Need owners manual for Primus Duo-Flow Ten Propane Heater
4 Suggested Answers
baugh55grfmj
  • 225 Answers
SOURCE: Propane Tank Size needed for Reddy Heater TB101
Yes it will work but it will heat more efficiently with the 100 lb tank
Posted on Jan 05, 2010
  • 77 Answers
SOURCE: gas flow
sounds like a ad thermocouple.
Posted on Jan 22, 2010
mxc2
  • 146 Answers
SOURCE: I am looking for a downloadable owner's manual for
http://www.cozyheaters.com/pdfs/products/parts_manuals/direct_vent/direct_vent_all.pdf
www.cozyheaters.com
This should be the download you are looking for.
Thanks
Mark
www.allpartsinc.com
Posted on Dec 28, 2010
Cannot get it too light
PDF]operating instructions and owner's manual - Rural King
www.ruralking.com/.../MH9BX_Portable_Propane_Heater_Manual.pdf
light, adjust or operate the heater. PORTABLE PROPANE HEATER FOR RECREATIONAL AND COMMERCIAL USE. MH9BX. Model #. 02/09 32030. MR.HEATER, INC., 4560 W. 160TH ST., ... Get fresh air at once! Have heater serviced. speciFicatiOns. MODEL NO. .... Some people cannot smell well. .... Buddy series hose.
Mr. Heater Portable Buddy Propane Heater - Bass Pro Shops
www.basspro.com/...Heater-Portable-Buddy-Propane-Hea...
Bass Pro Shops
Feb 03, 2016 | Mr Heater Base Camp Portable Buddy Propane...
I have a reddy heater rlp30 propane forced heater 30,000 btu. Heater lights ok but will not stay running unless i hold red bypass in, when i let go the heater goes out. Do i need a thermocouple or...
achowe - Several things can cause what you have described.
Restricted air flow. Check the heater's inlet & for any obstructions.
Damage Fan - check the fan for any obvious damage.
Excessive dust or debris inside the heater or in the surrounding area.
To help you more, I am including a link to the Owners Manual for your heater. You can download and print it for future reference. If you find you need to order parts, they can be found online at Master Distributors. They stock all the parts for DESA/Reddy Heaters.
http://www.desatech.com/manuals/Construction%20Heaters/BLP42A.pdf
Hope this helps you solve your heater problem.
Apr 10, 2011 | Heating & Cooling
My reddy heater RLP 100 would not stay lit after I released the ignitor switch so I changed the thermocouple and, the thermal unit switch. The heater will ignite but when I release the knob the flame goes...
A couple of things come to mind:
Restricted air flow. Check heater inlet and outlet. Remove any obstructions.
If the heater has been used in a dusty environment, it may simply need a thorough cleaning.
Inadequate propane supply. Make sure there's enough gas in the tank to facilitate combustion.
If the tank is full, turn of the tank valve and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose. Turn the tank valve on very, very slowly, until it's fully open and try relighting and operation of the heater.
If you have misplaced your Owners Manual, you can find it at www.deastech.com
Hope this helps to solve your problem.
Mar 02, 2011 | Reddy Heater RLP100 Portable Forced Air...
Need flow rate and pressure adjustment proceedure for an old raypack 266 not electronic.thanks murray
The maximum flow rate for that heater to be installed in without a bypass is 125 GPM. The owner's manual can guide you thru gas pressure adjustments or adjusting the set point of the water pressure switch. Please note that unless you are installing the unit below or significantly above the water line you should not have to adjust the pressure switch. Whenever you do adjust it, be certain to turn the pump on and off several times to be certain the heater reacts to the pump condition...failure to shut down when the pump does can be a serious and dangerous condition.
Dec 15, 2009 | Raypak Millivolt Gas Pool Heater 266,000...
It heats the pool but the hot tub gets warm for ten min then the heater shuts off ???
ARE THE TEMPETURE SET HIGH IF YES THEN THE FLOW VALVE IS BAD . WHAT ABOT THE FLOW TO THE SPA CHECK THE PRESSURE READING WHEN SWITCH FROM POOL TO SPA IF VERY HIGHT THE JETS MAY BE PLUG MAKING THE FLOW TO SLOW FOR THE HEATER TO WORK OK
Dec 01, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Propane heater has spark but wont light
ODS/Pilot may be clogged make sure you clean it out according to the instructions in your owner's manual. If you need a copy of the manual let me know and I will try to find it for you. If it is still not working it could be the gas regulator or the ignitor cable. For Glow warm parts contact Master Parts at 800-446-1446 or you also can find them online at www.masterparts.net. I hope this helps you!
May 04, 2009 | Desa International Blower Glow Warm Wall...
Pool heater will not come on
There is an extensive troubleshooting flow chart in the owners manual for these pool heaters that will answer this question better than we could. It has many steps that you must check to come to a solution. The link below is to a pdf of the manual. Try that and I bet you find your solution.
http://www.backyardcitypools.com/Pool-Heaters-Main.htm
Apr 24, 2009 | Pentair MAXITHERM 333K BTU PROPANE GAS...
Procom ML300TBA Heater: Liquid or Gas
Propane exist in a liquid state when it is under pressure in a propane cylinder. When the valve on the propane cylinder the pressure on the liquid is reduced and the propane reverts back to gas state.
Also, regarding the tank you need....
the owners manual probably states what size you will need but, with most heater like the one you have it will require a 100 lb tank (approximately 25 gallons). You will also need an inline regulator set to 11" to 14" of water column between the tank and the heater.
Jan 09, 2009 | Procom ML300TBA Heater
Heating & Cooling Logo
137 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
