Question about Bowflex Treadclimber
Error Code E1
I just put my tredclimber together, it worked for 3 seconds, then it stopped and I got an error code E1.
  • Anonymous Feb 28, 2009
    Error E1 after 10 seconds
  • Anonymous Mar 26, 2014
    MY treadmill has the E1 Code appear after about 20 seconds of use , then the treadmill just stops
I had the same error message E1 at 10 seconds according to the LCD display on an older Treadclimber TC1000. I called Bowflex 1-800-792-6784 and first thing they told me was to check the drive sensor on the back left corner of machine. It is two wires connected by 2 white connectors that snap together. The end of the sensor has a rubber cap that is supposed to be approximately 1/8 inch from the drive pulley. The rubber cap plugs into a small hole within the "firewall" of the drive pulley, but the end of the cap does not actually touch anything. They can email you a picture of it. If it ever gets knocked loose, the machine will register this e1 error, in some cases- hope this helps.Error Code E1 - getattachment.aspx&hm__qs=file%3d3d2f2ee0-2668-46ea-b32c-db049d56cb37.jpg%26ct%3daw1hz2uvanblzw_3d_3d%26name%3daw1hz2uwmdiuanbn%26inline%3d1%26rfc%3d0%26empty%3dfalse%26imgsrc%3dcid%253aimage002.jpg%254001c99c08.13bd6320&oneredir=1&ip=10.12.128.8&d=d6608&mf=0&a=01_0b590aaade5e800af268d347750ab151eca93264be20cd9ce2166e583b18cfe9
Posted on Mar 03, 2009
We purchased a used bowflex treadclimber and brought it home in back of our pickup truck. Of course it was snowing and it got wet. We used the treadclimber then it poped up with an E1 error code. We made sure connections were tight and we pulled out the speed sensor wire in the red rubber cap and made sure it wasn't wet or dirty. Re-inserted the black end of the wire that came from the rubber cap making sure not to push clear thru so inserted a credit card between cap and magnet in the pulley. So far so good. This may help some one.
Posted on Jan 02, 2010
I have a TC3000 had for 8 years, use it just about every day. Past few days i heard this noise like the belts are rubbing against something.
Posted on Mar 10, 2011
I purchased the bowflex treadclimber 1000 and paid for assembly and after they assembly men left. I tried to use the machine and after 3 seconds then it stopped and I got an error code E1.
Posted on Apr 09, 2011
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    Treadmill triumph 400t has error E1
    E1 usually suggests it is and Electrical error and would probably require someone with knowledge of treadmills to rectify the error.
    It is very unlikely the ordinary Jo Blo can fix this problem.
    Apr 16, 2014 | Triumph Academy Sports 400T Treadmill
    E1 error code LFWC38F6LS
    Good Morning Chris,
    I see that you are receiving an E1 error code on your wine cooler, model# LFWC38F6LS, even though your wine cooler is still working. This could possibly be a false error code, caused by a miscommunication between the different control boards inside your appliance. I suggest resetting it by either unplugging it or cutting the power at the circuit breaker for 2-3 minutes. If when you bring power back to your wine cooler, you are still receiving the E1 error code, I suggest contacting either the manufacturer or your local authorized technician. Hope this is helpful.
    -Best Regards-
    WP
    Mar 18, 2014 | Frigidaire 38-Bottle Two-Temperature Zone...
    Dear I have samsung dryer model jv665jw , it starts for 3 seconds and stop , on disply it show error E1 ! What is the problem please ?
    It's a error code and you can call your local appliance store and give them the code they should be able to tell you what it is that's setting that code. I think E1 is the control board and usually runs in the $200 range to replace. Hope it's a simple fix though.
    Apr 29, 2011 | Samsung Dryers
    E1 and E4 error code desplay on the screen induction cooker. what is the fault in the induction cooker?
    E0 error - ensure pot or pan is placed correctly
    E1 error - the circuit has malfunctioned
    E2 error - the temperature sensor is opening circuit or short circuit
    E3 error - the voltage is higher (140 - 160V) for 3 seconds
    E4 error - the voltage is lower (80 - 100V) for 3 seconds
    E5 error - the cooktop surface temperature is too high
    E6 error - Internal electronic temperature is higher than normal for 3 seconds
    E7 error - Internal electronic temperature sensor is opening circuit or short circuit
    Dec 12, 2010 | Stoves Heating & Cooling
    How do I see/get error codes for my 1988 4Runner? (idling prob.)
    The check connector is located near the No. 2 relay box. Short terminals T and E1 of the check connector. (jump together)
    2. Turn the ignition ON. do not start engine.
    3. Read codes by the number of flashes of the "CHECK ENGINE" WARNING LIGHT.
    4. System normal: blink every 0.25 seconds.
    5. Malfuction Code: light will blink a number of times equal to the malfuction code.Between first digit and second digit, 1.5 sec
    Between code and code 2.5 sec, between all malfuction codes 4.5 sec
    6. The diagnostics code series will be repeated as long as the connector terminals T and E1 are jumped.
    7. Codes are 2 digit numbers
    Feb 11, 2010 | 1988 Toyota 4Runner
    F1 e1 error code...oven has previously cut off
    F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
    Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Oct 09, 2009 | KitchenAid KGSA906P Gas Kitchen Range
    KitchenAid KESS907 Electric Range E1 F1 Error Code
    F1 E1, replace Electronic Range Control.
    In other words, the controller board has failed.
    Jan 29, 2009 | KitchenAid KDRS807SSS Dual Fuel (Electric...
    Kebc207 oven error code E1 F2
    This is information from the Tech Sheet.
    Fault Code F2 - Error Code E1: Code Explanation: Keypad keytail not connected. Recommended Repair Procedure: 1. Check keypad connector for firm connection. 2. Press CANCEL. If error code returns after 60 seconds, replace keypad. 3. Replace control.
    Jul 15, 2008 | KitchenAid KEBC207 Electric Double Oven
    Bowflex Treadclimber Logo
    5,534 people viewed this question
    Top Bowflex Exercise & Fitness Experts
    Howard
    Howard
    Glenn Mayer
    Glenn Mayer
    ka4iup
    ka4iup
    Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
