Question about Electrolux EL5020 Vacuum
Broken handle release spring assembly on an electrolux intensity
Handle release spring assembly has broken handle will not release what can i do to resolve this issue
2 Suggested Answers
SmartAlec
  • 171 Answers
SOURCE: repairing contacts in Electrolux Z8240 handle
Hi There, Alec From VacuumSpot here. I work as a vacuum technician and unfortunately I am the bearer of bad news the handle is not really repairable. Even in warranty Electrolux allowed us to simply swap the hose over in favour of any repair. If you need to buy a new Z8240 hose the part number is 1131404541.
Posted on Dec 07, 2012
How do I fix the foot pedal assembly for the handle release on shark vacuums?
You should call cust service. Call may still replace it.
Aug 04, 2014 | Shark Vacuums
Handle release stuck
its as simple as pulling top casing of bottom part of vac off and replacing the pedal just pay attention to where the springs go as you take them out
Dec 26, 2012 | Electrolux EL8502 Versatility Bagless...
The handle release pedal wasn't allowing the handle to lower. I took off the pedal and saw the spring load part was broken. What is this part and how to replace it? Bissell 3760-3 handle release
Order Slider Release (7.93, vacpartswarehouse) Pull off 'tank.' Remove 3 Screws for Foot Detent Lever. Pull off. Remove old slider release and spring (verify it's broke.) Replace with new. I just did this today after a year of dealing with it.
Mar 04, 2012 | Vacuums
The cord won't retract, how do I fix it?
Hold the vacuum at a nearly upright position. Gently tug and release the cord near the vacuum. This should cause the cord to retract. If not, it may be a worn out spring or a broken piece on the cordwinder. If this is the case, it needs to be taken to an Aerus Electrolux store for repairs.
http://www.aerushome.com/storelocator/
Jan 21, 2011 | Electrolux Vacuums
CORD SPOOL WILL NOT PULL BACK
Try tilting the vacuum to about a 45 degree angle. Gently tug and release the cord a few times. This usually will release the cord. If not, the cord winder may have broken, or the spring came loose, and it needs replaced/repaired. Take it to the nearest Aerus Electrolux store for help/repair.
Jan 19, 2011 | Electrolux UltraLux 2000 Bagged Canister...
Hoover savvy handle release pedal does not retract. There does not seem to be any mechanism to force it back, is something broken or missing, like a spring?
yes the handle release pedal is broken. i have the same problem and ordering the spare as i'm writing this email
Jul 07, 2009 | Vacuums
Replace power switch - Electrolux Epic series 6500
well, i post an answer in the wrong field, and i can't find it, so i will type one more time.
slide two vinyl side pieces off, and remove top halves. remove two screws from the switch, and remove it from top halve. between switch and outside button is a plastic rocker, which is broken. you will find two broken pieces, one spring for the rocker piece, and one small plastic rod, which goes inside of the spring for support. i do not know if part is available, but you can for quick fix like me, turn the switch on by the hand, assemble unit, and plug in, and plug out from the wall. whay? i dont have electrolux store close by.
john
Feb 21, 2009 | Electrolux Epic 6500 Vacuum
Kirby model gd3
The "switch" refered to is probably the handle release button.
Sep 07, 2008 | Kirby Generation 3 Bagged Upright Vacuum
Electrolux EL5020 Vacuum Logo
94 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
