Question about Sunbeam Electric Skillet Fry Pan Fp-10a Vintage
What metal was used for the sunbeam fp150A electric frypan - stainless or aluminum
Wanting to know if the shiny silver cooking surface is ss or aluminum
2 Suggested Answers
  • 57 Answers
SOURCE: Sunbeam electric frypan thermostat replacement
IF YOU STILL HAVE THE OLD ONE CHECK TO SEE IF YOU CAN SEE WHAT TEMPUTURE THAT IS WRITEN ON IT IF SO YOU CAN POSSIBLEY GET ONE ON THESE FOLLOWING WEBSITES (WWW.RADIOONICS.CO.UK) OR (WWW.MAPLIN.CO.UK) GOOD LUCK.
Posted on Jul 17, 2008
Is sunbeam electric fry pan model 7710 type 787 still available
Sunbeam Frying Pan‎
www.shop411.com/Sunbeam+Frying+Pan
Many Sunbeam Frying Pan
Find our Lowest Possible Price!
Nov 01, 2015 | Sunbeam Multi Cooker Frypan Fry Pan...
Tip
Proper Use and Care of Ceramic Glass Cooktops
Here's some helpful tips that can hopefully ensure many years of quality use of your ceramic glass cook-top.
NOTE: It is important to maintain PROPER care of your ceramic glass cook top as they can be very expensive to replace. Prices vary between models, but most are in the $200 to $300 range. With added labor charges, this repair can cost over $600 from an appliance repair company.
WARRANTIES: Most manufacturer warranties DO NOT cover cosmetics. That is, if your cook-top paint starts to wear off from normal use, or from the selection of cookware you choose to use, manufacturers typically WILL NOT replace it. Warranties also DO NOT cover accidents such as dropping something on the top and chipping or breaking it. Some warranties WILL cover, however, blistering, warping and heat related breakage that were no fault of the consumer (as long as you were using the recommended cookware). It is important to become familiar with, and follow, all the manufacturer's use and care instructions that come with your range.
CERAMIC GLASS CHARACTERISTICS:
It is normal for the ceramic glass to change color when heated. This is especially true for lighter colored surfaces. The color should return to normal when cooled. It is also normal for the enameled or painted areas on the cook top to show signs of wear and fade over time. Proper cleaning and cookware selection can extend the cook top appearance.
It is NORMAL for the radiant heat surface elements to glow red and cycle on and off. There is a thermostat associated with each individual element that regulates the temperature. The frequency at which the elements cycle on and off is determined by the heat setting.
PROPER COOKWARE:
Use ONLY flat bottomed cookware for the best results of heat transfer from the surface elements. Cookware with warped, rounded or ribbed bottoms can cause uneven heat transfer which can result in uneven heating of the cooking surface and cause damage to the cook-top such as cracking and/or permanent surface discoloration.
An easy test you can use to determine the flatness of your cookware, is to turn the cookware upside down and place a ruler across the surface. As you rotate the ruler around the surface perimeter, you should not see any light along the ruler edge where it meets the surface. Cookware with slight indentions or expansion grooves can still be used, however.
Make sure the cookware bottom is always clean and dry before use to prevent any foreign matter from burning to the cook-top surface and leaving stains. ALWAYS place your cookware on the cook-top surface BEFORE turning the surface elements on.
Make sure the selected cookware matches the size surface element in use. The cookware surface should NOT exceed one inch beyond the radiant surface element surface.
COOKWARE CHARACTERISTICS:
The material of the cookware you select will determine how well it transfers heat and how evenly it cooks. The ideal cookware should be of medium to heavy thickness.
NOTE: A non-stick surface will take on the characteristics on the base metal used. (i.e., non-stick over aluminum, will take on the heating characteristics of aluminum).
*ALUMINUM - Heats quickly and evenly, light weight, suitable for all types of cooking tasks.
*COPPER - Heats quickly and evenly, light weight, suitable for all types of cooking tasks.
*Both aluminum and copper are great when used as a core metal cover with a non-stick or enamel surface. However, when used as a base metal, alone, they can leave metal transfer marks on the cook-top surface which will have to be cleaned immediately following use.
GLASS or CERAMIC - Heats slowly and unevenly, may scratch cook-top surface if there are any rough edges, best results are when using low or medium heat settings.
