Question about Abit : AL8-V LGA775/945P/FSB1066/ATX Motherboard (MOTAB15)
I instolled a 160 gig sata hard drive in my pc it runs fine for about 2 days after wich at start up it goes to chk dsk where it says that one of your disks needs to be cheched for cosistency it runs the scan and deleted some of my files the disk also slows my pc down considerably i have an intel p4 with a 3.2 mhz processor and i'm running 1 gig ram what should i do
  • Dirk Le Roux Jan 24, 2009
    i did a test on drive and it running fine on other guys pc could it be my bios thats out dated
    Scholar:
  • 96 Answers
Sounds like the 160gb drive has some issues ...bad clusters etc ... if it keeps happening you can be sure the drive will fail soon.
I would look to replace the drive as soon as possible. If it's less than a yar old you should be able to get it replaced under warranty.
Posted on Jan 24, 2009
My Seagate Momentus 5400.6 500GB hard disk is told to be inaceesible and corrrupted by my pc. the plug of hard disk was broken so i changed the casing twice , it works finely for 2 3 days and then there...
Internal hard drives should only be opened in a clean room. If I understand you correctly this drive is bound to fail. Suggestion: Start moving files onto other space.
Aug 28, 2012 | Seagate Momentus 5400.6 500GB SATA/300...
Hello sir, can i ask u abwt my computer problem? i need ur help nw bcoz i cant open the computer...it says here DISK BOOT FAILURE. THANKS
DISK BOOT FAILURE...
1st-check ur hard disk drive see if the sata/ide cable loose o not
2nd- change ide port o sata port
3rd- goto BIOS make sure HDD booting first
4rd- check ur HDD by scaning using windows chk dsk o use other utilities such as HDD generator
or something else
Oct 26, 2010 | Computers & Internet
Turned off raid, unable to access 2nd 160 gig hard
Right click on Computer in the Start menu. You should see manage.
click on manage and you will see some selections the left one called disk management. click that and you should see all your drives. If you disable the Raid you may have to initialize the disk for windows to use it again. right click on the drive and initialize or if it shows up you may have to create a partition and then format.
Mar 08, 2010 | Dell Dimension 3100 PC Desktop
IS THERE ANY replacements for YH278 HITACHI 120 GB SATA HARD DRIVE HTS541612J9SA00, THAT IS CAN I REPLACE WITH 250GB.
Generally speaking, you can replace any SATA hard drive with any other SATA hard drive. Notebook SATA drives are all the same size, basically, (2.5 inch), and desktop drives are generally the same size (3.5 inch), Desktop and notebook SATA drives will connect to the same power and interface cables, though desktop drives require more power. Just make sure that you pick a 2.5" drive for your notebook, or 3.5" drive for your desktop, and the drive will attach with no problems.
As for the size of the drive, to my knowledge, any system with SATA should support any size SATA drive (I put a 500 gig drive in my notebook, where the stock drive was 160 gig).
Feb 28, 2010 | Dell Inspiron 6400 Notebook
F7 hard drive problem the PC has two 360 gig hard drives. Which one is the primary? Will a WD serial # WCAV 5463220018 3.5 inch SATA hard drive 1000 Gbyte be compatible with my PC?
If your PC has SATA connections yes you can use SATA, but not a SATA 2.5 which only fits a laptop! When you use 2 drives one must be set by jumpers on rear of drive to master..... the slave drive (2nd hard drive) must also be set to slave by same jumpers.
Dec 23, 2009 | HP Pavilion Elite M9150F Desktop PC
CAN I UPGRADE THE HARD DRIVE IN MY ASUS A8M LAPTOP, EXAMPLE CHANGE THE 80GIG DRIVE TO A 160 GIG
Yes you can upgrade the hard drive from 80 to 160 GIG SATA for you to have more storage for your computer files....
Jul 16, 2009 | ASUS A8M Notebook
160 gig sata hard drive that keeps on failing
hello what brand is ur hard drive. western digital has software that can scan ur hard drive for possible hard ware errors, as does seagate. in addition ur motherboard may have a test that may help (smart something not sure but good luck)
Jan 24, 2009 | Abit : AL8-V LGA775/945P/FSB1066/ATX...
Satelite M40 Boot problems
It sounds like your hdd. If you have access to another computer, download a program called SeaTools for DOS, from the Seagate website:
http://www.seagate.com/www/en-us/support/downloads/seatools
This program will make a boot disc that will check ALL sectors on the drive. If bad sectors are found, you will be given the option to fix.
Let me know how you get on.
Tim
Dec 19, 2008 | Toshiba Satellite A100-S8111TD Notebook
Service pack3 crashed puter - after reinstall machine thinks extra hard drive is a disk drive.
You can get to the BIOS by hitting DEL or F2 at start up.
However, that does not have anything to do with a drive letter.
Drive letter designation is set in
START>SETTINGS>CONTROL PANEL>ADMINISTRATIVE TOOLS>COMPUTER MANAGEMENT>DISK MANAGEMENT.
Hope this helps.
Sep 06, 2008 | E-Machines eMachines Desktop PC
Laptop cannot see externa drive
do you get a LED blinking ? is there power on the drive? Is the Activity LED blinking as well?
Dec 23, 2007 | Western Digital imicro IM35ST320SI 3.5 IDE...
Abit : AL8-V LGA775/945P/FSB1066/ATX Motherboard (MOTAB15) Logo
32 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
