Question about Conair Professional Ceramic Hair Straightener - Black
My conair straightener won't heat up
I turn on my straigtener and the light turns on but it won't heat up anymore. I have only had had it for a few months so it's still in good condition. What should i do?
  • Anonymous Feb 25, 2009
    exact same problem...
  • Anonymous May 10, 2009
    SAME PROBLEM
I have the exact same problem !
Posted on Jul 27, 2009
Me too :(
Posted on May 06, 2010
    New Friend:
This just happened to me too. I've had mine for approximately 8 years-it actually made me sad :(( It styled my hair so nicely and it was so pretty with it's dark red satin-y finish. :( Any recommendations on a new steam straightener I should try? I might spend a little more this time and buy something from hot tools...
Posted on Jan 27, 2016
    New Friend:
Well, it's most likely because the plates have now burnt up, so there is really nothing to do but gt a new straightener.
Posted on Jun 16, 2013
3 Suggested Answers
  • 3 Answers
SOURCE: my conair straightener won't heat up
that same thing is happening to me! but iv had mine for almost 2 years...exact same hair straightener, its happening to many people! i dont know if this is the problem but alot of people wrap their cords around their straighteners (i did too) and it twists the cord that conects to the hair straightener and makes it loose. i still have not found a way to solve this problem.
i would just go out and buy a new one, and if your looking for good but inexpensive i suggest vidal sassoon. they get really hot and have many settings and many different types. mine has worked greats
just remember not to wrap the cord
Posted on Jul 03, 2009
FML.
Posted on Jul 19, 2011
Remington pearl plates won't heat with blue light?
1) you have to test the power cord for broken or fault with VOM
2) inside there are thermal fuse, test it and replace with VOM
3) test the heating element for open and replace, and test for ground
4) test the thermostat, and adjust it.
God bless you
Jul 22, 2012 | Remington T-Studio Pearl Ceramic 1" Slim...
Black and decker all temp steam iron stopped working while ironing and now it won't turn on.
please see the cause and fix it:
a) tank or ports clogged. Dissasembly and inspect replace tank and seal if badly clogged. Emptying iron after each use allow heats to evaporate remaining water and helps prevent clooging. Inspect valve and linkage: clean or replace as necessary
GOD BLESS YOU
Jul 22, 2012 | Applica Black And Decker All Temp Steam...
Steam not working on iron then lots of water pouring out of holes
fill water chamber with vinegar and let it sit for 24 hours.
empty vinegar - fill with distilled water - turn on and press the steam button to clean the holes in the plate of mineral deposits which accumulate from using tap water. after a few shots of steam all should be clear - empty and refill with distilled water and it should be good to go.
May 08, 2012 | Tefal Pro Express GV 8120 Iron
When I plug in my iron the light comes on but when I go to push the button to turn it on it does nothing, not even heat up. The iron is only 3 months old
Good Day!
Please open the cover of your iron and look for the thermal fuse inside.That is the only problem of your iron replaced it on the same ampere and temperature.
Thank you and don't forget to rate my answer.
May 10, 2011 | Irons
Iron is not heating. Tried shaking it. It will start to heat then turns off. It is onlt a few monthe old.
If shaking it does anything, you should not use it. It clearly has an internal problem that could lead to shock or a fire. Even if you are not under warranty, most manufacturers will replace a unit with a serious fault that can lead to liability. You should contact the manufacturer directly. They will be very helpful.
May 06, 2011 | Rowenta Irons
I have the vertical commercial steamer model IS 8100. Machine lights up, no steam. The cord doesn't even get hot. I've tried to demineralize it by allowing vinegar to sit in the well of the base. Thanks...
My unit did the same thing. There is a temperature fuse attached to the heating chamber. If the unit overheats it will blow this fuse. It is not re-setable and must be replaced. Radio Shack carries these items.
Check your chamber for crude. Mine was pretty bad and I ended up filling it up with white vinegar over night. If you can get it to work, boil a solution of 1/4 white vinegar and DISTILLED water. Let it run through a whole tank of it and then run it with just DISTILLED water until you don't smell vinegar anymore. Do this every few months with heavy use.
Jan 10, 2011 | Rowenta IS8100 Iron
My iron will not stop flashing and will not go to green light -- it will not heat up
Hello :
Check the fuse first ! If the fuse is in good condition , then try this troubleshooting .
1: Make sure there's enough water in the tank if the iron won't steam. Fill the tank up .
2:Check that the iron is set to a steam setting. Some of the settings are dry and won't create steam.
3:Set the temperature dial to the shaded setting which represents steam. You'll see a little dark cloud-type icon with raindrops as opposed to a white cloud with a stripe through it. The dark cloud represents moisture (steam), and the white cloud with the stripe through it represents no steam.
4:Allow the iron to heat up for a while and to emit steam for a couple of minutes while pressing the extra-long burst button a few times. That should get rid of any impurities which can cause blockages. Try this if the iron hasn't been used for a while and steaming is intermittent.
5:Iron horizontally. Steam is only generated when the iron is horizontal.
6:Use the maximum steam setting when the iron is set to its maximum temperature setting.
7:Let the iron get to a high temperature before expecting steam. If the soleplate isn't hot enough, the water won't turn to steam and will in fact drip, spit or leak from the soleplate. Some Rowenta irons have an anti-drip system, which will turn off the steam when ironing at a low temperatures. Turn the temperature up, if needed.
PLEASE DON'T FORGET TO RATE !
Apr 21, 2010 | Rowenta DZ5080 Iron with Auto Shut-off
May 31, 2009 | Conair Professional Ceramic Hair...
NI-A57SR steam Iron suddenly not functioning
I had the same problem, when I took it apart, I noticed the theromstat points needed sanding. Just a reminder, make sure to write down the order of wire leads before disconnecting. By the way to test if the heating element is working connect white lead to the second connection from the left and black lead to the far right. Place your iron flat down on a wet cloth ( so that you won't burn your surface). You can also use an electrical tester. If heating element does not work though, it is time to buy a new iron.
Dec 31, 2008 | Panasonic NI-A57SR Iron with Auto Shut-off
Conair Professional Ceramic Hair Straightener - Black Logo
3,915 people viewed this question
Top Conair Irons Experts
ashburton
Glenn Smart
Glenn Smart
Piyal Perera
Piyal Perera
Are you a Conair Iron Expert? Answer questions, earn points and help others
