Question about Kenmore Dryers
Model #11082722200 Kenmore Compact electric dryer
SOURCE: Kenmore dryer (electric )
NOT ELITE HE4..... Model 96595400. Replaced thermistor and Hi-Limit Stat. Probably the thermistor.
Posted on Jun 29, 2008
  • 142 Answers
SOURCE: Kenmore dryer model 110.62066102 electrical wiring diagram
contact manufacture.
Posted on Sep 14, 2009
jsrock516
  • 5911 Answers
SOURCE: Kenmore electric dryer model 110.60942990 no
If the dryer runs, but does not heat, the following link explains how to troubleshoot an electric dryer with a no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
NOTE: If the wires at the terminal block are not color coded, the outer two wires (left and right) are the hot leads. The center conductor is neutral or ground.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the dryer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
All dryers are not constructed the same. However, the Heating Element is located inside a heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
If either the TCO or Hi-Limit Thermostat are determined to be bad, replace BOTH components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
If the model number you have this listed under is correct, the part numbers are as follows:
Heating Element - 279838
TCO/Hi-Limit Thermostat Kit - 279816
All these parts can be found at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com. The average cost of these components varies, so shop around for the best price.
All your heating circuits are accessible by removing the lower toe panel dire the rear of the dryer by removing the back panel. Just remove the screws around the perimeter of the back panel and the heating circuits will be located on the right-hand side. Refer to the exploded view diagrams at the websites2.gif I mentioned for reference. The heating circuitry is located under the "Bulkhead Parts" section.
If you have any questions, or require additional assistance, please let me know. I hope you find this helpful.
Posted on Nov 01, 2009
jmeredith
  • 417 Answers
SOURCE: Kenmore Electric Dryer Model 110.6972110 timer motor NG
hi,
maybe call a generic appiance store other than sears, try maytag store. the knob pulls staight off and the timer nut is below. then take off the back cover off the control panel, sometimes those screws are on the front corners, sometimes hidden. take a picture of the timer wiring and tape and label all the wires before you remove it. unplug it first!!
jm
Posted on Nov 29, 2009
blueextc3221
  • 15935 Answers
SOURCE: kenmore electric dryer model 68702894 turns but no
The heater element may have failed - however, first check the Thermal limit fuse on the rear of the machine (silver disc held by 2 screws). Check for continuity.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Mar 05, 2010
Sears Electric Dryer is flashing F01 What is wrong?
The F01 indicates a failed electronic machine control board. This error code can sometimes be caused by a glitch or power surge through the electrical lines. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
You can order a new control board from the Sears PartsDirect website.
http://www.searspartsdirect.com/partsdir...
Here's how to do it: http://media.fotki.com/1_p,wkwdftgtbkdgf...
Error code on dryer F01 - Kenmore Elite HE3 Dryer - iFixit
https://www.ifixit.com/.../Error+code+on+dryer+F01 Traduire cette page The F01 indicates a failed electronic machine control board. This error code can ... The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Dryer Sears / Kenmore HE3 - F01 Error Code Main Circuit ...
2q==? 7:35 https://www.youtube.com/watch?v=eWqrn5klxm0 20 avr. 2015 - Ajout? par Jim Dandy Sears Kenmore Dryer Model HE3 - F01 Error Code. Main Circuit Board Repair - Electronic Control Board ...
Error code F1 on Kenmore HE2 electric dryer appeared ...
www.shopyourway.com > ... > Questions Traduire cette page Sears Kenmore HE2 electric dryer; model #11087571601. F1 error message appeared ... Power it back up and see if you still get the F01 error code. If not, then I ...
What does the error code F-01 mean on my Kenmore front ...
www.shopyourway.com > ... > Questions Traduire cette page By unplugging and plugging in the electrical cord, I got the dryer to work again. ... What does the error code F-01 mean on my Kenmore front loaded HE2 dryer? ... My kenmore washing machine 110.46462500 is flashing an error code F.01 ...
Feb 04, 2016 | Sears Kenmore Elite Electric Dryer 69278
How to thread the belt on the idle wheel and pulley without it coming off
Sheryl
should be doable as long as it does not have welded belt retainers,
if it has removable bolts or guards which help keep belt from falling off, remove these first. good luck
press the helpful button
the link below shows how to do it, but is not your model, hope it helps Dryer Not Spinning Whirlpool Kenmore Electric Dryer Repair Part 341241
Jan 18, 2016 | sonya Portable Compact Small Laundry Dryer...
Kenmore 240 volt compact electric dryer not heating model # 110.89182990
U need to check the heating element ,u know how are CALl for service
Mar 13, 2015 | Kenmore Dryers
Kenmore twin washer do not drain yes
Does the pump engage and if so there might be something stuck in the hose before the pump
Mar 10, 2014 | Whirlpool LTE5243DQ 24" Compact Thin Twin...
Kenmore electric dryer model 68702894 turns but no
Feb 28, 2010 | Kenmore 60172 Electric Commercial Dryer
HAVE A MODEL KENMORE ELITE He4 ELECTRIC DRYER. IT
Check the burner tube and clean it out.
Sep 26, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer model number 110.66912691 not heating.
Check the house electrical panel for tripped dryer-circuit breaker-pair. Push off, then on. If immediately re-trips, the dryer has a dead short circuit in it. If they hold, then retry the dryer. If it now works, ok! If not, recheck the breakers as above. If tripped again, there is a likely short in the dryer's heater assembly. The drum must be removed to access the heater.
Aug 24, 2009 | Kenmore 62602 Electric Dryer
Jun 28, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