CAST IRON - Heats slowly and evenly, maintains heat for slow cooking, great for browning and frying, rough on cook-top surfaces, may scratch.
STAINLESS STEEL - Heats quickly and unevenly, a base or core of aluminum or copper can provide more even heating.
DO's and DON''T's:
DO NOT store heavy items, such as jars, cans, pots and pans above the cook-top surface. Any inadvertent dropping on the cook-top surface and cause cracks or shattering.
DO NOT lay hot lids on the cook-top surface. Heated air can become trapped under the lid creating a hot spot as the rest of the cook-top surface cools. The cook-top surface could potentially crack when the lid is removed.
DO NOT slide cookware across the cook-top surface. LIFT cookware as much as possible when moving from surface to surface. This will minimize metal transfer marks and scratching.
DO NOT cook popcorn in prepackaged aluminum containers. The aluminum could potentially melt and may not be able to be removed from the cook-top surface.
DO NOT store anything on the cook-top surface that could melt (such as plastic and aluminum foil). Once melted to the surface, some of these substances may not be able to be removed.
DO NOT store empty pots and pans on the cook-top surface.
DO NOT attempt to use the cook-top surface while the oven is on a self-cleaning cycle. The oven super heats to temperatures in excess of 500 degrees and causes radiant heat to be exhausted from the oven vent on the stove surface.
DO NOT use a cook-top that is cracked. Any spill overs could potentially leak into the radiant heat elements and create an electrical hazard.
DO clean up any spills from the cook-top surface that contains milk or sugar. You may allow the cook-top surface to cool in order to safely clean, but do not allow these substances to remain on the cook-top for extended periods. If not removed, these substances can cause permanent discoloration and stains.
DO wipe down the cook-top prior to, and immediately following use, to maintain the surface appearance.
DO NOT attempt to cook any foods directly on the cook-top surface without a pan!
CLEANING and CARE:
Clean all spills and boil overs immediately.
Any substances that become adhered to cook-top surface can be removed by wiping up excess with hot soapy water and a kitchen sponge.
Use a non-abrasive pad (the green kitchen pads are considered non-abrasive) and a straight edge razor blade, pushing in one direction to remove stubborn particles.
Some metal transfer marks (copper and aluminum) may be removed by simply wiping cook-top surface with a damp sponge. Any remaining marks can often be removed with an approved cook-top cleaner.
Use only approved, non-abrasive cook top cleaner to keep the surface clean and polished.
DO NOT use scouring pads that will dull or damage cook top surface (i.e., steel wool or SOS pads).
DO NOT use any harsh chemicals such as ammonia or bleach that can etch or dull cook-top surface.
on Apr 19, 2011 | Cooktops
Heat control for sunbeam frypan FP150A and is there a genetic
see an appliance repair shop and ask if you can get a thermostat control for your pan
Apr 28, 2013 | Kitchen Ranges
I replaced the porcelain enameler flavorizer bars on my Weber genesis gas grll less than a year ago--four out of the five bars are bent and misshapen--no longer straight. Why??? They still look brand...
You are overheating the grill - make sure the thermometer is working on the right side of the grill lid. You should not heat above 550F (preheat) and you should not cook above 500F.
Secondly, you must clean out the drip tray (not just the aluminum foil tray but the bigger tray it is attached to (it slides out the front of the grill too). The grease that piles up on this tray can catch fire and overheat the grill (including the flavorizor bars).
Last suggestion is to get stainless steel bars next time (make sure you get the size that fits your grill because the stainless steel sizes also come a bit longer). The stainless bars are high temperature stainless steel and do not corrode. They are a bit heavier and cost about 30 to 50% more but well worth it. They clean up very easily and transfer heat to the cooking surface well. Keep them clean to keep the cooking surface hotter.
Jul 16, 2011 | Weber Genesis Silver B Grill
Can one cook with iron skillet on glass top electric stove
Cast iron is NOT recommended to be used on a glass cook top due to its weight and potential for damaging the surface. Cast iron also heats rapidly and retains heat for a long time. Its great for gas stoves, but not a good idea for a glass surface.
The best cookware to use should be lighter in weight, have even heating properties with a SMOOTH flat cooking surface on the bottom for proper heat transfer. Some cookware that IS approved for use on a glass cook top is baked enamel, stainless and copper.
NOTE: Cooper and Stainless can leave marks on the cook top, but these marks do come off with most approved cook top surface cleaners.
