Question about redbox.com
This operation currently prohibited for this disc
Bluray disk on bluray player
DVD says operation currently prohibited by disc Audio
Some discs for example will not let you bypass certain parts of a disc. Different types of disc will also stop certain functions happening. It's unlikely there is a fault, unless it's really crucial to the operation of the disc player.
Aug 24, 2017 | Televison & Video
When I insert disk it says no disc and when I go to select movie it gives the option of USB or player but when I select it nothing happens no response This is a recent problem player has worked for some...
It sounds like the laser is either out of alignment, dirty, or unable to read the disc for one reason or another. Have you tried a DVD and a BluRay disc or only BluRay? What kind of player is it
Feb 20, 2015 | Televison & Video
How to unlock regional code of philips HTB3510 3d blueray player?
Check current region code
Open the Philips HOME Screen
Type on your remote: 8520
This will display all of the current settings for your player.
Example: Region_Code: DVD(2) BD(B)Change region code
Turn on player with no disk inserted
Press "Open/Close" on the remote control until the tray is open
Press 8689310 - 0 means all region
Press 8689311 - 1 means region 1,
Press 8689312 - 2 means region 2,
Press 8689313 - 3 means region 3,
Press 8689314 - 4 means region 4,
Press 8689315 - 5 means region 5,
Press 8689316 - 6 means region 6.
Now the front Buttons might not work!
Go to SETUP and click on RESET FACTORY SETTINGS
Wait until the player restarts and now you can play all DVD regions
Oct 08, 2014 | Philips HTB3510 5.1 3D Home Theater System...
Where can i get a replacement part, the lens drive to be specific for this bluray player
Even if you got a replacement; the art of alignment is prohibitive and frustrating to say the least. After spending money and your time wasted; you would be better off replacing the drive.
Nov 26, 2013 | Sony BDP-S350 Blu-ray Disc / DVD Player,...
This disk does not fit the specifications
With a Samsung playe you go into your settings and for your BD Live feature you 'PROHIBIT" it and the disc will work fine. Here are the steps.
1) Settings
2)Network
3)BD-LIVE Interernet Connection
4)Select PROHIBIT
5)EXIT
it is good to go back ito menu to make sure it saved it.
Feb 12, 2012 | Samsung BD-C6900 Blu-ray 3D Player
My bluray player is a sony have owned it for 2 years but have primarily only played dvd's on it and have had no problems with it working on all types of discs. However recently I purchsed some bluray discs...
Lens cleaner disk works but it is a cd, which does not heat up a bluRay circuit. DVD too does not heat up the circuit. BluRay disks are denser in data(30gB) and runs closer to the lens, so reading disks is more critical. And some movies may heat up the circuit to freeze the functions. Maybe a moisture problem, keep it power on to drive off moisture on the semiconductor ICs.until bluRay disks work.
Oct 28, 2010 | Televison & Video
Blue ray player wont play a new disk says it needs
Software updates have to be done on bluray players whenever the technology in bluray discs themselve is changed. If you call the number for 20th century fox on the back of the bluray a representative there will explain to you what has changed technologically in this bluray that has caused there to be software updates for all of the bluray players. I believe LG can send you a disc so that you can update your player. Give them a call. The bluray players are all manufactured and shipped to the stores. In the meantime if an update is needed and its sitting on the shelf at the store until you buy it, even if you've just bought it an hour ago it will still need to be updated. The stores do not unbox the blu ray players and update them for you. However the Geek squad will update bluray players for customers for a fee.
May 06, 2010 | LG BH100 Blu-Ray Disc Player
I have a samsung blu ray 1080 hd that won't read disks when inserted it displays the message disk can not be played
Are you tryign to play back hoem made / burnt discs? If so the format more then likely is NOT compatibe with the bluray disc player....This is very common...You must rememeber bluray just came out and right now you have to expect it to only play conventional DVD's and blue disc's any other format is most likely not compatible
Jul 25, 2008 | Samsung Televison & Video
Cannot play DVDS
What does it do? I have a similar problem. the disk loads up and I get the previews, etc.. then I hit play and it says "Operation currently prohibited by disc.
Jan 01, 2008 | Sony DAV-FR1 System
redbox.com Logo
47 people viewed this question
Top redbox.com Computers & Internet Experts
David Payne
David Payne
Are you a redbox.com Computer and Internet Expert? Answer questions, earn points and help others
