Question about Abit : AL8-V LGA775/945P/FSB1066/ATX Motherboard (MOTAB15)
160 gig sata hard drive that keeps on failing
I instolled a 160 gig sata hard drive in my pc it runs fine for about 2 days after wich at start up it goes to chk dsk wich says it has a consistancy problem i have a intel p4 3.2 mhz processor and 1 gig ram i'm running xp home and xp pro and the problem comes up on both of them could it be my bios ?
    Problem Solver:
  • 7 Answers
Hello what brand is ur hard drive. western digital has software that can scan ur hard drive for possible hard ware errors, as does seagate. in addition ur motherboard may have a test that may help (smart something not sure but good luck)
Posted on Jan 24, 2009
My Seagate Momentus 5400.6 500GB hard disk is told to be inaceesible and corrrupted by my pc. the plug of hard disk was broken so i changed the casing twice , it works finely for 2 3 days and then there...
Internal hard drives should only be opened in a clean room. If I understand you correctly this drive is bound to fail. Suggestion: Start moving files onto other space.
Aug 28, 2012 | Seagate Momentus 5400.6 500GB SATA/300...
I recently upgraded my ram (2 days back) to 1gb on my intel d915gav motherboard, first it seemed to work fine, but now the Pc won't boot, with it connected?
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be
even something as small as a faulty power lead or fan lead can cause you problems
computers need all of the data and power to travel through every working device and to have an end to be able work properly
make sure ram modules and cmos batteries have dust free secure seatings and cmos battery has charge some motherboards cmos batteries are soldered in
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all power an data leads make sure they have dust free secure connections
cd/dvd floppy drives need to have current go through make sure these drives are working
check you CPU make sure its securely seated and has thermal grease
hope this helps
Jul 08, 2012 | Intel D915GAV Motherboard
Ms-6540 won't post with 2 gig memory
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your (motherboard to your hard drive) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
even something as small as an electrical extension or a faulty fan lead can cause you problems computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
check the CPU make sure it has thermal paste and dust free secure seating
also check your computer ram modules and cmos battery make sure they are dust free and securely seated some motherboards cmos batteries are soldered in
hope it helps
Jun 12, 2012 | Computers & Internet
Turned off raid, unable to access 2nd 160 gig hard
Right click on Computer in the Start menu. You should see manage.
click on manage and you will see some selections the left one called disk management. click that and you should see all your drives. If you disable the Raid you may have to initialize the disk for windows to use it again. right click on the drive and initialize or if it shows up you may have to create a partition and then format.
Mar 08, 2010 | Dell Dimension 3100 PC Desktop
IS THERE ANY replacements for YH278 HITACHI 120 GB SATA HARD DRIVE HTS541612J9SA00, THAT IS CAN I REPLACE WITH 250GB.
Generally speaking, you can replace any SATA hard drive with any other SATA hard drive. Notebook SATA drives are all the same size, basically, (2.5 inch), and desktop drives are generally the same size (3.5 inch), Desktop and notebook SATA drives will connect to the same power and interface cables, though desktop drives require more power. Just make sure that you pick a 2.5" drive for your notebook, or 3.5" drive for your desktop, and the drive will attach with no problems.
As for the size of the drive, to my knowledge, any system with SATA should support any size SATA drive (I put a 500 gig drive in my notebook, where the stock drive was 160 gig).
Feb 28, 2010 | Dell Inspiron 6400 Notebook
F7 hard drive problem the PC has two 360 gig hard drives. Which one is the primary? Will a WD serial # WCAV 5463220018 3.5 inch SATA hard drive 1000 Gbyte be compatible with my PC?
If your PC has SATA connections yes you can use SATA, but not a SATA 2.5 which only fits a laptop! When you use 2 drives one must be set by jumpers on rear of drive to master..... the slave drive (2nd hard drive) must also be set to slave by same jumpers.
Dec 23, 2009 | HP Pavilion Elite M9150F Desktop PC
30days out of of warrentu dont figure. Issue:
hi there i have the dv8000 i put a 500 gig ide drive in mine and never got any problems you say that you have several (9) issues most of them stated Failed Devices do you mean drivers for laptop as thats all i think you need.
also any 2.5 hd should work..
if its drivers you can go to hp site
Oct 23, 2009 | HP Pavilion DV6700T Notebook PC
CAN I UPGRADE THE HARD DRIVE IN MY ASUS A8M LAPTOP, EXAMPLE CHANGE THE 80GIG DRIVE TO A 160 GIG
Yes you can upgrade the hard drive from 80 to 160 GIG SATA for you to have more storage for your computer files....
Jul 16, 2009 | ASUS A8M Notebook
I instolled a 160 gig sata hard drive in my pc it runs fine for about 2 days after wich at start up it goes to chk dsk where it says that one of your disks needs to be cheched for cosistency it runs the...
Sounds like the 160gb drive has some issues ...bad clusters etc ... if it keeps happening you can be sure the drive will fail soon.
I would look to replace the drive as soon as possible. If it's less than a yar old you should be able to get it replaced under warranty.
Jan 24, 2009 | Abit : AL8-V LGA775/945P/FSB1066/ATX...
Service pack3 crashed puter - after reinstall machine thinks extra hard drive is a disk drive.
You can get to the BIOS by hitting DEL or F2 at start up.
However, that does not have anything to do with a drive letter.
Drive letter designation is set in
START>SETTINGS>CONTROL PANEL>ADMINISTRATIVE TOOLS>COMPUTER MANAGEMENT>DISK MANAGEMENT.
Hope this helps.
Sep 06, 2008 | E-Machines eMachines Desktop PC
Abit : AL8-V LGA775/945P/FSB1066/ATX Motherboard (MOTAB15) Logo
71 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
