought a kenmore 700 cu3742152 used, the minute i plug it in it trips the breaker
  • jjones40 Jan 24, 2009
    sorry about this is fault,its a kenmore washer model 11028722700
    President:
  • 1,214 Answers
Sounds like something is shorted in the unit.
Start at the power cord where it plugs into the wall, following down to where it enters the back of the refrigerator and look for any crimped or smashed places that may indicate the hot has come into contact with the ground (center wire.).
From there, you'll need to have basic trouble shooting skills to determine where the short circuit is. It could be the condenser fan, the evap fan, the compressor, or any number of other things.
Posted on Jan 24, 2009
  • Mark Egan Jan 24, 2009
    Same troubleshooting procedure, only now it's the motor(s) or any one of the coils/solenoids.
Dryer blows circuit breaker after running 10-20 minutes.
indicates problem motor , overheating in the wiring or excessive loads in the drier
Jun 07, 2017 | Kenmore Dryers
15 AMP breaker keeps tripping
do a amp check on the compressor and fans.That will tell you exactly what is overloading.
Apr 21, 2012 | Kenmore Freezers
I have a Kenmore model 20802990 washer, it will run for a short while and then stop working, it is almost as if the circuit breaker trips because when I turn the circuit breaker of then back on and switch...
well you right in saying "its triping the braker off" thats what it is doing,,
there is a problem with the washer motor,,its pulling far to many amps so its a fulty motor,,,and it will just keep triping the trip out,,,
its a good job you have trips,,the motor could have gone up in smoke
Jul 15, 2010 | Kenmore 24032\24036 Top Load Washer
Dryer Repeatedly tripping circuit breaker, Apartment Maintenance man said we had a defective dryer, Bought new dryer and 5 minutes after first load was put in it tripped the breaker, Maintenance man...
You probably have a bad plug connection, make sure all the wiring in there is tight, you may see signs of arcing. A bad connection causes resistance, and therefore causes the breakers to trip. It is best to replace the receptacle on the wall outlet with a new one because the problem will just resurface again soon.
Aug 12, 2009 | Dryers
MY KENMORE 1000 WATT LITERALLY WORKED FINE ONE MINUTE THEN NOTHING THE NEXT. I HAVE NO IDEA WHAT HAPPENED.
Most likely the circuit breaker tripped or the fuse blew. A 1000 watt microwave is using 2/3 of the power available on a typical household circuit of 1500 watts. If anything else is plugged into that circuit u can have a problem. Just reset the breaker or replace the fuse and u will be up and running. if it happens alot you should consider a dedicated circuit for your microwave only.
Apr 21, 2009 | Kenmore 62622 Microwave Oven
Kenmore 70 Series Dryer heats for 5 minutes then trips breaker.
Thanks for the question Your problem is with your breaker its weak and wont hold you reset it it works againfor a while Happens a lot When this happens again touch the breaker you will feel its hot also check the connections at dryer and at box where you plug your dryerin see if the prongs of the cord are lost its copper color . thanks for the question the appliance docs
Aug 24, 2008 | Kenmore 63942 Dryer
Tripping circuit breaker
if the dryer trips the breaker right away its a problem with the dryer if its after a while its the breaker. call an electrician to make sure the wires are secured tight to the breaker and the breaker is rated correctly. i can almost guarantee its the breaker.
Dec 18, 2006 | Kenmore Elite HE4 Electric Dryer
Kenmore 24032\24036 Top Load Washer Logo
153 people viewed this question
Sal De
fordexpert
Robert Rankin
