Question about Epson WorkForce WF-7015 colour inkjet wireless printer - A3 EPSON
Waste ink pad wf 7015 - Epson WorkForce WF-7015 colour inkjet wireless printer - A3 EPSON
jonniewalker
  • 1029 Answers
SOURCE: waste ink pad
to Reset Waste Ink Counter
  • RUN AdjProg.exe file Epson C90
  • choose Particular adjustment mode
  • select waste Ink pad counter
  • Klikinitialization
That’ all!
Posted on Jun 01, 2008
Nic61
  • 1073 Answers
SOURCE: Epson rx620-waste ink pad replacement Instructions
No Problems M8!
Here is the manual for your printer
http://files.support.epson.com/pdf/rx620_/rx620_qr.pdf
Good luck to you
If you find my answer helpfull, dont forget to vote!
Posted on Dec 18, 2008
  • 749 Answers
SOURCE: need replacement waste ink pad
Hi...
so bye bye waste pad... can't find any replacements but this is my recommendation for you a waste tank... It's what I did on my 2 Epson Printers... Click the link to get the idea...
waste tank
Or you can use some tissue papers to replace what was thrown away.
Happy Fixya...
Posted on Feb 28, 2009
SOURCE: Need To Replace The Waste Ink Pad on my Epson Stylus C66
I modified a little what Worldvet had done. I opened the door as if to change the ink cartridges. I first used a pair of needle nosed pliers and carefully took out the sponge type pad which is along bottom of the printhead travel lane. One will see the two center plactic guides within this lane. The sponge is very delicate, so be very gentle in removing it. It has ink residue in it so use gloves if necessary and upon removal place the sponge on a paper towel folded in triplicate so the ink does not bleed through the towel. Remember to what position it was before removal, so there is no problem when you try to replace the sponge after cleaning.
The second sponge I removed as follows: With the power on, I pressed the ink cartridge removal light (red) (far left) once. This moved the print head to the "far left", before the position to change cartridges. With the power still on and the printhead to the far left, I was able to very gently (with the same needlenose Pliers) remove the sponge under where the printhead was parked. It too is very delicate and be careful not to rip it. It too, one will find, has two plastic slots on the botton which the sponge will have to be returned into. I then turned the printer off, which caused the printer head to return to the parked position.
I took both sponges, and with Alcohol (Pharmacy type), I placed the sponges in a disposable plastic bowl and filled it with the alcohol. I gently used the needle nosed pliers (Closed) as a device to gently press on the sponges which were submerged into the alcohol. I continued to alternate up and down the sponge pads, causing the alcohol to dilute and clean the pads. When the alcohol became saturated with the ink from the pads, I took the pads out of the alcohol bowl and placed the pads on a triple folded paper towel so the remaining ink would not bleed through anything.
I then took the bowl of alcohol/ink and while I flushed the toilet and the water was going down, I emptied the alcohol down the middle of the water spout as the toilet water was completing its flush. This keeps any ink from touching any porcelion.
I then refilled the plastic bowl again with fresh alcohol and resubmersed the pads, just incase there was any ink still left in them. Upon pressing on the pads and the alcohol remained clear (indicating all the ink was removed) I again used another set of paper towels, trippled, and placed the pads onto the paper towels, and squezzed them dry. I disposed of the alcohol the same as before.
I then, first replaced the large pad onto the printhead travel lane, back into the same position, being careful that the holes and slots fits back into its proper position and the edges are tucked under the proper hooks (little plastic hooks attached to the side of the travel lane).
Upon reinstallation I pressed gently on the pad to make sure it was secure.
Replacing the second pad, I again turned on the printer and pressed the ink replacement light (red), same as before, causing the printhead to travel to the far left as before. I then very carefully replaced the second pad into the slot from which it came from.
After I made sure the second pad was secure in its proper position, I pressed the ink replacement light twice, causing the printhead to return back to the parking position. I had already reset the counter, so that was not neccessary. I returned to the computer and printed a test page to make sure the printer was working properly, at which time it was, so I therefore returned to what I was doing and the Service Warning was cleared. My fingers got a little ink; but what the heck, soap will take care of that! Good for another 20,000 pages. Hope this helps, not as bad a it sounds.
Posted on Mar 26, 2009
  • 5 Answers
SOURCE: EPSON 2200 - Waste Ink Pad Replacement
You can replace the pads yourself.... I wouldn't really mess with it though. There are other ways Google search "Waste Ink Epson 2200" to see how to setup an external tank.. I have mine setup this way and its been no problem.... If you're set on taking them out remove the screws from the sides and middle and the bottom will drop away and reveal the pads.
Posted on Apr 16, 2009
End of service for epson wf 7610
If your Epson WorkForce WF-7610 printer shows error message "The Printer's Ink Pads at the end of Their service life" and Epson WorkForce WF-7610 printer has a red light blinking problem: You should be download and reset Epson WorkForce WF-7610 printer Waste Ink Pads Counter with Epson WorkForce WF-7610 Resetter.
