Manual for ST-Z11L
FM aerial connection is via two connections and my FM aerial is coaxial connecter how do I connect
    Problem Solver:
  • 17 Answers
Http://compare.ebay.com/like/150922992753?var=lv&ltyp=AllFixedPriceItemTypes&var=sbar
Posted on Jan 16, 2013
OnlyOneN
  • 86 Answers
SOURCE: Digital optical from DVD player produces no audio
Hi, It sounds like your receiver is still looking for audio on the coaxial connection, rather than the optical.
1. Make sure the optical connection is between your DVD player and the LD/DVD Optical In on the back of your receiver.
2. If you have a monitor connected to the receiver to show the on-screen display, click Setup from the main menu, click Input Mode, then, next to LD/DVD choose Optical. It may be set to coaxial, analog or auto.
Alternatively, choose the input source on the front of your receiver (LD/DVD), then press Input Mode button (bottom right, near the input selector) till it displays Digital Optical.
If all else fails, reset the receiver by:
1. Turn off the receiver
2. Hold down DISPLAY and PANEL UP/DOWN buttons and press power.
3. All Clear should appear on the screen.
Use caution, however, as this will erase all the settings in your receiver.
Posted on Apr 20, 2009
SOURCE: REAR CONNECTION
You can make your own or find someone who can. I hope this helps.085fcaf.jpg
Posted on Apr 21, 2009
Bulldog AV
  • 52 Answers
SOURCE: hi i have a yamaha rx-v995 reciver and just
1) Check to see if the screen says "EXT DECODER". If it does, press the EXT DECODER button again and this should fix the problem
2) Press input mode button until the display reads auto or digital. It may be set to analog.
Posted on Nov 23, 2009
SOURCE: Trying to play Pandora radio
I have the same problem. Used to work even on Iphone 4 and suddenly it just stopped working about 10 days ago. Very strange as i have not updated my iphone (I'm on Version 4.02). My Denon dock is ASD-3W (wifi) connected to Denon 3808CI.
Any info appreciated.
Posted on Dec 21, 2010
dunnbiker
  • 8546 Answers
SOURCE: Hi. I write from spain. I have the blu-ray LG
Have you tried the another optical cable? They don't tolerate dirty connections or small-radius bends in their routing. THAT (and the expense of optical cables) is why I always choose coaxial connections when possible.
Posted on Mar 02, 2011
When on FM tuner, stereo stops playing after a few minutes
Right then sounds like the connection from the aerial lead into the receiver - check out the socket where the aerial plugs into!
Is it loose at all or could there be a bad connection inside the unit.
Get the cover OFF and investigate yourself before you rush down to that very friendly repair man along the street.
Jan 05, 2014 | Denon DRA-365R Receiver
How do I connect my DMR-EH57 to freeview
Connect a suitable aerial via a coaxial/RF lead to the 'RF in' socket. Connect another coaxial/RF lead from 'RF out' to your TV, and/or SCART or HDMI leads.
Access the 'setup' option within the menus to tune in to Freeview broadcasts.
Oct 03, 2013 | Panasonic DMR-EH57 HDD Recorder Player
Will not connect to tv channel
  • Connect the existing Aerial/Cable TV
    signal (or from the Cable Box/Satellite
    Receiver {RF OUT or TO TV}) to the
    ANTENNA-IN socket on the
    recorder.
  • Use the supplied RF coaxial cable to
connect TV-OUT socket on the
recorder to the aerial input socket on
your TV (VHF/UHF RF IN).
Helpful Hint:
- Depending on how you have currently
connected your TV channel (directly from an
off-air aerial or Cable box or VCR), you will
have to disconnect some of the cables before
you make the above connection.
Feb 02, 2013 | Philips DVDR3380/05 DVD Recorder
I want to connect a vcr to the tv but there are no connections except one coaxial connection. The tv is also conneted to a DTV box. Any suggestions?
Without you giving any more detail about the TV or the set-top box, the box probably has the connections you need to connect your VCR. You could connect the VCR to the secondary coax on the DTV box, or if it has them you could use standard A/V connectors (yellow=video red and white=stereo audio).
The easiest would be to use the other coax connection and look in the DTV boxes manual to see if there is anything you have to change on the box via the menu system.
