Question about Dell Inspiron Computers & Internet
Backlight On waking from sleep mode my computer has no backlight, anybody have a solution please.
  • Dell Master
  • 7,627 Answers
On a Desktop? Reboot, Open Control Panel, Power Options, set to High Performance, Advanced Power settings. Set Hibernate and Sleep to Never. Shut down your computer when not in use, it will last longer and a reboot everyday will reset the machine.
Posted on Jan 16, 2013
leecom72
  • 4806 Answers
SOURCE: My computer keyboard works fine,
press the on/off button to wake it up, see if that resolves the problem
Posted on Nov 15, 2008
  • 285 Answers
SOURCE: Monitor goes into Sleep Mode immediatly upon turning on computer
Ok. I think "sleep mode" means that your monitor might not have a tight connection. Tighten all connections. Also, push the power button on your tower. When you gegt back, go to screensaver- power settings- and from there you can adjust.
Posted on May 24, 2009
  • 315 Answers
SOURCE: PC will not wake up from sleep mode ACER Aspire M1202
dont use sleep mode.
Posted on Aug 02, 2009
  • 10406 Answers
SOURCE: Compaq Presario stuck in sleep mode
Connect the monitor to some other computer, e.g., a notebook, and see if it does the same thing. If it does, then the monitor is the problem.
If it does not, then your computer is not putting-out any "video" signal, and so the monitor goes to "sleep".
If you have MORE than one VGA-output port on your computer, connect your monitor to the "other" VGA port.
Or, press-and-hold the ON/OFF button on your computer, to force it to completely shutdown.
Posted on Jan 13, 2010
  • 53 Answers
SOURCE: My monitor has kicked into sleep mode and won't "wake up".
Unplug all the Cables from Compaq Presario 5103 CL and leave the Keyboard, mouse and monitor cable pluged in.
Now make sure the power cable of the monitor should be pluged in and the power cable of the tower should be pluged in.
Now to check if the montor is fine just unplug the video cable only which will show no input signal on the screen. If it shows this signal the monitor is fine. Plug back in the video cable.
If the monitor is going to sleep mode it might be possible that the old computer ( Compaq Presario 5103 CL ) is in stand by mode. hit any key on the keyboard and it should come back .
If it is not in the stand by mode then do one thing. Check the same monitor with the new computer. If it is working. Perfect ..!
Do one thing now ..!
Unplug all the cables from your old system and then press the power button for 30 sec and let it go. Now plug the keyboard, mouse and the monitor try again.
If it works Perfect. If not ..!
Then you need to open the tower and check on the processor FAN is it running..? If its not running you will not get the display as the fan is responsible for the display on the screen. Otherwise...!
Check the Tower possibly the Tower is not getting the power.
Try these steps and let me know If it works
Posted on May 05, 2010
How to wake Dell All in One, Win 7, from sleep mode
In Windows 7, there is a bug, if you put the PC in sleep mode when the system is running on batteries then it may still drain out the batteries and you cannot wake it up. In this case, you need to connect the AC power and reboot the PC. If you put the Pc to slepp when the AC power was connected. Then there are no issues and just by pressing the enter key it should come out of sleep mode. Sometimes - depending upon settings - you may need to press the Power button the PC to wake it up from sleep mode.
If you have already tried all this, then please go to the Power settings in Control panel and check all the setups that exist. You may need to change some of them.
May 25, 2014 | Dell OptiPlex 760 MT Desktop Computer
How do I wake the cycling computer from a sleep mode?
To wake your computer from its sleeping mode, press any button, spin the wheel and rotate the crank. Doing so will connect the speed and cadence sensors to the computer.
Jan 17, 2013 | Cycling
How to wake msi u130 from sleeping?tnx
If it is in sleep pressing any key or moving the mouse will generally wake it up. If you left the computer unplugged in sleep mode then it most likely ran out of power. If your using hibernate I would recommend not using it as it has so many issues.... :) If you have to hit the power button to wake it up then it's either shutdown or in hibernate. FYI there will generally be an amber light on to indicate sleep mode. If no lights it's most likely not in sleep mode.
Comment if you need additional assistance.
Aug 24, 2011 | Acer Aspire One Netbook 8.9" Notebook
Waking from sleep mod
Hello
The hinge is a very fragile part of the Macbook. In the hinge goes all the video and sound cables, as well as the backlight power. You can have a hardware problem here with your connectors.
However the sleep mode can also take its time to wake up:
- The hard dive needs to wake its 5400 rpms - The system has to wake - The video has to wake
I would think that a fast internal hard drive, as a SSD drive for example, will wake up much faster.
Hope this helps
Aug 04, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Computer won't wake after sleep mode
there is no other solution part from this..............all brand follos the same procedure to come out of the sleep mode do not worry.................................Sameeraryan
Jan 13, 2009 | Sony VAIO VGN-FW230J/B Notebook
Cannot get me monitor out of sleep mode, please help?
Hi
Pls check the power management properties in device manager to check if the option to wake the computer from sleep for the keyboard and mouse are enabled.
You may also try to change the power plan or create a new power plan and check if you are able to wake the computer from sleep.
If this problem started a few days back, then you may try to do a system restore.
Feb 26, 2008 | Dell E151FPp 15" TFT LCD Flat Panel...
My monitor is in sleep mode and I cannot get it out if it.
Sleep Sleep is a mode that the computer enters after being inactive for a set amount of time. Commonly, this mode will turn off a device or set it into a stand-by
Engergy star No data is lost when computer components enter a low-power mode, ... keyboard would get the computer out of this mode. Also see: Power Definitions, Sleep
This should wake your computer, Good Luck/Please dont for get to Vote.Thank you.
Dec 15, 2007 | HP Pavilion F1703 17" LCD Monitor
When I select sleep or hibernate mode - the monitor stays black...
Hit the keyboard keys. It is better to just turn sleep and hibernate off and just use a screen saver or tun it off.
Aug 24, 2007 | ViewSonic VX910 19" LCD Monitor
Computers & Internet Logo
66 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