Go to this link, you should be able to download the resetter and follow the procedures step by step.
Reset Epson WorkForce WF 7610 End of Service Life Error message Wic Reset...
Jul 22, 2017 | Epson Office Equipment & Supplies
I just changed the black ink and now I have small black blotches on any paper that I print out.
This can happen due the printer automatically running a cleaning cycle when any new cartridge is installed, to ensure the ink is properly run into the printhead down to the nozzles. In the main, what happens is the ink that is used during such cleans goes into the Waste Pad but sits on top if the pad is fairly soaked with ink from past cleans and is thus transferred on to the underside of the printhead - thus to get smudged on to the print paper. Ideally, fit a Waste Ink Bottle (search on youtube.com for your printer model and for the Waste Ink Bottle installation - some dealers of ink cartridges offer packs with full instructions but is generally easy and cheap to DIY). All you need is some tubing to fit on the waste ink drain tubing (normally inside the RH side .- where the printhead parks between uses - the youtube video for your model will show how to easily remove the end panel and fit the tubing) and then to put the end of the replacement tubing into a small glass (not plastic as can be easily tipped over - glass is better as heavier) so any waste ink is drained from the felt waste pads under where the nozzles park. Meantime, put the printhead into the Change Cartridge position, then unplug the power lead - NOT turn printer off as that simply parks the head again. With the head in the CC position and power off, you can freely move the whole printhead with its cartridges to the left - then make a decent pad of kitchen paper and find the felt waste pad down on the RH end and press to soak away the surplus ink. Repeat several times until most ink has gone. There is then none to get back on to the nozzle area again and you should be free of the blotching. A small torch will help to see inside the printer. There is sure to be at least one youtube video for your printer on fitting the drain system but if not - try several print cartridge suppliers (not generally the sell-only eBay ones so search using google for main dealers)
Feb 24, 2015 | Epson WorkForce WF-2530
My epson WF 840 has had counter reset, and waste ink pds changedbut, message reads, printers ink pads at end of life, switch off printer
Google epson waste ink pad resetter.this is a small program from china.you may be in luck and be able to reset the counter.download program run it, select printer from drop down menu.right click icon, reset waste ink pad.switch off printer restart.you may need to do this again.this program also resets cartridges before they become empty so you can get more out of them.
Nov 27, 2014 | Epson Workforce 840 Wireless Inkjet...
Reset Epson WF-7610
I've seen a program reset function which is downloadable from the internet. You will have to google it. I think it's only available on a windows operating system.
Sep 07, 2014 | Epson WorkForce WF-7620 Wireless Color...
How to reset epson t 60 printer
Depends on what you mean by "reset".
If you're referring to the waste ink counters, you can either:
  1. Locate a copy of the AdjProg service utility and use that to reset the waste counters
    Note: Will not work on MacOS or Windows 8
    ... or...
  2. Download the WICReset (for windows) or iWIC (for MacOS) and purchase a WICReset key to reset the waste ink counter that way.
Whatever you do, remember that resetting doesn't deal with the waste ink inside the pads so you should be looking at changing the pads (not easy to do yourself) or fitting an external waste ink tank like a printer potty.
Aug 06, 2013 | Epson Stylus Office Equipment & Supplies
When printing coming on the screen "The Ink
When turned on, the printer initializes the cartridge, and perform inkcharge. So there is some ink discharged to waste ink pad. The printer calculates the amount of waste ink, and when the waste inkreaches a certain amount, which approached the waste absorptioncapacity pad, then the printer will stop printing command. Intendedto waste ink does not overflow from the waste pad. To be able to re-use the printer must be reset waste ink counter., and replace thewaste pad. Or it could also extend the exhaust hose to outsidebottle.
Jan 14, 2011 | Canon Office Equipment & Supplies
How reset E-91 ( wast ink ) ( reset tool ) on epson stylus rx 520
Hi there you can download this from my website.
Main features.
SSC Service Utility allow you to do many amazing things with Your Epson printer :
1) Work directly with CSIC in Epson Stylus printers cartridges.
2) Reset or rewrite any chip using special addon device.
3) Freeze internal ink counters.
4) Reset internal ink counters even with empty cartridges.
5) Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode.
6) Hot swapping of cartridges supported.
7) Resetting of protection counter (even then it is already full).
8) More then 100 different Epson printers supported
This allow many people with high printing demands to save some money (program works with both black and color cartridges).
Up to day this software works under Windows 95/98/ME/2K2/XP with both the LPT and USB printers.
Download Free
Click Link = http://www.4all2sell.com/reset-tools/sscserve.exe
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
May 08, 2010 | Office Equipment & Supplies
Indicates waste ink absorber is almost full on cannon i9900 print
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink full" error.
The waste ink absorption pads cannot be emptied, only replaced.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you. Once they are replaced, it'll be functional again.
May 16, 2009 | Canon i9900 InkJet Photo Printer
Epson WorkForce WF-7015 colour inkjet wireless printer - A3 EPSON Logo
447 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