Thanks for using Fix Ya and happy viewing.
Mikeywaf
Mar 14, 2011 | Televison & Video
In my philips SAA1732 fm is not working, if put scan, it scanning my no channel were is found. i connect to outside aerial but it still not detecting any fm stations... what i should do sir, please suggest...
You probably need to install a proper fm aerial and diplexer, is your aerial a TV aerial or a radio aerial?
You need to set it for the correct TV system in the software to get the audio from the TV, there will be a number of options like PAL I or PAL M or N. etc They have different sound settings, you need to choose the correct one for your system.
Dec 30, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
Marantz SR870 tuner not working
Make sure your FM antena connection is good. A receiver will not pick up an FM signal without an antena. Even a small piece of wire will work to test. If the Tuner section is bad, an external tuner can always be connected to an Aux input. Due to cost, it may not be cost effective to repair this unit.
Hope this helps.
Oct 08, 2009 | Marantz Audio Players & Recorders
Need connecting wiring for Sony ampilfier and tuner
FM-TUNER out connect into tuner in your amplifier
Jul 06, 2009 | Audio Players & Recorders
I have a CXSGT08HP sony car stereo. It was installed by a friend at home. The memory does not work. Can you tell me which wire is the memory wire and were i need to hook it up to?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}Hi Justtamera,
I’m attaching a wiring diagram which hopefully isreadable. I’ll also list the “where to”instructions for all of the other wires. It’simportant that several wiring steps be done in a particular order.
About the Memory Wire:
The memory wire is Yellow and should be connected to the +12 V power terminal (which isenergized at all times). First besure to connect the black ground (earth) lead to a metal surface of the car.
Important…
>>Before making connections, turn the stereo unit and carignition off to avoid short circuits.
>>Connect the yellow and red power input leads onlyafter all other leads have been connected.
>>The power antenna (aerial) control lead (blue)supplies +12 V DC when you turn on the tuner.
Hope this helps. Lemme know if you have more questions or would like me to email you acopy of the owner’s manual.
Thanks, and take care.
Gail :-)
Connecting the Sony CXS-GT08HP Car Stereo Unit
1. To a metal surface of the car
>First connect the black ground (earth) lead, thenconnect the yellow and red power supply leads.
2. To the power antenna (aerial) control lead orpower supply lead of antenna (aerial) booster amplifier
>Notes
>>It is not necessary to connect this lead if there isno power antenna (aerial) or antenna (aerial) booster, or with a manually-operatedtelescopic antenna (aerial).
>>When your car has a built-in FM/AM antenna (aerial)in the rear/side glass, see “Notes on the control and power supply leads.”
3. To AMP REMOTE IN of an optional power amplifier
>This connection is only for amplifiers. Connecting anyother system may damage the unit.
4. To the +12 V power terminal which isenergized in the accessory position of the ignition switch
>Notes
>>If there is no accessory position, connect to the+12 V power (battery) terminal which is energized at all times.
>>Be sure to connect the black ground (earth) lead toa metal surface of the car first.
5. To the +12 V power terminal which isenergized at all times
>Be sure to connect the black ground (earth) lead to ametal surface of the car first.
Important…
>>Before making connections, turn the car ignition offto avoid short circuits.
>>When your car has built-in FM/AM antenna (aerial) inthe rear/side glass, connect the power antenna (aerial) control lead (blue) or theaccessory power supply lead (red) to the power terminal of the existing antenna(aerial) booster. For details, consult your dealer.
>>A power antenna (aerial) without a relay box cannotbe used with this unit.
Nov 29, 2008 | Car Audio & Video
Cant connect playstation 2 to LG lcd tv
I have a sony bravia lcd digital color tv. I want to know how to plug in my play station 2? The PS2 has a coaxial cable running from it with a side coaxial connection. Where an how do i connect?
Nov 09, 2008 | Televison & Video
Ariel connection for denon dm 31
try going to your local tv store and ask for a male to male connector it looks like this:http://www.firefold.com/Products/RCA-Male-to-Male-Adapater__RCA-MALE-MALE.aspx
Dec 02, 2007 | Audio Players & Recorders
 Grubhead
Grubhead
