Question about Maytag Kitchen Ranges
Maytag gemini error code h3 133 - Maytag Kitchen Ranges
woodchuck789
  • 4070 Answers
SOURCE: maytag gemini model MER6770AAB - F1-2 error
Check the sensor for correct ohm reading. If it is good, replace the control. It should read 1143 at 100 degrees
Posted on Sep 18, 2009
localwonder
  • 6784 Answers
SOURCE: range displays error code f9-5
HI. This indicates that there are serious issues that concern the operational value of the main control abord(ERC/Clock).
This will require you to replace the ERC, asap.
ERC_(Electronic Range Control Board)
F9-5_Hardware conflict(watchdog)
Posted on Nov 08, 2009
EllaWatson25
  • 725 Answers
SOURCE: Getting Error Code f9-5 and f9-6 on MER6770
This is a bad electronic clock assembly and it is very simple to repair. You can save a lot of money by making this repair yourself, too!
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service from 7 AM until 7 PM CST and we will get the correct part, as well part removal/installation instructions to you .
We look forward to working with you. Thanks, Ella
Posted on Jan 18, 2010
  • 11 Answers
SOURCE: Getting error code 9-6 on MER6770AAW maytag gemini
That code is for obstruction in the lower door lock mechanism. You need to check for a obstruction in the lower door lock. The next step would be to disconnect the power for a few minutes then turn it back on and see if the code reappears.
Posted on Feb 23, 2010
blueextc3221
  • 15935 Answers
SOURCE: What is an F1=4 error on the clean cycle on a Maytag gemini range
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
Getting a F1-4 error code on my Maytag Gemini model # 6772. Came home to the upper oven at full heat with the control panel beeping. Extremely dangerous situation where the oven would not shut off at the...
Hi greg_shanoia,
The F1:-4 error code means "Runaway Clean Lower oven". You need to check the oven temperature sensor, replace if necessary.
Hope it helps.
Thank you for using FixYa.
Sep 21, 2011 | Maytag MER6772 Gemini Electric Kitchen...
A maytag Gemini everything is working but it is flashing an F9-5 code and sometimes it throws a F9-6 any ideas on what to do????
Hi twiztedminds,
The F9:-5 / F9:-6 error code description is Latch Unlock Lower. Check for obstruction in door lock mechanism.
Hope it helps.
(Positive feedback will be greatly appreciated.)
Aug 09, 2011 | Maytag MER6772 Gemini Electric Kitchen...
Getting error code 9-6 on MER6770AAW maytag gemini double oven range...what and how to fix?
Feb 23, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Range displays error code f9-5
Nov 08, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Maytag gemini model MER6770AAB - F1-2 error
Sep 18, 2009 | Maytag MER6772 Gemini Electric Kitchen...
How do i get fault codes for maytag gemini?
Go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the following page, there is an "Error Code" link listed under the Special Features section. The Maytag Gemini series fault codes are listed there. You can print the list for FREE. I hope this helps you.
Sep 11, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Maytag Gemini Stove Code F1-4 (bottom door won't open)
F-1 error is a Temperature Runaway. It Maytag's way of letting you know that oven overheated. Nothing you have done but it may have shorted out the oven sensor or the keypad. Check the sensor and see if it's closed. If it's okay, replace the keypad.
Oct 25, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag Gemini top oven, the bottom element does not get hot. I replaced the element with a new one from maytag. what is the problem?
Hello jrlibs
Welcome,
You said, Your Maytag Gemini top oven, the bottom element does not get hot. You replaced the element with a new one from Maytag. Asking what is the problem?
1.What is the model number and the year of your Gemini Range?
2.Was there an error code that came up before you changed the heat element?
3.If yes what was the code?
4.Did you check for current in the connection leading to the element before you installed the new one? Or just plug it in hoping for the best?
Waiting for your reply!
Huuum
Oct 16, 2008 | Kitchen Ranges
Maytag Gemini mer6770aw
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
May 26, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Kitchen Ranges Logo
366 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
