Question about Lexmark Office Equipment & Supplies
Print buffer now message on Lexmark T654 - Lexmark Office Equipment & Supplies
2 Suggested Answers
SOURCE: I cannot find the ADMIN PIN for a new LEXMARK
The only way to gain access when the admin pin has been lost is to open the panel on the left side of the printer. With the printer off, rRemove the metal cover over the board. Look for a small yellow jumper. There should be a series of three pins with the jumper connecting the center and right pin. Move it to the left so it covers the left and center pin. Wait about a minute and then turn on the printer. You should be able to regain access to the menus. You may always want to do a restore to factory by holding in select (checkmark) and right arrow then turning on the printer and releasing the buttons after about ten seconds to gain access to the service menu. From in there you can reset the printer back to factory. You can also reset just the network to clear a forgotten web password for example. These instructions also work on the Dell equivalent which is a 5530dn I believe.
Posted on Jul 31, 2010
Lexmark Pro 715 prints garbage
Sorry, hit the wrong key... IF a different program prints okay, try again with the program that invoked the original issue.
Update windows and the offending program.
The piece that stumps people is the buffer. Print buffers sometimes do not purge easily, and you have to "bleed" the garbage out of the buffer, by turn off, and back on type of procedures.
Oct 05, 2012 | Lexmark Pro 715 All-in-One Printer
T654 reset printer
Press the button with a key logo ( menus) until Busy/Waiting appears. This will give you an option to reset the printer.
For futher assistance please contact Lexmark Technical Support.
Feb 17, 2012 | Lexmark T654DN MONO LASER PRINTER
Lexmark t654 reset maintenance count
por favor alguem me ajuda a resetar os contadores da impressora t654 lexmark...por favor.
Feb 13, 2012 | Lexmark T654DN MONO LASER PRINTER
Lexmark x6575 - i work off a mac message reads : The cartridge carrier is jammed. Check under the scanner unit for obstructions. Close the unit and press the Check button on the control panel. Delete or...
Clear the print buffer, unplug the printer, remove everything that could be jamming the printer, CHECK carefully, then plug the printer back on and see if it has cleared. You may have to restrt the computer to reset the print buffer. Hope it helps.
Brock
Sep 16, 2010 | Lexmark P6250 All-In-One InkJet Photo...
Papaer jam "check duplex"
Here's an article in the Lexmark website on Paper Jams and the Printer Displays a 'Check Duplex' or a '23x' Type Paper Jam Message: Lexmark T650, T652, T654, or X65x Series Printers. Just click on this link: http://bit.ly/aqGjtK. Read the instructions thoroughly. Hope this helps but if you need more assistance, don't hesitate to contact Lexmark Technical Support. Thanks.
Jun 25, 2010 | Lexmark T652DTN MONO LASER PRINT Printer
Paper not pulling from tray 2 when tray 1 empties - Lexmark T654
For the majority of the Lexmark printers, all that needs to be done is to set the paper size and type the same for each drawer. Example - drawer 1 & 2 sizes are set to letter, drawer 1 & 2 paper types are set to plain. Set up this way, when drawer 1 empties, the printer will automatically switch to drawer 2 to supply the paper.
May 20, 2010 | Lexmark Office Equipment & Supplies
I have been printing chapters in a book. One chapter will not print. The message on the Lexmark screen is "flushing buffer". does anyone know what this means or why it will not print?
The 'flushing buffer' is most likely due to a corrupt file or file to large for the printer memory. You can check the file size and reduce it. Also you might want to upgrade your memory for the printer. Also might want to check your printer settings if the page you are having trouble printing is different from the other pages printed, such as text & graphics, etc. There is also a possibly of print program incompatibility or Windows OS Patch required but I doubt this since you have printed other pages without any problem. If you need to re-install Lexmark driver: http://downloads.lexmark.com/perl/downloads/downloads.cgi Or, if you need the Lexmark user's guide & reference guide: http://www.lexmark.com/publications/eng/optras/index.html
May 17, 2009 | Lexmark Optra S 1255 Laser Printer
What does "flushing buffer" mean
No response from the original poster as of 6/6/09. Normally, a "Flushing Buffer" message is pointing at a Postscript problem. A quick easy test would be to set the printer for PCL and retry the job. If it works, then you really need to look at the PS print file to find the error. Don
Jan 20, 2009 | Lexmark T644 Laser Printer
Posted by rhung33 on Jan 16, 2009 Under Window DOS prompt and Unix Sun Solaris 8 Station , using LPR -p command to print txt file to cause Lexmark T644 printer '' Flushing buffer '' and...
The printer can't handle the data it received and flush it out of its buffer. Goto Menu->Settings->Postscript Settings and turn "Print PostScript Erro" on. When the same print job prints, you should get a page printed out telling you what the printer doesn't like. You may also want to try forcing the printer into Postscript mode. Your PS file probably contains a PJL to set the device to PS mode before it prints. When the printer expects PCL data and received PS data(or vise versa), you can get this behaviour
Jan 16, 2009 | Lexmark T644 Laser Printer
620 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
