Question about JBL TLX PS10 Speaker
I have a TLX JBL PS10 speaker and need to know if the fuse has to go back in a certain way because I have to replace the fuse?
    New Friend:
  • 60 Answers
It uses a slow blow 2amp fuse - only one way it goes in :)
Posted on Feb 07, 2013
3 Suggested Answers
Just_Bobz
  • 448 Answers
SOURCE: JBL TLX PS10 Subwoofer - Does not work
If you have checked the fuses which it sounds like you have, your amp may be out. Take that RCA and plug it into the other speaker. If thar she blows, treat as warranty and call the factory. If this is helpful, please post as such.
Posted on Jan 18, 2009
SOURCE: JBL PSW-D112 Speaker fuse blow immediately after replaced
The Problem in this unit is the Amplifier module S64AMI,which is surrended in a black heatsink, filled with epoxy, not serviceable, the bad news is that JBL discontinued this module and is really hard to find, sorry....
Posted on Nov 21, 2009
Interested in your Infinity sub repair; could I send you some images to verify infinity TSS-1100 has no light, seems blown to me, not sure if it has the screw you mentioned
Hi my name is MIchael and I repair the following amps JBL PB10, PB12, PS10, PS12, TSS-1100,TSS-1200,VENUE SUB12, E250P. If it has the screw near the on/off switch. If your amp is blowing the fuse, has bad sound, no sound, doesn't power up or if the output is low or muffled. We can fix it - please check ebay and search WE REPAIR JBL PB10, PB12, PS10, PS12, TSS-1100,TSS-1200,VENUE SUB12, E250P - you will find us ... Edwards Electronics ....
Oct 24, 2011 | Infinity TSS-1100 System
I have a JBL TLX PS10 sub woofer, and it keeps blowing fuses almost immediately.What do you think the most likely problem is? also, where can I download a free service manual for this item? I have removed...
Edwards Electronics not only repairs the following amps they also do upgrades to them so they do not burn up again: TSS1100 TSS1200 PS10 PS12 E250P PS210 and a few others - Look on Google for them or Ebay. Thanks.
Aug 17, 2011 | JBL TLX PS10 Speaker
Hi can you tell me that impedence on JBL TLx4 speakers- i need to know if they are compatible with my denon RCD M37 dab player thanks
hi,
Is it JBL TLX 420 then its impedance is 4OHMS. You cant connect these speakers to denon rcd m 37, because its output impedence is 6 to 16 ohms.
ok
Jul 04, 2011 | JBL PSW-D110 Speaker
Hi, my E250P is experiencing blub, blub sound after 45 minutes to 1 hour in operation for the past few month. But at this point of time, when switch on, loud wobble sound are generated even the input...
WE REPAIR THESE AMPS ... JBL PB10, PB12 (IF SCREW NEAR ON/OFF SWITCH) WE REPAIR THE PS10, PS12, VENUE SUB12, TSS-1100 TSS-1200 E250P. CHECK FOR US ON EBAY EDWARDS ELECTRONICS OR MESASURPLUS.COM - FAST WORK - WITH WARRANTY - HAVE FIXED THOUSANDS OF THEM.
Mar 16, 2011 | JBL Northridge E 250P Subwoofer
I have an older JBL TLX PS10 sub woofer but hardly used. I get a green light when plugged in. However, the speak makes a loud continuous noise when I plug in the Y connector to the low level input. It...
Just touch your fingertip to the input connector on the sub -- similar noise? That would be its amp picking up the hum of the room through your antenna-like body. IF that is the same noise, you need to make sure your input cable is shielded and connected at both ends BEFORE applying power to the electronics at either end.
Be mindful of electronic noise sources such as track lighting, UV lights, motors, TV's, etc, and route the signal and power cables well away from them.
Try reversing the orientation of the AC plug at the sub and see if that helps out.
Feb 10, 2011 | JBL TLX PS10 Speaker
Jan 17, 2009 | JBL TLX PS10 Speaker
Bloon Fuses!
You don't need schematics to replace the fuses.
Open the speaker unit by unscrewing the back. The fuses are located near the on/off switch assembly. Replace them and screw the the unit back together.
To avoid blown fuses, try lowering the volume.
Aug 18, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
114 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
