Question about Dishwashers
Whirlpool ADG 6340 ix Dishwasher is continously pulsing on filling and emptying and also can overfill. The green indicator light is flasing on and off continously also, any ideas??
2 Suggested Answers
tbirdfan1
  • 3051 Answers
SOURCE: I have a Whirlpool Dishwasher model no. ADG 6340
Hello there and thank you for choosing fixya
This is a very common problem with these types of machines the water inlet valve has a solinoid for the hot and a solinoid for the cold that opens and closes the water on demand .
When they start to pulsate like this it is trying to close the valve but it cant this is normally due to the valve being clogged with debris or the valve is failing all together and simply needs to be replaced
So what i would do is first if you can look into the inlet valve with a flashlight and see ifit looks like it has stuff in it and if so clean it out and try it again if this doesnt work than you can assum that the valve will need to be replaced here is what the one of the valves should look like or close to it .
$50.60 Quantity:
In Stock
Posted on Jun 05, 2011
Why Whirlpool ADG-6558/1 IX stops sometimes the wash cycle after 15/30 min?
reset the panel by hitting normal-- heat dry NOT at the same time until all lights flash then push cancel and it should start. element is going bad
Jun 02, 2014 | Whirlpool Dishwashers
WHIRLPOOL ADG 6340 ix - At start and during the cycle water drains in pulses and for long time and water intake is in pulses and for long time. The cycle finishes OK but it takes long time, 30 min cycle...
since the water drain is on a float be sure there is no blockage of the screen drain area in the bottem of the dishwasher under the lower rack.the make some cleaner rinses to clean out the screen.
Feb 21, 2014 | Bosch SHX5AL02UC Dishwasher
I have a Whirlpool Dishwasher model no. ADG 6340 IX.The inlet valve is pulsing and letting in water on every pulse. It just keeps filling, over fills and trips elcb
$50.60 Quantity:
In Stock
Jun 05, 2011 | Whirlpool 24 in. ADG6340iX Built-in...
Adg 3962 IX showing fault code f2 with flashing
The machine has a switch inside that activates when a set amount of water is loaded.
If this switch then breaks (switches off) during the wash the machine assumes that the water has leaked out.
Run it through a couple of washes, check for a leak and see how it goes.
Hopefully it will be fine.
F2 indicates a flooded base.
Press and hold the start button until the start light goes out. (This resets the appliance)
Select a new programme and try the machine again.
If it comes up with a fault F2, take the panel off below the door and check for water in the base.
Be careful when you take the panel off, the exposed edges are razor sharp.
Drain any water in the base, reset and try the machine again and watch for a leak through the inspection panel.
May 24, 2010 | Dishwashers
Dishwasher does not wash simply beeps continously and wont start the rinse cycle with green flashing pre rinse light. Have tried turning off at power and have checked all connecting pipes. Have emptied...
If your dishwasher is a whirlpool or IKEA then maybe the answer given by emmanuelr in "Whirlpool dishwasher ADP5962 F7 error code" may do the trick. It certainly worked for me. Bit technical but if you are happy taking the sidepanels off the thing then the fix may be easy.
Apr 06, 2010 | Whirlpool 24 in. GU2500 XTP Built-in...
Front light flashing
Solution to the problem:
Discovered that the dishwasher was covered by our household insurance policy. Phoned and arranged for it to be repaired or replaced (no charge). Engineer coming on Friday.
Jun 10, 2009 | Whirlpool 24 in. ADG6340 Built-in...
Dishwasher adg 6340
is this a digital washer? If not turn the knob manualy while the bar is switched to on and see if you can get it running
Mar 30, 2008 | Whirlpool 24 in. ADG6340 Built-in...
Whirlpool ADG 6340 Dishwasher
What flashing are you referring to ? This could very well be a fault code.
Jan 09, 2008 | Whirlpool 24 in. ADG6340 Built-in...
Dishwashers Logo
55 people viewed this question
Top Dishwashers Experts
