Question about Pyle Car Audio & Video
Plye plcm7500 installation of red wires
What do you do with the red wires
Stereo harness for plye pld 193t where can i buy one
try radio shops that install the units they sell
if they don't have one then maybe they can suggest where to go to get one
Aug 31, 2016 | Cars & Trucks
How can I fix the cd tray on a plye PTTCSM60 stereo?
I would use an optical disc player cleaner, you know, the one that looks like a CD? Then I would check the CD for damage and dirt. Clean it with a VERY soft cloth, being careful not to scratch it. If the CD is damaged, you might try another CD.
Apr 27, 2014 | Pyle Home PTTCSM60 Turntable Boombox With...
Install flash player but not plye youtoub ( samsung gt-b3410 mobile ) and show massage display eroo plesh securti satting and plz your mobile nomber
Phones doen't plays youtube videos as they r usualy in.flv fromat...So you should covert them into your Phones supprted format i.e .mp4 or .mpeg etc then transfer them to phone they will run......
Apr 03, 2011 | Samsung B3410 Cell Phone
How to bypass the plye tv deck to play while driving
you need a 2 way toggle switch, then solder ground to one side, and find brake wire from radio harness and solder that to the other side of toggle switch, then flip the switch to on and your ready to watch and drive, disconnected harness from radio first
Feb 20, 2010 | Jensen VM9510 Car DVD Player
Pyle dvd player dome light
You need a third wire
The 12V Red need to go to a constant positive (battery) the yelly needs to go to the positive from the two wires, and the ground should go to the ground for the two wires
Feb 05, 2009 | Pyle Car Audio & Video
All settings for my plye dvd player restarts anytime i turn the ignition on.
Check if the stereo direct positive lead is right connected.Good luck
Sep 18, 2008 | Pyle Car Audio & Video
Amp in Protection Mode
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage drops below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, disconnect all speaker wires and signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Dec 19, 2007 | Nitro BMW-482 Car Audio Amplifier
Car Audio & Video Logo
23 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
