Question about Dryers
I have an Admiral ADE7000AWY dryer and it wont start.
I have an Admiral ADE7000AYW (Model #) Dryer and it wont start. This happened suddenly. I dryed a load, loaded the next load and the second load wouldn't start. I checked the terminals inside the back, where the AC line cord terminates, and I have 240V across the top and bottom terminals as I should. I checked the door switch and its working properly (no continuity when the door is open - short when the door is shut.). I've check the Thermal Fuse and its good (disconnected one of the terminals and checked continuity-shows short as it should). Where do I go from here with the troubleshooting? Is it likely going to be the cycle selector thats gone bad that quickly?
  • Daniel Hodgen Jan 16, 2013
    By the way, the momentary start switch is part of the cycle selector - just push the cycle selector knob.
    The Resistor (3.77K Ohms) checks out good to @ 3.77k or so
  • 3 Answers
SOURCE: My admiral dryer LNC7753A71 just
Your dryer is equipped with a thermal fuse located behind the drum seat on the heating coil.
http://www.applianceaid.com/la-1053.html
There are two white wires connected to the fuse. Pull those off and connect together. Your door light will come on if that is your problem. There might have been a problem that caused the fuse to blow. Check for kinked dryer hoses, dirty lint traps or anything that might have caused it to overheat. You must replace the fuse or you risk catching the dryer on fire.
Posted on Mar 09, 2009
watugot
  • 290 Answers
SOURCE: 196 degree non resettable thermal fuse
That is the thermal fuse. It must read closed for the dryer to work. You can connect the two wires together to check the rest of the system, but don't run it with them crossed for normal drying. Many times this is an indication that the high limit switch is sticking or the duct is clogged with lint causing a high temp situation.
Post back if you have any questions.
Posted on Nov 07, 2007
dinomb
  • 16 Answers
SOURCE: Maytag Electric Dryer Stopped Working
Check spring tab behind door switch-if it's bent/out of adjustment, circuit will act like door is always open.
To confirm this, open door, set dryer to active setting, and hold in door switch; if it comes on, then it's either the spring tab, or the switch is malfunctioning
Posted on Mar 30, 2008
  • 172 Answers
SOURCE: whirlpood dryer Model LER8620pwo Above
Pull the dryer out and unplug. At the bottom left of the back you will see your blower housing. on it you will see a 1 inch by 1/2 inch white thermal cut out. This is the part you are looking for. it is part number 3392519
This part is available and cost$18.00 to ship it to your door.
Mike Anderson
Anderson Appliance Repair
(865)945-3808
Posted on Dec 02, 2008
SOURCE: Maytag Performa PYE2200AYW Dryer Heats intermittently
i had the same problem with my dryer and i installed the wrong thermal fuse for gas dryer which calls for a pink thermal fuse in which i installed and it works fine also check the lint in the front of your dryer. also my dryer which is the same make as yours seems will run on the fluff cycle until i replaced the right thermal fuse. my dryer run exceptionally hot and eventally shut down and it only run on the fluff cycle for any length of time.
Posted on Sep 22, 2009
Dryer wont start
You need to have someone check it.
It could be anything from the switch on the door latch to a bad timer...
Feb 23, 2014 | Maytag Dryers
Admiral Dryer Model #AGD4475TQ No Heat
This is very rare on a gas dryer but I have seen it. If you have already replaced all that other stuff I would say it has to be inside the timer. On one I worked on once I could remove that orange wire and the dryer would function ok so I ordered a new timer, they sent me a bad timer. Same problem. I finally got a working timer after going through a bunch of mess. That fixed it. So if all the other components are working it very well could be the timer.
Dec 02, 2013 | Admiral Dryers
Admiral dyer model ade7000ayw wont make heat
You will need to replace the heating element and the thermostat. They come in a kit and is a simple job to replace them. Here is a link to the kit.
Oct 14, 2012 | Admiral Dryers
Dryer suddenly stopped heating
Heating element, thermostat or thermal fuse
Feb 24, 2012 | Admiral AED4475TQ
ADMIRAL ADE7000AYW This dryer will not start at all. Light inside is not on. There is power at the plug. Is there a internal breaker
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 18, 2011 | Dryers
Admiral 6.5 Cu. Ft. Super Capacity Electric Dryer not drying load
does the admiral aed4475tq have a reset button it will not turn on it is only 9 months old
Nov 29, 2009 | Dryers
Admiral Dryer: 5 cycle 3 temperature electric
Unplug Dryer
Remove back (many screws)
Clean lint from interior & Vent Chute
check for breakage & parts on dryer floor
check for burn damage (wires burned off or char)
if no burn or char:
could be the "Dryer Coil" itself broke or
a "Snap Disc" usually mounted on the coil housing.
Very Serious!!!! Replace only!!!! Do not ever bypass!!!!
Stay clear of dryer for test start
Be ready to shut it down fast in case of problems
Always replace back & vent chute
Good luck,
Vinnie
Jun 17, 2009 | Maytag Neptune MDE5500AY Electric Dryer
I have a kenmore electric dryer it worked fine i dryed a load of clothes in it and went to dry another load and it wont turn on i set the knob to tempature to dry my next load and push the start button and...
This may be a thermal overload switch which is probably located underneath the top of the dryer. When you find it, bypass it to see if that is the problem. If so, replace it for about 10-12 dollars. Check the breakers first, then the connections in the back to see if they are secure.
Dec 29, 2008 | Kenmore 659 Electric Dryer
Dryer not starting
Dryer needs a new motor. I changed the thermal fuse and the dryer worked for a minute then stopped without the ability to restart.
Jul 05, 2008 | Dryers
Dryers Logo
73 people viewed this question
Top Dryers Experts
