Question about Vehicle Parts & Accessories
Passlock II issues for 99 Tahoe
Engine starts but won't run because of passlock II not functioning right.
Is there an easy fix or shood I try a (bypass). I really don't have the $160.00 to $200.00 to pay a Dealer for 5min. of time. Can you help?
  • 3 more comments
  • pncdangelo Jan 26, 2009
    To answer your question- no it does not have a remote start.
    It is a 99 chevy Tahoe, 5.7 engine, 4x4, 4dr., old body style with keyless entry.
  • pncdangelo Mar 19, 2009
    Hey Guys, Thanks for the feed back and yes I have tried everything out there and then broke down and let the Dealer try to fix it. They checked everything and I mean everything and replaced the Key cylinder and switch, and thought they fixed it. When I went to pick it up, it started all over again. By the way I was not charged a dime for labor or parts,(dealer went out of business and said my gift to you, Sorry). So I made a call to an old friend who knows a few mechanics and they told me to take the Fuel Pump Reley (fuse box under hood) out an slightly sped the pins and put back in, and would you believe it! I haven't had a problem with starting it yet.
    I don't know if this is or was the fix but if it helps anyone else then great. Thanks again guys, everyone here has been greatly appre.
  • deffox11 Apr 01, 2009
    I have a 99 z71 and I pretty much have the same problem. My security light stays on every once in a while and cause of the passlock, my truck won't start. This happens every couple of weeks. I pretty much do as one of the people posted, turning the key and wait about 10 min to reset the passlock. However, I have the viper 5900 alarm and does any one think that there is some miscommunication between the stock alarm and the viper alarm? I had a switch replaced a couple of months ago and every thing was working great, the secruity light did not turn on anymore, but now its back. Could it also be a bad computer?
  • Keith Methot
    Keith Methot May 11, 2010
    have you tried leaving the key on for 20 minutes to reset the passlock??
  • Keith Methot
    does it have a remote start???
Turn key to start position for 10 minutes and it will reset passlock
Or, once you're tired of being stranded for 10 min every 6 weeks or so, try the following:
Here's the "fix" I did for my 99 tahoe. Took the cover off the steering column, unplugged the sensor from the cylinder *while* the car was running. it's a 3 wire plug red w/ white, orange w/black and yellow. From then on, the car will always start and ignore the sensor. The only negative is the security light stays on. Replacing the BCM only postpones it from happening again if the problem is the resistance in the ignition lock cylinder. Check out the following links. Good luck.
http://car.justanswer.com/for/ce07-bypass-lock-sensor-1998-chevy-tahoe
http://general-motors.pissedconsumer.com/gm-passlock-ii-system-has-major-inherent-design-flaws-20080502119601.html
Posted on Mar 18, 2009
    Scholar:
  • 116 Answers
I hate no say it, but it sounds like the passlock computer is bad or going bad. A bypass wold work, but you need to read a value. Even hough the auto learning one are easy, there is no guarentee that it would solve your problem. When you put the key in ignition, turn it on (not to crank) dos the security light start flashing? If so, you need to either wait 15 minutes or wait with the key oon until it stops flashing. Once it stops flashing, try to start again. You should get to try it 2 times before the passlock will lock up again.
Did the problem just start? I put a start in a 99 tahoe, and the guy SWORE that it was my start causing the problem. Si, I took it out and it turned out to be either his key cylinder or the passlock computer.
Sorry for the bad news. Hope this helped just a bit.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Posted on Jan 28, 2009
    Novelist:
  • 355 Answers
There is a definitive solution. A great write-up here: http://newrockies.ca .This was the only way I was able to save mine.
Posted on Jun 07, 2010
I have tried cleaning the contacts on the fuse for that system, it seems to be working for now. It has been an intermittent problem for years. New fuel pumps, etc., but thought I'd try this basic step. Also read that the contacts on the fuel pump relay may need cleaning, but that didn't help in my case.
Posted on Oct 09, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
How to program key to ignition for a 1998 Chevy truck w/vortex v6 engine..I tried it myself an it did crank but will not stay running
Program KEY ? There is no transponder in the key for a 1998 Chevy truck . What problem are you have ,no start ? Is the SECRUITY light lit on the dash ? you don't need to program keys with this ant-theft system .
