Question about Maytag Neptune Washing Machines
Whats wrong when vibration problem when on final spin
  • Maytag Master
  • 17,130 Answers
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Posted on Jan 17, 2013
2 Suggested Answers
Macmarkus
  • 2605 Answers
SOURCE: Final spin making very loud noise vibrates with
Open the door and see if the basket has any up and down "play" in it. what you're doing here is checking the rear bearing assembly. There should be no "play"/movement (other than the entire tub assembly moving on the shocks/springs obviously). the rear bearing in any front load machine has practically zero tolerance. meaning it shouldn't knock when spinning, or have movement in the basket if you try to move it with an up & down motion.
If you DON'T have nay unwanted motion, make sure you are using the right detergent, that the unit is sitting level on all four feet/legs, and that the shock absorbers and springs on the tub aren't broke or seperated from the cabinet.
If you DO have unwanted motion/up & down play, you may want to consider a new washer, unless you have extended warranty or canet a could "used" one for parts.
Also check for any signs in the cabinet for pieces of concrete from the counterweight at the front.
At this point, before removing any parts/panels etc. **Unplug the unit from the wall**
You'll need to remove two screws at the bottom in the front to remove the lower panel for checking the shock's and counterwight, and remove the top to check the springs. There are two or three screws at the top in back to remove the top panel.
hope that helps,
Good Luck :)
Posted on Oct 29, 2009
Frigidaire fws747rfs1
The washer tub bearing may be defective, but that is the only thing that I can think of. Are you noticing this on all loads or just heavy items like bath towels and jeans? Are you redistributing the clothes before the final spin, try that. Also do not overload the washer, wash to medium loads instead of one full to the top load. Wastes water but saves on repairs.
Apr 12, 2017 | Washing Machines
In the final spin the washer is so loud you can't stand by it what is wrong with it
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 07, 2010 | Maytag Neptune MAH5500B Front Load Washer
On spin cycle machine vibrates and makes a load banging sound especially on the final spin.
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 14, 2010 | Washing Machines
I am getting a vibrating noise from my washer right before the final spin. Levleling looks good. This happened a couple days ago. We drained out the water and the washer would work again, but would stop at...
It sounds like you could have multiple issues but a possible cause of the vibrating right before the final spin is a broken shock absorber if one or both are gone it will throw off the center of gravity inside the machine and allow it to move freely and at high speed or even low speed this is not good. part number for both shocks is 134560400. If your machine just stops before the spin cycle and only drains, you could have a faulty door switch. the washer will not spin for safety reasons if this is gone. part number for the door lock switch is 131763245. as well the striker that hits this door switch can be broken and sometime pieces will be left inside the mechanism. part number for the striker is 134456640. The last cause of your washer not spinning could be a motor speed control board, if this is faulty, the motor will not receive the proper amperage to send the motor into spin cycle. speed control board part number is 134409904. Hope this helps.
Thanks
Oct 12, 2009 | Frigidaire Affinity ATF7000E Front Load...
FRIGIDARE FRONT LOAD WASHER,2+YRS OLD ON FINAL HIGH SPEED SPIN MACHINE MAKES LOUD VIBRATION NOISE AND FIND NEED TO SHUT DOWN DUE TO FRANTIC VIBRATION AND NOISE.
It is possible the bearings on the motor that spins the canister could be going bad especially at the high speed. This could also be from clothes getting unbalanced in the final spin cycle. Hope this helps. This could still possibly under warranty!
Aug 22, 2009 | Washing Machines
Washing machine vibrates really bad during the final spin
make sure your machine is level in both directions
Apr 02, 2009 | Admiral AW22 Top Load Washer
Hotpoint WF100 Vibrating on final spin or fast spin
Hi Clive, if you look under the drum you will see two damper legs which are secured to the drum and the chasis, you will find that one or even both of these are defective, what happens is that one packs in and puts double pressure on the other resulting in that breaking down. take them off and examin them, they should both have a resistance to a fast pull, and should move quite easily with a steady pull applied.
Good luck hope it works.
Mar 06, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Won't drain or spin out
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Dec 12, 2008 | Danby DWM99W Top Load Washer
Excessive vibration during spin cycle
If this is the only problem be thankful ,its capable of a future of problems. I my self would not recommend putting 1 more dollar into this machine.Your next concern is a high dollar repair that may be soon coming ,that is a circuit board problem.
Please rate this !!
Jun 09, 2008 | Washing Machines
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
