My system is losing display
When i switch it ON it displays for a few second or minute after that display is off i think main machin is ON because fans are ON i know its not monitor's fault and os is also right because i have two os can it be CMOS battery fault ?
  • 180 Answers
You can check the SMPS or replace by a new smps.remove the ram and clean the slots and refix the ram
Posted on Jan 17, 2013
  • mukesh roulta Jan 17, 2013
    are you sure its smps problem ?
  • 383 Answers
SOURCE: HCL Monitor type HCM580M display problem
Information about the Linux / UNIX less command. Thus, various display problems may result, such as long lines being split in the wrong place. -R --RAW-CONTROL-CHARS, Like -r
Device Manager information and help This section will also display what COM ports are detected; for example, ... CODE 13 - System Failure - Possible problem in Device Driver or Windows 95 Code.
Good Luck, Please dont for get to Vote, Thank You.
Posted on Dec 20, 2007
benwabnick
  • 2404 Answers
SOURCE: OSD main controls locked and moving cursors by itself
i think the main board is flaky in that monitor. Hook up another known good monitor to that computer and see if it behaves in the same way.
If it does behave in the same way then you know its either the video card or the motherboard if you have an integrated video connector to the motherboard.
If it goes away then you know the phillips monitor is bad.
If its the phillips monitor that is bad for sure. You can try taking off the front cover and try cleaning the contacts on the main board in the front of the monitor. Could be that a few of them have dust or dirt and is activating those buttons by accidents inadvertently.
Posted on Jun 27, 2009
  • 732 Answers
SOURCE: my VA712 does not turn on, when supply button
bholesir, If unit covered by ViewSonic warranty, USE IT!!! The units "switch-mode-power-supply" is in need of service!! Unit WILL require inspection and repair of possible bad (poor quality soldering) soldering of electronic components to the prinded circuit cards and or need replacement of bad (poor quality) electrolytic filter capacitors on the unit's "switch-mode-power-supply"/"CCFL inverter circuit" that have failed!! Do a visit to YOUTUBE for "LCD monitor disassembly" and "LCD monitor repair" so you can familarize FYI with what is inside your monitor, and possibly make a decision to do a DIY repair or contract out the work to a local TV/LCD monitor repair shop. If your pocket is deep enough, maybe you will repair and buy a new unit, keeping VA712 as spare unit for a rainy day. Read more of my responses to other owners in my FIXYA profile for more options not mentioned here. Good luck with repair. 12fixlouie
Posted on Jan 27, 2010
budmrtn
  • 11361 Answers
SOURCE: hello, i have one asus lcd monitor, the display is
Please look through the pictures, most monitors have the same problem; bad caps, very few has failed lamp assemblies due to poor soldering works.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 03, 2010
Testimonial: "yes it is helpful, i will send the photos to you by mail. thankyou"
  • 732 Answers
SOURCE: my LG Flatron L1515S 15" LCD goes on blank scree(black screen)
sitaramjava, Problem not new one!!! When lcd screen goes "black" point bright flashlight (torch) 1" (3-4cm) from lcd panel to determine if you can still see desk-top icons!!! If icons are visible, unit SMPS is in partial shutdown mode. If not visible then SMPS is in full shutdown mode. You or qualified CCFL back-lit lcd monitor technician will need to make repair to units internal SMPS/ CCFL inverter supply. Your monitor isn't any different than any other brand in it's basic design and operation!! Read my and other CCFL backlit lcd monitor technicians FIXYA profiles to see if you can repair it. 12fixlouie
Posted on May 04, 2010
Error code F13 showing on whirlpool ghw9300pw2, please help
Controller fails to detect door lock triac correctly This error code is displayed if the main control unit fails to detect the door lock triac correctly. Also, if the controller cannot unlock the door after 240 seconds after the cycle is completed then this error will be shown.
If displayed switch the washing machine off completely, recommend disconnecting it from the mains supply for a few seconds. Switch it back on and the controller will attempt to unlock the door once more but, if it fails to do so in the same 240 seconds the error code will be displayed once more.
  • Check all wiring and connectors between the main controller and the door lock
  • Check main control unit, probably requires to be replaced
Mar 09, 2015 | Whirlpool Washing Machines
Sky box green light on permanent
Sounds as if the software is corrupt. Try a forced software update...
1) Switch the digibox off at the mains power, so no lights are displayed on the unit
2) Press and hold the BACK UP button on the digibox (not the remote control)
3) Whilst holding, switch the digibox back on at the mains power so the red standby light is displayed
4) Wait approximate. 10-20 seconds for the remaining 3 lights to display, at which point you can release the BACK UP button
5) Allow the digibox to download the latest software, which can take 10 minutes before returning to standby
6) Leave 60 seconds then power up as usual
A software update/refresh will leave your recordings intact. You won't lose anything.
If this doesn't solve your problem, then the next step is more drastic. It's a Full System Reset and Planner Rebuild. Be advised though: Your recordings are at risk!