Vehicle Theft Deterrent (VTD) Operation
The design of the passlock system is to prevent the vehicle operation if the proper ignition key is not used in order to start the vehicle. The mechanical key, in normal operation, will turn the passlock lock cylinder. The passlock sensor will relay the passlock data to theEVO/Passlock module. The EVO/Passlock module will determine the validity of the passlock data. The EVO/Passlock module will send a code password to the vehicle/powertrain control module (VCM/PCM). When the VCM/PCM receives the correct code the VCM/PCM allows the fuel injectors to operate normally. The passlock system requires the VCM and the EVO/Passlock module to communicate the various functions in order to operate. These functions transmit over the class 2 serial data line CKT 1807. For an explanation of the class 2 serial data operation refer to Data Link Communications Circuit Description in Wiring Systems.
Passlock System
The design of the passlock system is to prevent vehicle theft by disabling the engine unless the passlock lock cylinder rotates properly by engaging the correct ignition key. The system is similar in concept to the passkey system. However, the passlock eliminates the need for a key mounted resistor pellet. The components of the system are as follows:
The ignition lock cylinder
The ignition switch
The passlock sensor
The security indicator
The vehicle/powertrain control module (VCM/PCM)
Nov 29, 2015 | Cars & Trucks
The truck starts but it shuts down on its own.its almost like it cuts current right away.
Hi, does the security light flash? Maybe a problem with your Passlock system. See the Passlock section of this post: http://www.ricksfreeautorepairadvice.com/repair-topics/gm-anti-theft-systems
Jan 09, 2011 | 1999 Chevrolet Tahoe
99 Alero Passlock and starting problem
YOU CANT BYPASS PASS KEY ANTI THEFT SECURITY SYSTEM.ITS PART OF THE PCM.IT WAS MADE WITH CAR.THATS WHY YOUR CAR NOT CRANKING.THE SECURITY THEFT SYSTEM SHUT DOWN FUEL SYSTEM.THE DEALERSHIP HAS TO FIX. IF YOUR IGNITION SWITCH KEY CYLINDER LOCK OR KEYS ALSO THE BCM FAULTY.THE DEALERSHIP HAS TO REPLACE FIX THEM AND REPROGRAM TO PCM IN ORDER FOR CAR TO CRANK.
Jun 26, 2010 | 1999 Oldsmobile Alero
1996 buick skylark..alarm theft keeps flashin..try to start..it turns but wont stay running..
Need a bit more information, Is the security light on, have you checked for spark and fuel pressure, just in case you did and know it is the passlock system then check this out, hopefully it will ansewer your problem, please rate your mechanics help.
have a great day. Sorry the pictures won't come up, but check out the site
GM Passlock I & II Information
Please study the following information carefully WHEN INSTALLING REMOTE START systems on a 1996 or later GM car or truck.
Introduced in 1996, GM has changed the VATS anti theft system to Pass-Lock system. This is a similar device to the VATS system, in that there is a resistor present during the start cycle. However, in the PASSLOCK system, the resistor has been placed inside the ignition switch, instead of the key. See the GM V.A.T.S page for more information.
To remotely start a car with this feature, you must bypass the PASSLOCK system. There are two methods of doing so.. The first, is to permanently bypass this system. This is the easiest method for accomplishing your task. The second way, is to temporarily bypass the PASSLOCK, by introducing relays into the system, which retain all of the features of the system, while allowing your remotes start module to bypass it automatically during a remote start cycle.
Vehicles effected
(1996 and newer): N & J body cars, such as
Pontiac Sunfire and GrandAm Passlock-1
Chevrolet Cavalier Passlock-1
Buick Skylark Passlock-1
Oldsmobile Achieva Passlock-1
1997 or newer
Chevrolet Malibu Passlock-II
Oldsmobile Cutlass Passlock-II
1998 or newer
All trucks , SUVs and Vans Passlock-II
It is important to pay special attention to the fact that there are many different ways of achieving the same goal. There are actually 2 different Passlock-II systems. On the next page, there are tests to establish which type of passlock-II your car has.
Relays shown are standard automotive 5 pin spdt relays, available from IEI.
A multi meter is required to measure the resistance values. Accuracy is important within 5%.
Once the value of the resistor is measured, a resistor of the same value +/-5% must be purchased (Radio Shack2.gif, for example). You can also use a Potentiometer (POT), which can be adjusted to the same value of the resistor in the ignition switch.
pslc1.gif Passlock-I bypass procedure....
