Question about SanDisk Ultra II 4GB Memory Stick PRO Duo Memory Card
How do I format the card?
Do I put the card in the memory reader and hook to the computer? When I put it in the camera it says the card needs formatting but the camera can't do it for me.
  • 46 Answers
When you plug the card into your computer, open my computer. After you have done that find the card and right-click on the care and select format. Format the card to NTFS or FAT, click start and that should solve your problem.
Posted on Jan 24, 2009
  • 684 Answers
K in this case just insert the memory card inside the card reader...........
Connect the card reader to the computer...........
Go to My Computer..........
Right Click On Removable Drive/Disk which is the Memory Card................
Click On Format.............
And now click on start as soon as it is finished just remove it from there and use it........
Good Luck
2 Suggested Answers
  • 103 Answers
SOURCE: formatting sandisk
try formathing the 2 GB card with fat.
Posted on May 06, 2009
Hi, Our daughter has a Samsung ES30 12.2 megapixel camera. I just put a new sd card in and it says Card Error, When you click on OK, it tells you to 1. Turn the camera off and on again, 2. remove and...
You need to format the card.
Insert the memory card into the system and this will be displayed as the mass storage device in my computer. Right click over the removable disk and then click format. It will format the memory card.
Then insert the memory card into the camera. Now the camera will not show the error message.
Hope this helps.
Shane
Apr 04, 2011 | Cameras
I work for a school bus company and we have a camera system installed on our school buses that uses a 32 gb memory card. I also have a Dynex 6 in 1 memory card reader. When i hook up the reader to my...
You need a memory card reader that support SDHC formats - all SD cards bigger than 2GB are the new SDHC format. Most new readers will read SDHC. Any reader old enough to be "6 in 1" type doesn't support SDHC. You can get very cheap readers from eBay.
Mar 18, 2011 | Dynex External USB 2.0 Multiformat Memory...
My c330 kodak easy share reads memory is full whenever i turn it on
If the memory says it is full when not, reformat the memory card. Take out the memory card and put it in a card reader. Hook it up with your computer. Go to My Computer. Look for the card reader. Right Click on it and click FORMAT.
Formatting option is also available in the camera menu.
Oct 23, 2010 | Kodak EasyShare C330 Digital Camera
I wud like 2 format another memory card in my qv-r61 but wen i put the card in i can get nothing onscreen to set it up any ideas? it is a Fuji memory card and when put in the camera all i have got onscreen...
Hi, have you tried using your computer to format the memory card, what you need to do is put your memory card into a memory card reader then wait a minute then open up my computer then locate the memory card then right click on it with the right button on the mouse then choose format and format it to fat32 then try it in your camera and it should then be working.
if you have been using a memory card in the camera and still have it then put this in the memory card reader and go to my computer and then right click on the memory card and select properties and have a look at what format that memory card is, and if its anything other than fat32 write down what it is.
Then put the new memory card into your card reader and goto my computer then right click with the mouse then choose format and then choose to format it to the same type as the other memory card thay you know works in the camera, once you have done this the memory card should work in the camera with no problems.
until you have formatted the memory card to the correct type it wont be recognised by your camera so give it a try what i said and you should find you will have no more problems ok.
let me know if you need further assistance ok
Jul 02, 2010 | Casio QV-R61 Digital Camera
How do I format a memory card for a digital camera?
if you have a card reader put memory card in card reader and go to your computer choose the card reader and then choose format. in the camera turn on go to menu choose setup and go to format then choose memory card and then press ok.
Apr 03, 2010 | Kodak EasyShare C643 Digital Camera
When I install my Memory Stick Pro Duo 8GB in my camera it will format and take and store photos fine 1460 total. I then try to put the Memory stick in my card reader which says it supports this format it...
You need a new memory card reader. The reader isn't supporting the higher capacity of the new Memory stick. For a workaround, hook the camera directly into the computer via USB cable - then the camera itself becomes the reader and can transfer all of the pictures. Look for a reader that specifically does Memory Stick PRO Duo sticks, the PRO means the higher capacity.
Dec 01, 2009 | Computers & Internet
I get an error e001oo when I try to format my C310 camera
Here are the steps:
1. Make sure you will install a new or fully charged
battery/batteries into your camera.
2.Remove the battery/batteries and the memory card from
your camera
3.Reinstall the battery/batteries into your camera
4. Without the memory card,turn on your camera.
If issue persists, call 1.800.235.6325 for repair.
Thanks.
Regards,
Neerak21
Sep 21, 2009 | Kodak EasyShare C310 Digital Camera
Foramtting scandisk
If this memory card will be connected to a camera you can simply put the memory card to the camera and there you can format it using the camera's menu, you can also format this memory card using a card reader that will be connected to your computer, just put the memory to a card reader then connect it to the computer that way you can also format the memory card....
Dec 29, 2008 | SanDisk 2GB microSD Memory Card
How do i format my scandisk
If you are only using the card in a PC then when you plug the card into pc,it shows as a drive under my computer,you rt on the drive and pick format, fat.
If you are using a sd card for anything else such as a phone, you format the card with the phone,or whatever devise it is being used in, and you DO NOT format the card with the PC.
SanDisk 1GB Impact
r u unable to copy d pics........???
tell me den i will give u soln
di tpe of error comes when memory card gets full....n dere is no space for more pics....
if u r able to copy d pics den copy it and format ur card
u can format it wid camera or by using external card reader...
Jun 18, 2008 | Kingston 1GB Secure Digital Memory Card
SanDisk Ultra II 4GB Memory Stick PRO Duo Memory Card Logo
164 people viewed this question
Top SanDisk Electronics - Others Experts
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
