Question about MXR Phase 90 Pedal
My phase 90 is not working - MXR Phase 90 Pedal
  • nikos Jan 18, 2013
    A friend of mine by mistake gave power to the pedal instead of 9volts 24volts!I change the two diodes in the power section of the pedal and now I have sound from the pedal but I don't have the phase effect!I change the first tranzistor and afterwards the 2n5952.But still nothing you think the problem is the tl 062 or the tl 064 tranzistors?I want to be sure because It's a bit tricky to change them and I'm afraid I might damage the pcb.Help!
MXR phase 90 swtiches on but I have no phasing
I would check the difference in sound between using an AC adapter and a battery. These things lose the effect when the batteries get low.
Mar 28, 2014 | MXR Phase 90 Pedal
I have the MXR EVH Phase 90. When plugged in, and unit is off my sound is fine. When unit is activated, the light comes on but there is no sound. The same thing is going on with my Maxon AD999 Delay pedal....
The fact that it happens with 2 different units may point to something in common. You just first eleminate the cables as a possibility by swapping. Also, most pedal problems can be traced to a battery issue, so make sure it is a good one. Make sure you are using mono, not stereo cables.
The footswitch could be faulty, try holding it in different ways to see if it makes contact.
Feb 27, 2011 | MXR Phase 90 Pedal
I'm experiencing an unwanted gain boost when using this pedal
If using another pedal in the loop, change the orrder
Aug 21, 2010 | MXR Phase 90 Pedal
Is there some sort of trim pot or something in the block letter phase 90 where I can turn the volume boost down when it's on. I don't hate the sound of it but it gives me too much gain when I click it. I...
Have you tried experimenting with the order of your signal chain? Have a look at this link:http://www.zimbio.com/Guitar+Boomer/articles/36/How+Choose+Correct+Signal+Chain+Order+Effects
Jul 02, 2010 | MXR Phase 90 Pedal
How do I fix a mxr phase 90 (overvoltaged!with 12V universal)
My first guess would be that the zener diode is probably shorted. Also check the 2N4125 transistor for a short. Start there and update this with your results.
Dan
Apr 30, 2010 | MXR Phase 90 Pedal
MXR Phase 90 doesn't phase only clean signal. The oscillator is working and I have changed the BJT's.
sounds like a switch contact problem, try some surgical alcohol. (for the MXR not for you!!!)
Dec 31, 2009 | MXR Phase 90 Pedal
Phase 90 dead no led no nothing- it has tl062 and a tl064 chips block script, switch seems good on VOM, can the 2 diodes after the power input be likely problems? I can also swap out the IC chips for...
One needs to consider the history of the unit. Could someone have used a reversed power adapter? If so they probably blew those diodes.
Input power protection diodes are often in the 1N4004 family.
Do not change any diodes without knowing the type. There may be Zeners as part of the effect shaping.
Check the power getting to the Op amps... pin 8 and 4 are the power pins, 8 being positive. Don't get fooled as sometimes the circuitry has the positive as signal ground.
ONLY SHOTGUN a device as last resort.
Dec 11, 2009 | MXR Phase 90 Pedal
Turns on, led works, just suddenly stopped applying its awesome phase 90 effect though.
If you are using battery power, just because the LED lights doesn't mean the battery is adequate. Check the battery voltage.
If you are on adapter power, make sure any bypass switch is in right state. Also occassionally someone gets the in's and out's cables backward... that can do it!
Nov 09, 2009 | MXR Custom Shop Phase 90 Led
Mxr phase 90 block logo and the 9v power jack not working
These break and SOMETIMES the circuit board gets cracked.
Open up and inspect for damage. If board is cracked, bridge broken traces by soldering wires around the break.
If the solder is broken, resolder it.
If the connector is damaged or weak spring, replace the connector.
Sep 12, 2009 | MXR Phase 90 Pedal
MXR Phase 90 Pedal Logo
52 people viewed this question
Top MXR Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a MXR Music Expert? Answer questions, earn points and help others
