Question about Garden
My wheelhorse model 71225 goes very slow in reverse why
Why won't my toro model 71225 15 horse hXL m554201196. Will not pick leaves
I do not pick up leaves. I just keep mowing over them until they are very small pieces. Over the winter they decompose and fertilize the lawn.
Nov 06, 2015 | Toro Garden
Swimline 71225 sandfilter won't build pressure after changing sand
Did you cover the stand pipe?
Use a cap, or cut water bottle, or tape it up.
If you didn't, there's your problem...
You got sand inside your lateral drain assembly!
No sand in that pipe, period!
(The stand pipe is the pipe in center of rank, and the valve goes over it)
Jun 07, 2015 | Pool & Spa
Where is the switch on pump
www.sears.com/hydrotools-hydro-tools...s...
Jul 02, 2014 | Swimline Corp Swimline 71225 Above Ground...
1992 Buick Lesabre that will not go in reverse. It goes slow in drive
The bands in the transmission are bad,you need to replace or have that rebuilt
Mar 12, 2014 | 1992 Buick LeSabre
Toro wheelhorse riding mower 1638hxl very slow forward gear
if it works fine in reverse adjust the linkage rod on the pedal
Jun 08, 2012 | Toro Garden
Blades run slow on 314-8 78360,48" side discharge mower wheelhorse
are the bearing binding?where any of the pulleys changed?
Apr 23, 2012 | Garden
Have a new battery, only goes forward very slow, but in reverse goes fast then slow. does anybody ave an idea what may be wrong?
sounds like switches reversed, remove the shifter and swap the two switches. the for/rev is a spring loaded switch, the hi/low will stay on either position on its own.
good luck!
Dec 20, 2010 | Peg Perego John Deere Gator HPX Ride on...
Reverse speed too high
No, the controller must be reprogrammed and you will need an Invacare service tech to bring his hand-held programmer over to make the corrections to the chair.
Oct 11, 2009 | Health & Beauty
I need a owners manual for a Toro Wheelhorse tractor model 16-44 HXL
simple go to outdoorpowerequipment.com and enter make and model and you can download or print it in pdf form
Aug 27, 2009 | Garden
I cant figure out how to hook up the tiller on my toro wheelhorse i dont know if i goes on the front or the back
Go to www.toro.com then customer care, then manuals and parts then type in model no. hopefully the owners manual will show how.
Mar 26, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
