Question about Tivo R54040 140-Hours Video Recorder
Connecting DVR to laptop using HDMI
Hi, I'm trying to connect my Motorola DCH6416 to my laptop using a HDMI cable. Can you help me on what I need to do. I'm trying to back up of a program I recorded on there by using a laptop or even a VCR just any information can help. Thanks!!!
SOURCE: DVR recording of off-the-air television signals
TiVo works with 'off the air' TV watchers as wellNot really worth the extra money though if you just have VHF and UHF channels.
Posted on Jun 05, 2008
SOURCE: TIVO DVR : Won't Change Channels
Set up your infrared blasters connected from your IR port on the Tivo and by placing the two lead lights in front of your cable box so it (the cable box) can read the signal.  Then go to Channel settings accessed through Tivo Central and follow the questions. It will ask you to change channels until the remote is working correctly.  This all worked on a different "input" on my Mitsubishi TV (it has multiple inputs.  I have the cable input on a different "input" to make it work.  Hope this helps.  Call TIVO tech assistance because they are the ones who talked me through this.
Posted on Jan 15, 2009
SOURCE: hooking up laptop to hdtv with hdmi cable
Only if your graphics card can handle HD viewing
Posted on Mar 07, 2009
  • 34 Answers
SOURCE: my tivo HD is not broadcasting or recording in HD
I would agree with mjjdesigns. You will likely need to get a cable card, which luckily the Tivo supports to receive the HD signal. Your Tivo may be able to receive the channels without the Card, though I have found that they are often mapped to funny places, for instance on my network, Channel 3 which reports as cable channel 403 with the CableCARD, shows up as 84-3 on the TV and Tivo if not tuing through the CableCARD.
It is possible that you think that you are getting an HD signal through the TV just becuase it is showing up in the 16:9 format. Unless you are tuning to an HD channel (such as 3-1 or 5-1) it is standard definition being stretched to fit your screen. Your Tivo can do this to by pressing the Aspect button on your remote, but it still won't be HD.
Also, if you do get a CableCARD from the cable company, be sure to ask for a multi stream card so that you only need one card and can tune to cable channels on both tuners. Also, I know that the cable companies have often had significant trouble getting CableCARDS to work with the Tivo. Be patient, it is often the Cable Co's fault but they typically pass the buck first to Tivo. Tivo has a hotline established for the sole purpose of working with the Cable Companies to make the cards work in their devices. If you wind up in the situation, call Tivo Customer Service and ask for this hotline.
Hope this helps - Flub
Posted on Jun 02, 2009
SOURCE: Can't get Slingbox remote to work on DCH6416 DVR
Try using the QIP6416 (DVR) model to run it. very similar remote, most remote buttons the same only missing the page and day buttons. Otherwise not sure the problem.
Posted on Oct 04, 2009
I need the exact location of the IR sensor on the front panel of a Motorola DCH6416 cable box.
Do this like mine sweeping. Grab the remote and put it right up to the front of the box. Press the channel up or down keys as you move the remote across the front of the box. You'll get to a point where the box responds well. Then as you go past the point the box will stop reacting so well. Home in to the point where the box responds well. That's your point for the blaster.
Sep 14, 2014 | Arris Dch6416 Dual Tuner Hdtv Dvr Hdmi...
My dch6416 will only display a zero?
Sounds like the program may be hung up. First try a hard reset which means you need to unplug it from the power strip. Wait 15-20 seconds, then plug it back in and see if that resets the program. If that doesn't help, try the 800 number that you used when you first turned it on out of the box. Lastly call your cable provider.
Feb 13, 2014 | Arris Dch6416 Dual Tuner Hdtv Dvr Hdmi...
Denon AVR-4306 + Motorola DCT-6416 Blanking
Hi Jim,
I tried connecting my dvr via component and optical to see if it was my hdmi or my dvr. Ended up being a bad hdmi plug in back of my amp. I was fortunate enough to have both style connections on my dvr. Hope this helps
Turk
Oct 13, 2009 | Denon AVR-4306 Receiver
Sep 19, 2009 | Motorola Televison & Video
HDMI connection not working
I have a DCT6416 which is essentially the same unit but with a bigger hardrive. I just had the same problem and was able to fix it.
First connect your DVR to your TV with the composite RGB cables and disconnect the HDMI. Then power your unit on. Then power it off (using the power on the DVR not a remote) and immediatly press the menu button on the DVR (not the remote). A white screen with black writing will come up. Using the down arrow buttons on your DVR go to the bottom line where it says "reset factory default" Toggle down to that and then use the right arrow key and your settings will be reset. Then exit out of that by powering off. Now remove your composite cables and replace the HDMI. You should be back up and running.
Feb 06, 2009 | Arris DCT6200 DTV Receiver
Having problems with HDMI connection from COMCAST Motarola HD Dual TUNER DVR HDMI DCH6416 to Panosonic Home Theater system SA-PT660 to AKAI LCD HDTV. There is only one HDMI Output on the COMCAST box; one...
Connect the HDMI outputs on your various components to the HDMI inputs on your receiver. Connect the HDMI output on the receiver to the input on your TV. HDMI incorporates digital audio, so no need to buy optical audio cables. If your receiver does not have HDMI inputs for all your components, you will need to make a choice. HDMI = Best, component video + optical audio = second best, S-video+ optical audio = third best
Jan 01, 2009 | Onkyo TX-SR606 Receiver
How to Hook up HDMI from Comcast Motarola Cable Box
Connecting HD cable box to DVR too HDTV
When I hooked up my HD cable box using an HDMI cable, I had to go into the cable screen menus and select HDMI output. You may have to do something similar when using an S-video cable. Your DVD recorder doesn't seem to have an HDMI input, so you'll have to use the S-video or (worst case) composite video (red, white, yellow cords). Your cable box may also be scrambling the signal so that you can't record. That may be why you can record by bypassing the cable box.
Jun 22, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Tivo R54040 140-Hours Video Recorder Logo
902 people viewed this question
Top Tivo Televison & Video Experts
Computer Repairing
Computer Repairing
Dave
Dave
Level 1 Expert
Are you a Tivo Televison and Video Expert? Answer questions, earn points and help others