1: Remove the top and bottom shrouds from the steering column.
2: Find the 3 wire ribbon cable2.gif, coming from the ignition switch, containing White, Black, Yellow (Sometimes White, Black, Black). These are THIN wires.
3: Locate the Black 6 position connector on the LEFT side of the steering column, right above the ignition switch position. There is a BLACK (Thin) wire in this connector, called "Bulb Test", which shows Ground with ignition in the Off position, OPEN in the "Run" position, and GROUND in the "Crank" position.
4: Turn the ignition switch to the "Run" position. Do not crank the car.
5: Cut the Thin Yellow wire and strip both ends.
6: Without cutting the Black wire, expose some of the copper.
7: Using the ohmmeter, measure from the Yellow wire (the end coming from the ignition switch), to the exposed Black wire and record the value. Measure more than once to assure you have the right value.
8: Acquire the same size resistor and 3 relays, and perform the connections shown in the diagram below.
pslk2.gif PASSLOCK-II bypass procedure
There are 2 types of Passlock-II systems. To determine which system you have, follow these instructions;
1: Locate two wires, which are THIN and are in the main ignition harness.. Orange/Black (or Black) and Yellow.
2: Cut the Yellow wire, and strip back some of the insulation from the Orange/Black (Or Black) wires.
3: Turn the ignition to the "Run" position ( don't crank the starter). Measure and record the value measured from the KEY SIDE of the Yellow wire, to the Black/Orange wire.
4: Turn the key to the "Crank" position and release. Now read the value again.
pslk3.gif5: If the value changed, follow "Method#1". If the value stayed the same, follow "Method#2".
These diagrams are from our friends at ALARMTEK AUTO ALARM
Need additional assistance?
Oct 22, 2009 | 1996 Buick Skylark
My son has a 1999 grand am, just like the oneshown above. the car wont start because the security sys. shuts off the fuel sys. down. the manifold still has good pressure cause we just had thefuel pump...
Need a bit more information, Is the security light on, have you checked for spark and fuel pressure2.gif, just in case you did and know it is the passlock system then check this out, hopefully it will ansewer your problem, please rate your mechanics help.
Introduced in 1996, GM has changed the VATS anti theft system to Pass-Lock system. This is a similar device to the VATS system, in that there is a resistor present2.gif during the start cycle. However, in the PASSLOCK system, the resistor has been placed inside the ignition switch, instead of the key. See the GM V.A.T.S page for more information.
Vehicles effected
Chevrolet2.gif Cavalier Passlock-1
1997 or newer
Chevrolet Malibu2.gif Passlock-II
1998 or newer
Once the value of the resistor is measured, a resistor of the samevalue +/-5% must be purchased (Radio Shack2.gif, for example). You can also use a Potentiometer (POT), which can be adjusted to the same value of the resistor in the ignition switch.
Oct 05, 2009 | 1999 Pontiac Grand Am GT
Why the 1500 silverado does run good but stalls and then after turning the switch of and recrak it does starts ,runs good for a few minutes and stalls againg? note I replace the fuel filter but did not...
If it is your security system you might want this, and please rate your mechanics help, Have a good day.
Vehicles effected
1997 or newer
1998 or newer
Once the value of the resistor is measured, a resistor of the same value +/-5% must be purchased (Radio Shack, for example). You can also use a Potentiometer (POT), which can be adjusted to the same value of the resistor in the ignition switch.
2: Find the 3 wire ribbon cable, coming from the ignition switch, containing White, Black, Yellow (Sometimes White, Black, Black). These are THIN wires.
Oct 02, 2009 | 2000 Chevrolet Silverado
1999 won't start when security light is on.
If you would like to bypass the system I found this, Good luck and please rate your mechanics help.
Vehicles effected
1997 or newer
1998 or newer
Sep 26, 2009 | 1999 Pontiac Grand Am GT
Ignition passlock sensor
have a great day.
Vehicles effected
1997 or newer
1998 or newer
Feb 24, 2009 | 1998 Pontiac Sunfire
Passlock
While I've never had this issue, the fix is pretty easy:
  1. Turn car to ON position (without starting it)
  2. Leave in that position for 15-20 minutes
  3. Turn off.
  4. Start car.
This issue is with the PASSLOCK system in the car.
Nov 30, 2008 | 2001 Oldsmobile Alero
Vehicle Parts & Accessories Logo
5,616 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
