Question about Kitchen Ranges
I need some help with a magic car alarm system ,manual if possible it's not a kitchen range for car only...
I posted it and it said it was for a kitchen range....No ...it's a car alarm system, I bought this car and it had it already installed in it,It's a 1988 Jag XJ 6.Anyway it went crazy,lights coming on an off,blinking dash.It needs to come out. All it does now is turn over,no start..I just need to no what wires to cut to get it out of there.I would appreciate any help I can get.. Thank you Doug
catriver
  • 878 Answers
SOURCE: STOVE TOP CONTINUOSLY SPARKS
Thrasher, Sorry I cant help with the diagram but one of your burner switches is grounding out. Each burner valve has a switch and one of them is finding it's way to ground, therefor the contstant clicking. Good luck on this deal...Catriver..post back.
Posted on Sep 07, 2006
fridgetech
  • 473 Answers
SOURCE: MAYTAG MAGIC CHEF SELF CLEANING GAS RANGE
Here are the codes for magic chef:
F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad
Posted on Nov 18, 2007
gwshaw71
  • 83 Answers
SOURCE: wiring diagram
try the whirlpool or kitchen-aid web sites I looked up your model # at 1st source parts and that model is not there
Posted on Dec 07, 2007
aborcass
  • 2651 Answers
SOURCE: Kitchen Aid Gas Range, Model KGR 1801
F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) theres the bad news its reading a stuck key pad. replace the control..
there may be a good side and that is depending on age of machine they usually come with a 5 yr part warr on their electrical components, in which case youd only pay service and labor to install it
Posted on Mar 20, 2008
SOURCE: Electrolux Slide In Electric Range doesn't fit to the wall?
We have the same Electolux range.....it is supposed to fit about 2 inched from back wall......your granite installer will have to fit a piece of granite behind the range. Yes, it is proper to have the plug installed. The plug is not part of the range package and will have to be purchased seperately if your installer does not use the plug from your old unit.
We are on our second slide in with wave touch controls.......we hope you have better luck that we've had. Ceramic cooktops do not seem to be level on all units. The bottom oven has locked up on both ovens and cause burned foods.....Electrolux has problems that aren't acknowledging as yet..........good luck
Posted on Nov 30, 2008
I'm not even using my oven and the F2 alarm keeps sounding every minutes. What is wrong?
First, check the oven sensor and see if it reads 1080 ohms @ 77 degrees F or close to that at room temp. Post back your results.
Nov 18, 2012 | Hotpoint RGB745 Gas Kitchen Range
What do i do about an F1 alarm that won't quit??????
Hello there:
this annoying alarm and the f1 code is reffering to the
2. Touch membrane defective To determine which component is at fault, you will need to remove the back panel that houses the electronic control unit then disconnect ribbon strip. going to it and retry the oven If NO fault code, replace membrane, otherwise replace board
Oct 05, 2010 | Magic Chef CER1115AA Electric Kitchen...
Magic chef stove model # 6898VRA keeps setting off alarm f1 why?
Have you tried to Turn it OFF and then Turn it ON.You could also try Pushing Multiple Buttons, if that could help.
If not, i am afraid that this is a BAD CONTROL BOARD / TOUCH PAD error. You need to replace either or both of these. Once done, it would Fix the Problem.
Some Models do Incorporate Touch Pad and Clock Control as One Part. So, that means you Could have Bad Clock Control.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 19, 2010 | Magic Chef CER1115AA Electric Kitchen...
Magic Chef kitchen range needs oven door hinges replaced
slide unit out they should be on both sides of the unit
Oct 30, 2009 | Kitchen Ranges
Gas oven alarming and flashing F8
Hi wlfwoman2002,
The F8 failure code description is an Analog / Digital problem. To resove this error code, please replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Hope it helps.
Thank you for using Fixya.
Jan 01, 2009 | Magic Chef 31000 Gas Kitchen Range
Magic chef beeping
You need to replace the touchpad. I'm just getting ready to replace mine for the second time in 14 years. A bit pricey but not a hard repair to make.
An appliance repairman told me that it's possible to peel the old pad off and carefully fish the connecting wire out to the point where it plugs together. This would save removing the burners and the stovetop I'm going to give it a try when mine arrives
Mar 01, 2008 | Magic Chef 31000 Gas Kitchen Range
Alarm fault code
f-2 is a faulty temp sensor. replace the oven temp sensor to solve problem
Nov 19, 2007 | Magic Chef CGR3742 Gas Kitchen Range
Kitchen Ranges Logo
49 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
