Question about LG P509 Cell Phone
My LG-P509 phone does not recognize my sd card, any suggestions?
I have tried changing the SD card on my phone but it still keeps telling me, " SD card removed."
  • 5 Answers
SOURCE: Micro-sd card capacity
absolutely. the first time you pop it in, your phone will ask you if you want to format it. select 'yes' and then you will find several new folders for pix, flix, music, etc.
Posted on Nov 21, 2007
  • 4 Answers
SOURCE: micro SD card wont work
type 277634# * # (no spaces)
click port setting
click mass storage
click mass storage remove
go back to main screen and check again for memory
if this doesnt work,take out memory card and try without the memory card.
Posted on Jan 03, 2008
SOURCE: My LG Chocolate VX8550 wont recognize micro sd card
Here are the steps I took:
  1. Insert the micro sd card with the metal plates facing you (that took me a second). Don't worry about the little push you have to give.
  2. Go to the Settings & Tools option in the Menu.
  3. Select *. Memory
  4. Selct 3. Card Memory
  5. Select Options while the bar is on "1. Memory Usage". The only option available to me was 1. Format and select that.
  6. It will ask for the phone lock code-if you have never set it IT IS THE LAST 4 DIGITS OF YOUR TELEPHONE NUMBER.
  7. The phone will format the card and put the file folders on it.
  8. Use the adaptor USB reader or whatever you have to connect it to the computer. Copy songs to the my_music folder.
for mp3 as ringtones:
  1. You should select the part of the song you like, and can add effects with this:http://www.mptrim.com/
  2. To set it as a ringtone, send it as an attachments to you areacodeandyourphonenumber@vzwpix.com. It must be small to go through, around 30 seconds.
  3. You will get a text message, and select options. Select Save As Ringtone.
Posted on Oct 17, 2008
  • 212 Answers
SOURCE: my phone wont read the micro sd card
Check wheteher the card is nor micro SDHC, you r device supports only SD cards , if its SDHC then your device wont ablt to read it
Posted on Sep 07, 2009
  • 821 Answers
SOURCE: Micro SD Slot in My LG Rumor 2 isn't reading Micro SD Card
hello,kindly check if it is inserted properly,you will see a directive arrow on the memory card to show you how it is to be inserted,if after you have inserted it correctly and it still does not sees it,i would suggest you suspect your memory card is corrupt if their is any message displaying on your mobile phone screen,and if it does not show any message like memory card corrupted,then you will have to visit a mobile phone repair expert to help you change the memory card slot,after this your mobile phone will now read your memory card.
kindly rate this solution if it's helpful,
take care.
Posted on Apr 16, 2010
Why isn't my LG phone recognizing my Micro SD Card any longer? How can I put music on my phone than?
Try another known working card in the phone. If that also does not work then you have a serious issue with that phone. If it works then parhaps your card has gotten corrupted and needs to be reformatted or replaced.
Aug 30, 2015 | LG Cell Phones
I have a 16g sd card in my phone and when i try to download an app it tell me there is not enough space on my device why wont it use my sd card
You need to setup your phone settings to use the SD card instead of phones internal memory. Should be under the settings menu, look in the apps section and storage to find what your looking for...Change the defaults to use the SD card and NOT the internal memory.
Hope that helps.
Dec 22, 2014 | LG Optimus GT540 J1
Camera does not recognize any sd card
See if camera electronics can be reset. Contact the manufacturer for this procedure. If nothing can be done to restore camera to factory defaults then the electronics are fubar. May not be cost effective to repair.
Sep 08, 2017 | Canon PowerShot SD1000 Digital Camera
My phone keeps telling me that my SD card has been removed but it hasn't been. I've tried taking it out and putting it back in but it keeps telling me the same thing
maybe because your phone don't recognize your SD card anymore. try to put your SD card to other phone and try if the other phone recognize your SD card, if the other phone don't recognize your SD card, the problem is in your SD card. you should buy a new SD card if that's the case. Also try to put a different SD card on your phone and you'll see your phone will recognize the different SD card.
Kindly rate this post. Thank you for your question and I hope I help you a lot.
Jan 20, 2012 | HTC Cell Phones
LG 970 shine will not recognize SD card
THIS WILL MAKE YOU LOOSE ALL FILES!!!
(even password)
Take the memorycard out of the phone and,
put it in a computer.Use filesystem FAT-32
to reformat your memorycard.
Now the card will work again!
No password, No files will be left after a
complete reformat
This is your solution! Please vote!
Jun 10, 2009 | LG Shine KE970 Cellular Phone
KS 360 won't recognize my micro SD card
best to back it up on your computer then FORMAT the sd card when inserted into your phone
Apr 25, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Micro SD card wont work
click port setting
click mass storage
Nov 01, 2007 | LG CU500 Cellular Phone
Micro SD Not Reading
I have same problem with A1200 not recognize micro sd card.
some one help ,Please.
Thank - you.
Oct 07, 2007 | Motorola Mobility A1200
LG P509 Cell Phone Logo
189 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