1) Switch your digibox on
2) In sequence, press on your remote 'SERVICES > 4 > 0 > 1 > SELECT' (this will access the hidden menu)
3) Select the relevant option (usually the bottom two) and follow the on-screen prompts (note that it's likely your digibox will reboot between processes)
Applies to Sky+HD Digiboxes only, running latest EPG
1) Press Services on your remote control. 'Options' in the Top Menu will be highlighted in orange.
2) Press the Right arrow once to highlight 'Settings' in the Top Menu.
3) Now press the Down arrow once to highlight the 'settings' tab in the Middle Menu.
4) Press 0, 0,1, Select on your remote in quick succession. The 'Setup' tab will then be highlighted within a hidden menu.
5) Select the relevant option and follow the on-screen prompts (note that its likely your digibox will reboot between processes)
Sky Digibox Planner Rebuild / Full System Reset (if stuck in standby)
Applies to Sky+ and Sky+HD Digiboxes only
Same as above, but applies if your digibox is stuck in standby and you cannot get to the hidden menu:
2) Press and hold the 'right and left arrow' buttons on the digibox (not the remote control)
4) Wait approximate. 30 seconds for the blue Sky+ ring of lights to display, at which point you can release the 'right and left arrow' buttons
5) Press 'SELECT' on the digibox (not the remote control)
6) Now the system will format the hard drive, the blue Sky+ ring of lights should spin backwards
7) Allow the system to format, which can take 10 minutes before returning to standby
8) Try to power up!
Sep 02, 2014 | Televison & Video
Intermittent Start (expanded explanation)
Lint will jam the start/run switch on the motor. Vacuum out the motor real good and check that the switch moves freely, and all the wires to it are plugged in good.
Nov 30, 2013 | Maytag Dryers
Frigidaire Affinity ATF6700FS2 pauses with every load
Hello - This particular issue can be caused by quite a few reasons. Washer could be experiencing a communication error from the main control board, faulty door lock assembly or the timer itself is not operating correctly. Did you notice a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned or could possibly have another issue with the door lock assembly or pressure switch. You can also press and hold the start/pause and cancel button together at the same time for approximately 30 seconds to display an error code on the LED. What error code does it display? However, I would suggest contacting a professional to accurately diagnose the washer.
Nov 04, 2012 | Frigidaire Affinity ATF7000E Front Load...
I keep getting the over load display after a few minutes even on the clean machine setting. i have taken clothes out but does not help. on the clean machine setting there arent any clothes in it but after...
I dotn have soe USA/Canada numer, but could answer and comment that your "OL" codes, with the tub empty, indicates, that there's a problem in the drive/ tub system or the fill level.
Two choice there, first is that your hub mechanism is sticking. This model floats the basket, and although it does not say so, I am guessing that too heavy a load stops this process. In your case the floating mechanism may be sticking, so the machine thinks it is too heavy a load.
The second possibility is a bad machine control board. In the next link culd find the Repair2000/Library/CABRIOHEWASHER as reference guide to solve it.
Hope helps (remember to rate and comment this answer)..
Jul 02, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Getting error code C11A4 can you help me fix this please?
Some basic reset procedures.
A. Open and close the front door.
B. Power off the machine, wait 30 seconds power on.
C. Power down the machine, unplug from the wall for 1 minute, plug in and power on.
D. 13.1 Trouble resetting
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON again while pressing the Utility/Counter key more than 10 seconds after.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. Turn off the Main Power Switch and turn it on again more than 10 seconds after, and make sure that the machine properly starts.
Nov 19, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Hi there, everything seems to be working but there doesn't seem to be a signal going to the TV. Am just about to try using a HDMI cable. Do you think this will help?
What I did was initally hook up both the composite (R/W/Y) cables and the HDMI and switched between TV inputs until I found the display. Once I had the display (mine was on composite) I went to the settings, then display, and switched it to HDMI input. The screen went blank and I switched to my HDMI TV input and saw the display. I unplugged the composite and it was good to go. I also had to hold my finger over the power button for a few seconds when turning it on - I believe it resets the display to default, but it worked. Good luck!
In the event that it gives you a hard drive error shortly after, it's nothing to worry about. You won't lose anything and it will take a few minutes to run its course. Just make sure you never turn it off from the back of the system first, always shut it off via menu options.
Respectfully,
Don
Jun 02, 2010 | Sony Playstation 3 (PS3) Console
MY TREADMILL STOPS JUST A MINUTE AFTER STARTING.
Try Lubricating the belt with silicone spray.
Probably the resistence from the belt scraping over the ground board is too high, forcing the machine to switch off in order to prevent damage.
Jul 24, 2009 | Kettler Exercise & Fitness
Hotpoint Aquarius WD640
got the same problem, engineer came out thinks motor will need replacing approx £180 plus fitting
Apr 05, 2008 | Hotpoint Aquarius WD640 Front Load...
BLACK OUT LCD DISPLAY AND PANEL NT FUNCTIONING
hi,
seems like a silly question, and i dont know about canon copiers, but on my toshiba, underneath the key panel there is a scroll button that turns the brightness of the lcd up and down, if hit by accident, as often happens the lcd appears black. It has tricked me before!! haha
Take care
Apr 01, 2008 | Office Equipment & Supplies
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
