Question about Peavey Xr600b Mixer Amplifier "last One" 300 Watt Series 400bh
Peavey 150m power amplifier - no audio, hum
Peavey XR560 mixer/ amplifier using 150m power amplifier board. No audio, a distinct hum in output.
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Peavey Expert
  • 232 Answers
Bad caps probably..old unit, do you have a capacitor analyzer...if not you might find a Sencore LC102 to test caps with on ebay...
Posted on Sep 20, 2014
2 Suggested Answers
petraman7
  • 1175 Answers
SOURCE: eq on channel a doesn't work on 2 units
It could be an internal ground connection on the EQ that's broken ( maybe inside the connector) ..I repaired numerous peavey products and broken grounds are common.
Posted on Feb 16, 2009
How do i set up a Peavey xr560 mixer and graphic equalizer
PUT OUT PUT EQUALISER IN INPUT RETURN PUT IN PUT EQUALISER TO OUTPUT MIXER
OR JUST PUT EQUALISER BETWEEN MIXER AND AMPLIFIER MEAN OUT PUT EQALISER TO IN PUT AMPLIFIER AND INPUT OF MIXER TO OUT PUT OF MIXER
Oct 12, 2014 | Peavey Audio Players & Recorders
How do you hook up a peavey pv14 usb mixer to non-powered speakers?
You'll need to provide an amplifier if there isn't one built into the speakers. All the mixer does is combine audio sources and provide a line-level output. A separate amplifier is needed to boost that to speaker level. If you're just using the mixer in a home setting and you have a stereo receiver or home theater system, you can feed the mixer's output to an auxiliary input on the receiver and use the speakers you have connected to that.
Feb 25, 2011 | Audio Players & Recorders
Can I connect this mixer to a main mixer with 17 channels that is connected to an amplifier?
Yes you can - but do not use the loudspeaker outlets on the rear panel.
There are a variety of outputs on the front panel (bottom right as you look at it).
You can use the main output,  or monitor  send - (for monitor you may need to use the relevant 'send' switches on each channel to send signal to these outputs.
You should also turn the power amp switch to main only (not main + monitor) so that the internal power amplifier is not connected to the monitor socket
You could also use the record out RCA (phono) sockets on the Peavey to connect to the CD / tape input on the main mixer.
You can download a pdf of the manual from here for more informationhttp://www.peavey-eu.com/index.php
Feb 10, 2011 | Peavey XR 8600D Class D Powered Mixer
Peavey 5150 II guitar amp! Power Tubes don't light up and only
peavey 5150 II has low humming sound but still plays and sounds pretty good...should i re-tube it?
Jul 18, 2009 | Peavey PV-3800 2-Channel Amplifier
TRANSISTOR TYPES FOR PEAVEY XR684 MIXER AMPLIFIER/ARRANGEMENT
Go to Peavey's website
http://www.peavey.com
You may find what you are looking for here if not you may have to call them.
Jun 30, 2009 | Peavey Pv 2600 Power Amplifier
Ive bought a Peavey 1500 pa amplifier and would like to know are the a b knobs on the front treble and bass.If they are how would I take the outputs at the back of the amp to my Soundcraft mixer.
The Peavey A/B controls are output gain controls. Your mixers stereo output goes into the amps inputs, channels A & B. The Peavey is the output stage to your speaker system. If you you connect the outputs from a power amp to the inputs of a mixer you will blow the mixers input stage, amongst many other things and possibly damage the amplifier too. The bias (Bass, Mid, Treble controls) are on the mixer, not the amplifier. Unless you are using a mixer amp, which you are not. A PA system DOES NOT work in the same way as an intergrated hi fi amp.
Nov 07, 2008 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Connecting cd player to mixer
This should work. I use a similar setup for break music at small gigs. I would check the cable and the output of the unit itself again. .
Feb 21, 2008 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Peavey Compressor/Limiter and Peavey 3/4/5w Crossover
The correct order is Mixer>EQ>Compressor>Crossover>Amps>Speaker. Here is the link that helped me out. Scott's PA System Tutorial
Feb 13, 2008 | Peavey CROSSOVER, STEREO 2-WAY/MONO 3-WAY,...
Peavey Xr600b Mixer Amplifier "last One" 300 Watt Series 400bh Logo
188 people viewed this question
Top Peavey Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Steve
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
