Ive recently purchaseda second hand phone and ive set it up well as i thought but i put in my trusted number as my mobile and not as a another number, and also its not reconsing my security code that i set up. so im in a mess as if i take the battery out or sim it will lock. PLEASE HELP.
SOURCE: Resetting Security Code
i have nokia 1112
my imei no is 354573018881860 i want to reset my code
SIM pin code:
This is a pin code that locks the sim card until you enter the correct code. This protects your account, even
if your sim is put into another handset. To reset it, you need the PUK code:
Pin Unlock Code (PUK)
If you miss key (or forget) your SIM pin code, and enter the wrong one 3-5 times in a row, the SIM will lock up, and you’ll need to enter the PUK unlock code to release it. You should ask your Network Service Provider for this code when you need it. Don’t try to guess it, because after a few wrong guesses, the SIM card will be permanently disabled.
Phone Security Code:
This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a “new” sim if the phone security code is entered. To reset it, you need the Master code code:
Master Reset Code
Sometimes known as the Master Code, this allows you to unlock a handset if you have entered the Security Code wrongly too many times.
Which is the one that you want?
The default security code for Nokia is 12345
as of mine losing security code a big problem the only solution for this, reformat the mobile to clear the old file.
Hello
You can generate the code by using this tiny software.Just follow the procedure.
1.
Downoad [ANT] Simple Ant Simple.zip
2.
If you have Nokia PC Suite running, be sure to close it by exiting from the
taskbar icon.
3.
Extract [ANT] Simple ] and run Simple.exe located in the folder
4.
Connect the phone via USB to the computer by selecting Pc suit/Ovi suit when
prompt a message in your pone.
5.After
you've connected your phone, Click "Read Info"
6.
On the MAIN tab, click on GET. Your phone IMEI number and model should be
displayed on the bottom panel
7.
Now click on the SERVICE tab and click on GET button under USER CODE
8.
Your security code should now be displayed on the right side of the application
window.
If you could not understand follow this How to Generate Your Phone Security code..Only for Nokia bb5 after this format the phone by using the code.Good luck
Thanks For visiting Fixya