If in doubt, always refer to your owner's manual. It explains in detail how to select the proper cookware for your range and the limitations and/or characteristics of each. If you have any questions, please let me know. I hope this helps you.
Dec 29, 2009 | Frigidaire FEF366 Electric Kitchen Range
Stainless steel doors need to be polished
I've personally been performing restoration of high end metal surfaces, bronze, stainless steel, aluminum etc., including scratch removal, polishing, regraining, lacquering etc.. Strictly commercial properties, elevators escalators etc. I've performed these services for 30 years. As a Master Finisher I developed DeBruce Polish, and still perform metal restoration personally.
go to debrucepolish.com
contact: Bruce Smith
Apr 16, 2009 | Kitchen Ranges
Glass top range cookware
Here's the recommended cookware for glass top ranges:
Aluminum and Copper - have good heating characteristics, but may leave metal transfer marks on the glass.
Stainless - may take longer to heat and may not heat as evenly (some stainless has a copper liner to aid in heat transfer). More resistant to leaving metal transfer marks.
Baked Enamel - great heating characteristics, provides uniform heating and resists marks on glass surface.
Cast Iron - NOT recommended due to the weight of the metal. Can cause potential cracks or breakage.
Now, any reference to metal transfer marks are merely disclaimers from most manufacturers that the potential exists that the cookware could leave marks on the stove surface. Using a good cook-top cleaning product after the surface cools will aid in removing any of these marks. This does not mean this cookware should not be used.
All cookware used on glass cook-tops should have flat bottoms. There should be no ridges, grooves, or warping. This creates an uneven heat transfer between the pan and surface and can potentially cause the glass to break. Most manufacturers will not honor a warranty where it can be determined that the consumer used the wrong cookware.
Make sure you wipe up any spills on the stove surface that contains sugars or milk. These ingredients (if allowed to burn on the surface and are not cleaned up) will eventually cause damage to the glass surface by either removing the finish or leaving pits and cracks. Wipe up all spills AFTER the surface has been allowed to cool using a non-abrasive cleaning rag or sponge. The green scrubbing pads are considered non-abrasive and CAN be used. DO NOT use steel wool or SOS pads! A small straight blade razor can be used to remove stubborn items by gently scraping in one direction. I don't believe you can use any cleaning product that contains ammonia either.
All of this information can be found in the owners manual that came with the appliance. If you don't have a user/owner's manual, post back with your model number and I'll see if I can locate it for you. I hope this helps you.
Apr 17, 2008 | Kitchen Ranges
Feb 22, 2008 | Sunbeam Kitchen Appliances - Others
Cast iron pans
Cast iron cookware is NOT recommended due to the weight and the potential damage it can cause to the glass top surface. There's nothing better than a good old-fashioned cast iron skillet that's been broken in over a number of years of use, but they are better suited for gas ranges rather than electric. I hate it. I have several cast iron skillets that I only use on the outdoor grill, because I currently own a glass top electric range.
Aluminum bottom pans and copper bottom pans heat well, but can leave metal transfer marks on the cook top surface. If the marks are cleaned after use with an approved stove top cleaner, you shouldn't have any problem retaining the condition of the glass surface, however. Stainless Steel seems to offer good resistance to metal transfer, but takes a little longer to heat than aluminum or copper. So...you have somewhat of a trade off. Baked enamel cookware seems to be the best recommendation because it heats wells and causes the least amount of damage to your glass top surface.
IMPORTANT: Make sure the bottom of your cookware is FLAT. If your pans are warped or bowed, this can cause uneven heat transfer on the heating elements and potentially cause the cook top to crack. Most manufacturers will not replace the top if it still under warranty if it is determined that your cookware caused the problem.
A little over kill, but I hope this helps you.
Feb 14, 2008 | Maytag MER5770 Electric Kitchen Range
Temperature
You can cook anything on this that you can cook in a normal frypan. Check your cookbooks & use the same temps that you would use with an electric frypan. For eggs & bacon, 300-350F would be a good place to start.
Jul 16, 2007 | Toastmaster TG21W Indoor Grill
Sunbeam Electric Skillet Fry Pan Fp-10a Vintage Logo
66 people viewed this question
Top Sunbeam Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Sunbeam Kitchen Appliances - Other Expert? Answer questions, earn points and help others
