Question about Vehicle Parts & Accessories
1994 buick park avenue harmonic puller
1994 buick park avenue the harmonic balance puller does not fit. is it a special year so different size HELP ME
  • Thomas Perkins
    Thomas Perkins Jan 17, 2013
    The holes in the back are threaded and you should use 6mmX80mm grade 8 bolts with thick, or multiple washers for removal
  • Vehicle Part... Master
  • 14,333 Answers
Here are some different types.
Posted on Jan 17, 2013
How do I replace the bottom pulley on a 1996 buick park avenue 3.8 supper charger
first off you have to get the nut off,then it requires a special harmonic balance tool too reach through the timing gates and pull it off crankshaft,you can probally get one from tool ilse at big autoparts store
Dec 21, 2014 | 1996 Buick Park Avenue
HOW TO INSTALL CRANKSHAFT SENSOR 92 BUICK PARK AVE
How to replace crankshaft sensor on grand prix gtp
The above link is for a video how to replace the crankshaft sensor on a different vehicle than your ,but the procedure is the same for your vehicle. The Harmonic Balancer needs to be removed to access the sensor, which is the most difficult part of the job.
There many videos on how to remove the harmonic balancer, and how to replace the crankshaft sensor on the GM 3.8 engine. Do a search on the web ' how to remove the harmonic balancer GM 3.8 engine.'
Hope this helps. Good Luck!
May 04, 2014 | 1992 Buick Park Avenue
What size nut holds the harmonic balance on. Buick park avenue, year 2000?
The center bolt can usually be removed with a 15/16" socket. Let me know if you have any questions and I'll do my best to answer them. Thank you for using FixYa.com!
Feb 12, 2012 | 2000 Buick Park Avenue
How do you remove hamonic balancer
You'll need to use the proper harmonic balancer puller for that engine model.
Dec 26, 2010 | 1992 Buick Park Avenue
My 94 buick park avenue is stalling. I tested the Alternator and it's running at 13. Could this be the problem? What else could be causing my car to stall?
IF ITS RUNNING AT 13 THEN ITS BAD MINIM IS 13.2 SHOULD BE AT 14 OR ABOVE IS THE BATTERY GOING DOWN TO THE POINT THAT IT WONT HARDLY TURN OVER
Oct 19, 2010 | 1994 Buick Park Avenue
I need to chance the crank sensor on a '96 buick park ave. 3800 v-6, what am i going to have to take off to do it ?
Passenger tire, passenger inner well cover, serpentine belt, pulley that attaches to harmonic balancer , nut for harmonic balancer, then harmonic balancer. Sensor is screwed to engine. Disconnect battery prior to and before install of sensor. The 3800 has a special balancer puller designed just for it, not sure were you could rent one it is a specalty tool.
Mar 19, 2010 | 1996 Buick Park Avenue
Crankshaft Pulley..98 Subaru Forester
just a socket set will do the job.But remove the bolt and put thread lock-tight on the threads and tighten to manufacturers toque
May 30, 2009 | 1993 Buick Park Avenue
How do I R&R harmonic balancer ?
to replace the balancer u need a special puller i'm not sure were you live but some parts stores rent such tools but if not and you want to do this yourself you will have to buy one like a snap on or mac tools have them but they are costly for a one time use
May 02, 2009 | 1989 Buick Park Avenue
Removing harmonic balancer on 96 regal 3.8
YES YOU DO HAVE TO HAVE A SPECIAL ADAPTER FOR THE NORMAL BALLANCER PULLER. NAPA HAS THE TOOL AND THE # IS BK700-2461. ONCE AGAIN THE ADAPTER IS USED WITH THE BALLANCER PULLER YOU ALREADY HAD. YOU HAVE TO SCREW THE EXTENSIONS INTO THE BALLANCER AND INSERT ANOTHER EXTENSION INTO THE CRANKSHAFT TO GET THE OLD ONE OFF. WHY G.M. DID THAT TO US IS STILL A MYSTERY.
Aug 01, 2008 | 1996 Buick Regal Olympic Gold
Vehicle Parts & Accessories Logo
51 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
