Question about Keurig Elite B40 Coffee Maker
I have descaled my Keurig every 4 mos. , but this time, I have had to des ale 3 days in a row......I use the white vinegar method, and follow the directions exactly......still coming on, even let it "rest"4 hrs on w/o using .....really do it all.....its1 1/2 yrs old......is it just done? Maybet no a good productt?
  • 139 Answers
There are pins that pokes holes on top and bottom of coffee kcups, find the pins and clean it by unclogging with paperclips or some thinner wire.
Posted on Jan 20, 2013
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: A few days after descaling my Keurig (because the
Yes, it may take more then one time...
Check out this tip about how to descale your Keurig coffee brewer
How to Descale your Keurig Coffee Brewer
heatman101
Posted on Feb 23, 2011
Regardless of setting, I have not been able to get any more than 1/4 to 1/3 of a cup of coffee. The water barely comes out and now the descale message is on the screen. I need instructions for...
Although this is in "Problem with Vacuums," I found it while searching for a solution to my steam cleaner vacuum problem. You must be talking about a Keurig or Breville-Keurig coffee maker. Tap water, especially chemically softened tap water, contains minerals that require periodic descaling, as often as every two months if you make only a couple of cups a day.
Filling the tank with white vinegar and making multiple large mugs without a Keurig coffee cup in the holder will remove most scale. There are products that claim to do better than white vinegar if this does not work. Amazon sells a couple of brands in its Keurig section.
It will take several tank fulls of clean water to rid the machine of the vinegar or commercial cleaning solution. Use distilled water for this. Then switch to good bottled water without a heavy mineral load.
Jun 13, 2011 | Vacuums
My keurig coffee maker is flashing the words DE SCALE. What does that mean and how do I fix it?
"Scale" is deposits of minerals, etc. normally found in water. Boiling a container of water (in a pot, or coffee maker in this case), leaves small amounts or "deposits" of these minerals on and near the actual heat source. If not removed, they can slow brewing time and more importantly, adversely affect the taste of coffee.
Descaling should be done at regular intervals to prevent this from happening. Your machine lets you know when to perform the descaling task. There are a number of products sold in your supermarket that will do this for you - but one of the least expensive; and just as effective - is to use white vinegar. Here's how to do it:
1) Drain your Keurig coffee machine over a sink.
2) Fill the machine with undiluted white vinegar.
3) Run the brew process at least four times, pouring the cups of vinegar back into the coffee maker.
4) Optionally, let your Keurig coffee maker sit for a few hours, then run the brew cycles again. Pour the vinegar into the sink and drain any remaining vinegar.
5) Fill your coffee maker with fresh water. Run multiple brew cycles with fresh water each time to thoroughly rinse the machine before returning to normal use.
That's it!
I know this will help & good luck. Please rate my reply - thanks!
Feb 06, 2011 | Keurig Ultra B50 1-Cup Coffee Maker
Our machine has been descaled two time using the vinegar method. It is running very slow and even after it brews it continues to run so you can't make unanother cup. It is now showing descale again. We...
Sorry to read about your problem, I hope this helps you out.
you can contact Keurig at 1-866-901-2739 or Keurig.com
You do have a 1 year warranty, and if you are out of warranty. They will give a discount on a new unit.
dssfdfs
Dec 17, 2010 | Keurig B50 Coffee Maker
How do I clean my B60 Keurig of scale
Empty the water...
start with half distilled water... half white vinegar...
just run it all day... take a break and let the vinegar work... it will be heated up in the main tank... then pushed out to all hoses and sensors etc.etc...
enpty the container... wash it out... fill it with filtered or distilled water and run that until you no longer taste/smell the vinegar...
consider buying a brita pitcher and use that water for your Keurig... I do... and my unit goes for a long long time before it needs a vinegar washing...
P.S. dont use C.L.R. :(
It tastes bad.
Apr 25, 2010 | Keurig B60 Coffee Maker
Not enough water making it from holding tank to dispensing cup
your machine is "Short Cupping"
It needs to be descaled. Even though the descale light might not be on yet, the descale light only comes on when it is in SERIOUS need of a descaling. You should descale once every 3 months.
Fill reservoir with distilled white vinegar and leave the machine on for 4 hours (make sure to turn off the auto off option).
after 4 hours, run the vinegar through the machine until the reservoir is empty. Refill with water and repeat twice. you will notice a difference right when you start running vinegar through.
Apr 04, 2010 | Keurig Elite B40 Coffee Maker
CANNOT PRIME PUMP AFTER DESCALING - therefore CANNOT MAKE COFFEE
first vinegar is not strong enought proper descaler for expresso machine and in our water container the hole in the bottom put water in the tank with a hoseor turkey juicer our anything you got push water in hole you need to pressurize to forse the pummp to trim itself hope it help fixya pierre
Jul 24, 2008 | Keurig Elite B40 Coffee Maker
Keurig Elite B40 Coffee Maker Logo
43 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
