How to take apart drum assembly on kenmore front load washer
Drum sits inside a plastic housing. I have taken apart the housing but am having trouble getting the stainless steel drum off the other plastic piece.
    Scholar:
  • 87 Answers
Is this a HE2,5,4 model? Can you give me the model number from inside the door. If it's a front loader. The only way you can get it out is to totally tare it down, cement, springs, shocks, and crack apart the outer tub. Very very labor intense. Usually if the unit is out of warranty, the cost of a tech to do it isn't worth it. What's the issure with it?
Posted on Jan 24, 2009
  • janetwillson
    janetwillson Apr 14, 2012
    I have a similar problem. I want the inner drum to use for another purpose, as a wood burner but can't get the plastic casing off. So I need to use brute force is that what you are saying?
Washer not draining but motor still hums
I would get to the water outlet pipe and blow hard down it to try and clear any blockage if not take the pump housing apart to clear the blockage eric
Dec 24, 2017 | Kenmore HE2 Plus Front Load Washer
Kenmore front load washer 970 c41032 00
Your spider assembly has corroded and broken. The exact same thing happened to my own washer (same model number as yours). Here's a picture of what it looks like inside.
This other guy made a youtube video demonstrating the same problem with his washer. As explained in the video, the replacement part cost $200 (in 2007).
After taking apart my own washer, I can tell you that it's not easy to replace this part. It took me several hours to get the washer apart. Even if I were to replace the defective spider assembly, I doubt I could get it back together without screwing it up. Also, the drum's scratched all to hell. Time to get a new washer.
Jul 26, 2013 | Washing Machines
WHIRPOOL washing machine drum out of alignment and making horid noise
There are no alignment adjustments for front loading washers. The only issue that could exist to make this type of problem is if the spider or support arms that hold the wash drum true in the washer are broken. You can verify this by removing all items from the washer and spinning the wash drum by hand. If it is sagging or rubbing against any part of the washer as it spins, then the spider is broken.
It is an expensive repair, since the washer needs to be taken apart and the wash drum and spider assembly has to be replaced and maybe the outer plastic tub may also need to be replaced. Get a few estimates before deciding whether to repair or replace. Sorry.
Mar 23, 2011 | Whirlpool AWZ412 Front Load Washer
Wash drum won't rotate, how do you take apart?
taking apart this machine is very time consuming, the entire tub assembly has to be removed from the washer cabinet.Does the drum turn by hand?
Jun 09, 2010 | Kenmore HE2 Plus Front Load Washer
We have a kenmore elite washer mod. 970-c40062-00 ser. xc11700832. the washer leaks, and is very noisy. It is 10 years old
Your Stainless Steel drum is supported inside of the washer tub by a spider assembly. The assemply, which is made of cast aluminum, has corroded (steel and aluminum and detegent don't mix) and the spider assembly has broken. The drum has likely wobbled enough to wear a hole through the tub. You need to replace the drum and spider assembly, and tub.
Mar 06, 2010 | Kenmore Elite 45986 Front Load Washer
Worn out front rim of plastic tub surrounding stainless basket
well not sure about yours but some front load washers have a five year warranty on the tub but you have to pay the labor which is between 100-150dollars
Dec 29, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 3.1 capacity front load washer
CHECK REAR BEARING(rear of drum)OR THE ROLLERS THE DRUM ROTATE ON LOWER PART OF WAShER
Jan 19, 2008 | Kenmore 43142 Front Load Washer
Washing Machines Logo
198 people viewed this question
Top Washing Machines Experts
